Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Logic Board 820-01987-A missing PP3V3_S5
    No photos found.
  • mferna14
    Logic Board 820-00840-A Missing EDP_BKLT_EN
    by mferna14
    Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
    07-10-2024, 05:18 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • joliver82
    Sony XR-65A95L no power due to logic board issue
    by joliver82
    Hi guys!
    I'm trying to repair a TV that a friend gave me recently. Lightning struck next to his house and broke the TV apart from more electronic devices.
    First of all I've checked the power supply and it works as expected. I removed the logic board and shorted the 3.3v standby output to TCON_ON and POWER_ON and every voltage was generated as expected (12v and 25v for logic board and 32v for TCON).
    When trying to boot the TV normally (having the board connected), the TCON_ON signal is not generated from it which made me think there's some issue in the logic...
    11-26-2025, 04:57 PM
  • ohren
    by ohren
    09-08-2023, 05:24 PM
