ASUS X54H laptop thinks it's always charging even with charger unplugged
  • m1ch43lzm
    replied
    Boardview here
    https://www.badcaps.net/forum/troubl...-2-1-boardview
    From the datasheet of BQ24740 there's a voltage divider connected to pin 5, the output of it should be around 2.6V with charger plugged in
    ACDET Adapter detected voltage set input. Program the adapter detect threshold by connecting a resistor divider from
    adapter input to ACDET pin to AGND pin. Adapter voltage is detected if ACDET-pin voltage is greater than 2.4 V
    Measure both resistors circled in red (with power removed), the one in parallel with the cap goes to GND, the leftmost one the other end goes to the charger input, maybe one of them is out of spec
    Measure voltage at ACDET, marked with a blue line on the picture:
    1. Only battery connected
    2. Charger connected
    Unfortunately there's no schematic available and the "repair guide" is useless for this, you have to calculate the voltage divider with Voltage=19V and the measured resistor values
    The values from the typical application circuit of the BQ24740 may not match what ASUS used
    Keep one of the resistors, then calculate the bottom one with Out=2.6v, then match it to the closest 1% standard value
    EDIT: Actually the boardview has the values:
    PR8803: 330K
    PR8802 (parallel to the cap): 53.6K
    Premium supporters get full download access and other benefits.
  • ASUS X54H laptop thinks it's always charging even with charger unplugged
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Click image for larger version  Name:	charge light on with charger unplugged-.JPG.png Views:	0 Size:	6.46 MB ID:	3666753
    Windows also shows ''Plugged in'' when charger is not connected.
    Click image for larger version  Name:	Windows shows Plugged in with charger unplugged.jpg Views:	0 Size:	1.74 MB ID:	3666754
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will warn me to plug in the charger, and even if I do, the computer shuts down as if the charger isn't connected, even though the charge light is on!
    Sometimes the charging light flashes green and red alternatively which I think means some fault, but replugging the battery fixes it.
    As you see very weird behavior.
    The problem is the same whether the computer is turned on or off the charging light stays on.
    Some things I tried:
    In Device Manager uninstalling Microsoft ACPI-Compliant Control Method Battery and restarting.
    I measured RTC battery and it was a bit low 2.96V so I replaced it and it didn't help.
    I have two laptop batteries and the problem is the same on both.
    I think the problem is on the motherboard.
    How to troubleshoot it?
    Label on laptop bottom says
    MODEL: X54H
    MB Ver. X54HR
    but printed on motherboard K54LY REV 2.1
  • motormayhem
    Lenovo T460 Only Charges on One Charger
    by motormayhem
    Laptop Question
    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
    05-12-2023, 01:46 PM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
  • flat-earther
    how to prevent a connected charger from draining battery when not charging?
    by flat-earther
    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
    So the battery is backfeeding the charger and being drained.
    How can I prevent...
    08-07-2025, 01:04 PM
  • Johndill
    Dell Inspiron 7567 LA-D993P odd charger issue
    by Johndill
    Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
    There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
    I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
    Here are the tested scenarios:
    1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
    2. With the laptop off, plug in charger (LED says on) & the front charging...
    11-16-2022, 10:55 PM
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
