Hi Super BADCAPS :-)
Today i have a challenge... New Asus UX582Z laptop with 2 screen.
The motherboard is well powered and the charger is not in a short circuit. Before the computer no longer turns on, it no longer charges the battery, then once the battery runs out, the computer obviously does not turn on anymore.
I noted several voltage points on the motherboard, but it seems that at the battery charge output the voltage is not correct.
I have the impression that a mosfet does not open a few times because it lacks power on the main one while the power is ok on...
Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
820-01700 motherboard charges but does nothing else
by orasl
by alsupoGood afternoom, my HP laptop with board Compal LA-G07JP only starts with battery but with something anormal :
- With only battery startup is normal.
- With only AC adapter same voltages but no EC_ON, no power up.
- Powered off AC adapter charges battery normally.
- With AC adapter charging battery as soon power on is pressed, charge is interrupted and laptop begins to run from battery.
No way to run from AC adapter. Which can be the reason?... -
by harounHDGreetings everyone got an hp 17 ab laptop does not turn on with charger , but turns on with battery plugged in and charges only when the laptop is off mb DAG37DMBAD0 REV D...
I have a Y50-70 gaming laptop. It has a problem where it charges up fine when the laptop is off, but when it's on, it doesn't.
I've tried a new 135w charger + new Lenovo battery and a new charging port but it made no difference.
I've updated all the drivers and still no difference.
Could it be down to a dodgy chip? I'll see if i can find a schematic and someone on here might be able to direct me where to test
Many thanks in advance.... -
by reessiHello,
I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
I have checked these lines in diode mode and they seam normal -> 600.
I have checked to see if they come on for even a fraction of a second... - Loading...
