MacBook Pro 820-00281-A A1707 macbook
  • jesi
    started a topic MacBook Pro 820-00281-A A1707 macbook
    hi all techs
    require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
    adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
    update:
    when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from 4.96v to 20.25v after 2 to 3 secs they drop to 19.77v
    attached a photo of the mb with all the voltages on the top side which i managed to note down are wdotted down on the attached photo of mb,
    i only get these voltages when the battery is disconnected and the adapter is connected, when battery flex is connected the macbook does not respond to anything no voltages except the usb c voltages
    i was thinking of flashing the bios to start with but not able to find the right one for it , so have not touched until i get a repnse from yourside
    these voltages i only get when the battery flex is disconnected from the mb
    thankyou in advance
  • jesi
    macbook pro a1707 dead
    by jesi
    hi all techs
    update:
    when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
    08-24-2025, 04:34 AM
  • CG_Dionysos
    MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
    by CG_Dionysos
    I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
    • Model: A1707
    • 15-inch, Mid 2017
    • 3.1 GHz Core i7
    • 16 GB RAM
    • Radeon Pro 560
    • 1 TB SSD
    • Board number: 820-00928-A
    I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
    Thanks in advance!
    Greetings from Germany...
    09-16-2025, 06:43 AM
  • leonemax81
    Macbook a1707 820-00281 Battery no Power
    by leonemax81
    Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
    08-23-2024, 09:24 AM
  • sofles
    Macbook a1707 2017 model 820-00928 GPU issue
    by sofles
    Hello there
    I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
    I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
    11-21-2024, 05:25 AM
  • tommy97
    Apple MacBook A1707 No Audio/Sound
    by tommy97
    I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
    I've also replaced U6300, but the problem persists.
    Here are the current voltage readings:
    • PPV18_S0: 1.8V
    • R6402: 1V
    • R6405: 1V
    • R6403: 1V
    • AUD_SPKRAMP_RESET_L: 1.3V
    • PPBUS: 12.6V
    03-10-2025, 11:22 AM
