Apple iPad 9 (A2602) backlight issue / no backlight
+ More Options
Posts
  • szakacsa195
    • Apr 2022
    • 45
    • Magyarország
    No backlight on iPad 9. Made some measurements around LCD connector, please find on attached picture below.
    Filter marked with green star has been replaced since it blown.
    Yellow values measured relative to GND. Red ones measured on components. Filters seems to be ok, but before and after the replaced filter the resistance is very low. Is it ok?
    Where this filter is connecting to?
    Thanks!
  • szakacsa195
    • Apr 2022
    • 45
    • Magyarország
    Bump!
    Anyone any idea?
    Thx!
    • szakacsa195
      • Apr 2022
      • 45
      • Magyarország
      Bump!
      Help pls.
      • GeirAndersen
        iPad .pcb file collection
        by GeirAndersen
        I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
        Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
        IPAD COLLECTION 1
        +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
        +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
        +---iPad mini3 820-00008(A1599) 820-00002(A1600)
        +---iPad mini4 820-00180(A1538) 820-00177(A1550)
        +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
        +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
        12-09-2024, 09:28 AM
      • Cornito
        Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
        by Cornito
        Hello Team,
        I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
        Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
        Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
        08-08-2024, 08:09 AM
      • Cornito
        TCL 65C715 backlight issue
        by Cornito
        Hello team,
        I'm back with another topic.
        It's a 65C715 TCL tv with backlight issue.
        But the problem is a bit strange.
        When I took this tv from the marketplace backlight didn't work but picture was ok.
        Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
        Putting all back together the tv worked fine for weeks. => Contact issue??
        Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
        06-09-2024, 02:24 AM
      • barry101
        Apple A1286 Mid 2012 MacBook Pro 820-3330 LCD Backlight issue
        by barry101
        Hi everyone.
        I hope someone has some suggestions on how to proceed with this issue.
        I have an Apple A1286 2012 MacBook Pro with 820-3330 Logic board. My customer purchased this from me in full working condition. Unfortunately, it overheated on him due to being left running on his bed.
        Investigation showed the LCD Backlight was not working (had a latent image and external monitor worked), the battery was no longer functioning (system couldn't read it or charge it) and the Samsung 850 EVO SSD was dead (not seen by finder or disk utility). Quite the trifecta....
        03-24-2022, 03:25 PM
      • shellybelly
        Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
        by shellybelly
        Back Story
        I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
        So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
        08-27-2023, 10:40 PM
