ASUS TUF Dash Motherboard FX516 REV 6.0 Model Device Not Charging
  • lazenes
    • Jun 2016
    • 41
    • Türkiye
    Originally posted by mon2
    Locate and measure the voltage to ground on each leg of SL3006.
    I couldn't find SL3006 on my rev 6.0 board — that part isn't present on this revision. In the same area there is a resistor labeled R3220, and I measured ~3.3 V to ground on it.
    Can R3220 be the equivalent/component replacing SL3006 on rev 6.0? If so, which points should I measure next (both sides of R3220, MB_MAX_POWER, or other specific pins)? I can attach a photo of the board area if that helps.
Name:	WhatsApp Image 2025-09-20 at 18.46.01.jpg
    • mon2
      • Dec 2019
      • 14691
      No, I don't think this part is the same. To confirm, meter in diode mode. Touch your meter probes together and the meter should tone beep.
      Remove all power to the board. One meter probe on the other side of this mystery part. Other probe on the other side of this same part. Do you hear a tone beep? If yes, then this is a low resistance component - like the ferrite bead in the schematics we are referencing from v4.0.
      • lazenes
        • Jun 2016
        • 41
        • Türkiye
        I tested the mystery component in diode mode and got the following readings (board fully powered off):
        Diode mode: probe orientation A→B = 0.642 (beep/reading), B→A = 1.470 (reading)
        Resistance mode: ~10 kΩ
        • mon2
          • Dec 2019
          • 14691
          Go back to the resistor @ R8935. Attach the pre-charged battery. Now measure the voltage to ground of R8935. Do you have a voltage now with the battery attached?
          • lazenes
            • Jun 2016
            • 41
            • Türkiye
            Unfortunately, there is no voltage coming through. :/
            • mon2
              • Dec 2019
              • 14691
              So there is an issue here for sure.
              Can you confirm that when you attach the battery, do you press the power switch to turn on the board? This is important.
              From the mix of reviewed schematics - the very first power rail that must be a logic '1' = 3v3 is +3VA_EC.
              The +3VA_EC turns into +3VACC and this +3VACC should appear onto the resistor used for the adapter detection but is missing. This is all assuming that your board will be similar to the reviewed schematics to date. Most likely will be similar.
              • mon2
                • Dec 2019
                • 14691
                Do you have PU8803 onboard?
                PS: Have to run out. BBL.
                Click image for larger version  Name:	load_switch.png Views:	0 Size:	87.8 KB ID:	3729306
                • lazenes
                  • Jun 2016
                  • 41
                  • Türkiye
                  #28
                  I accidentally caused smoke to come out of the card earlier, and now the card won't open.
                  • lazenes
                    • Jun 2016
                    • 41
                    • Türkiye
                    #29
                    I repaired the burnt part. The device turned on. I read a value of 3.3 on one side and 1.2v on the other, but it is not charging.
                    • mon2
                      • Dec 2019
                      • 14691
                      Which part was replaced? Where are you measuring the 1v2?
                      • lazenes
                        • Jun 2016
                        • 41
                        • Türkiye
                        #31
                        THERE IS NO PROBLEM HERE, but the battery charge light is still not on, or it won't turn on without a battery. motherboard
                        • lazenes
                          • Jun 2016
                          • 41
                          • Türkiye
                          #32
                          The power button flex cable burned out, so I replaced it. The device turned on; there is no problem with the motherboard.
                          • mon2
                            • Dec 2019
                            • 14691
                            Ok back from taming my out of control lawn.
                            Do you have +3VA_EC voltage at the output pin # 11 of the above load switch?
                            • lazenes
                              • Jun 2016
                              • 41
                              • Türkiye
                              #34
                              yes+
                              • mon2
                                • Dec 2019
                                • 14691
                                Good.
                                Do you have a voltage to ground @ AD_MAX_POWER? This is different than MB_MAX_POWER.
                                • lazenes
                                  • Jun 2016
                                  • 41
                                  • Türkiye
                                  #36
                                  Good.
                                  With both the battery and charger connected, there is no voltage to ground at AD_MAX_POWER when the board is off. However, when I power on the device, I measure about 1.28 V.
                                  • mon2
                                    • Dec 2019
                                    • 14691
                                    My bad - the AD_MAX_POWER is the adapter power signal; the MB_MAX_POWER appears to be the motherboard max power signal.
                                    What are the markings on your power adapter? Is it a 180W rated power supply?
                                    • lazenes
                                      • Jun 2016
                                      • 41
                                      • Türkiye
                                      #38
                                      Yes, exactly.
                                      • lazenes
                                        • Jun 2016
                                        • 41
                                        • Türkiye
                                        #39
                                        The adapter's image is this Click image for larger version
Name:	WhatsApp Image 2025-09-20 at 23.59.13.jpg
                                        • mon2
                                          • Dec 2019
                                          • 14691
                                          So the adapter IS being announced correctly to the EC.
                                          Confirm again if you have a voltage for MB_MAX_POWER. According to the v4.0 schematic, the high side resistor should also be @ ~3v since it is tied to +3VACC.
                                          If no voltage, remove all power. Meter in resistance mode. Measure the resistance between the top side of PR8935 to top side of PR8937. Best to test each side of these parts to confirm if one combination is ~0 ohms. That is, each high side resistor should be mated to be +3VACC. From earlier checking, the MB_MAX_POWER was @ 0v.
                                          • cope
                                            Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
                                            by cope
                                            I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
                                            Some history:
                                            Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
                                            As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
                                            Now, with a new battery the system will start up and run off...
                                            05-13-2024, 09:40 AM
                                          • GoCoSoftware
                                            Need schematic & boardview for Asus Tuf Dash F15 - Motherboard FX516PC r6.0
                                            by GoCoSoftware
                                            Hello I think I broke my motherboard when trying to upgrade the Ram!
                                            I made some shortcut when pluggining the battery connector because the thiny metal goes over nearest components and made sparks.
                                            The laptop won't poweron anymore so I need to check the motherboard to reveal if there is any shortcut.
                                            Could be great if some of You can share boardview for my motherboard FX516PC r6.0
                                            Thanks.
                                            Giuliano.
                                            10-11-2024, 02:49 AM
                                          • glovecaps
                                            Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                            by glovecaps
                                            I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                            My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                            The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                            11-25-2024, 04:23 PM
                                            ASUS TUF Dash FX517ZM-HN093 Notebook F15 Specification for Upgrade or Repair
                                            This specification for the ASUS TUF Dash FX517ZM-HN093 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX517ZM-HN093 boardview and FX517ZM-HN093 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-07-2024, 06:38 AM
                                            ASUS TUF Dash FX516PM-71B36CS2 Notebook F15 Specification for Upgrade or Repair
                                            This specification for the ASUS TUF Dash FX516PM-71B36CS2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX516PM-71B36CS2 boardview and FX516PM-71B36CS2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:20 AM
