Hi good Friends., today working on a Macbook Pro A2289, Logic board 820-01978-A. The history was liquid spill, Cleaned & replaced all corroded components & now the logic board shows 20v & .01amp on the meter. Not taking in any amps. Upon trouble shooting I get the required stable voltages 5V, PP3V3_G3H 3.3V but no PP3V3_S5. Checked the schematic, assume that this is generated from U7800. Checked all the Input/Output voltages on this chip. All is fine, except PP3V3_S5 is missing. Resistance from GND to PP3V3_S5 is 146 Kohms. First I need to make sure whether PP3V3_S5 is generated from this chip??? Thanks in advance
Logic Board 820-01987-A missing PP3V3_S5
It could be but personally cannot keep up with the madness of each model as it varies with the direction of the wind. THIS model does require a charged battery to boot. Would you have a battery connected? Ghettoware.
reference:
https://boards.rossmanngroup.com/thr...harging.64804/
See post # 10.Comment
Ok mon2., at last I figured out ths problem. This laptop had to be put in DFU mode & all restored back to factory default. Now at least I will remember that with 20V & drawing 0.03 ~ 0.08 amp, mostly it is to be rectified with DFU Mode. & one thing more for these models logic boards PP3V3_S5 will be missing & once restored all the require point with have 3.3V. Case done. Thanks dear for your helpComment
reference:
See post # 10.
I just want to clarify on your point, as mine only has the trackpad and fans working when I press the power button. Are you saying that to have it actually boot to the login screen, it would need a charged battery?Comment
Assuming...7 Photos -
by mferna14Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. β
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
The models launched in 2018 and 2019 respectively.... -
by fajfelekHello, First of all thanks you for reading this topic.
I need your help with identify missing parts on trackpad logic board (661-18430).
The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
Please help me with identity parts from blue and red area .2 Photos - Loading...
