asus k55a no display
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hi guys i got here asus mobo. can somebody see and help me pls... i got those voltage in coil and one is missing. what might be the problem?
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    Re: asus k55a no display
    which voltages u got?
    • dycc
      Vision
      • Nov 2011
      • 625
      • Côte d'Ivoire
      intel graphic voltage is missing (0.4v or 0.5v ). on some HP model reflow southbridge or flash bios can solve this issue
      • dycc
        Vision
        • Nov 2011
        • 625
        • Côte d'Ivoire
        CPU also can be bad as you don't have dedicated gpu on this board . don't ignore the (DC-DC) chip who supply this voltage can also be bad . good luck
        • rickybucalan
          • May 2013
          • 322
          • philippines
          0v on single big coil near cpu socket. the rest are written on the picture..tnx
          • rickybucalan
            • May 2013
            • 322
            • philippines
            thanks
            where exactly could i find that voltage? i did mild reflow on S/B chip and doesn't work. do you think its bios problem?
            • rickybucalan
              • May 2013
              • 322
              • philippines
              ok i will try that thank you....
              • diif
                • Feb 2014
                • 6978
                • England
                Hi, did you find a solution to this ? i have an identical laptop with the same missing voltage.
                • dj_ricoh
                  • 2073
                  did you try another cpu?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    No, but i have found a couple of Mosfets that don't seem to have the correct voltages.
                    19v on the Drain with no voltages on the Source or Gate of the mosfet on the rear (4955N) and 1.6mv on the Source on the front (4936N) mosfet.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      I forgot the photos
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        I have tried a replacement CPU and still the same issue. DC-DC chip problem ?
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3608
                          • slovakia
                          remove coil and check for short.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            By measuring the resistance between ground ?
                            Nothing on the back.
                            The two diodes next to the cpu show a short until i remove the cpu, is this normal ?
                            Source of the 4939 is to ground also.
                            I'm not quite sure what i'm doing, your help is much appreciated.
                            • martin319831
                              • Jan 2015
                              • United Kingdom
                              Hi all
                              I've got similar problem, I've got picture but no backlit. HDMI and CRT work fine. Because I cannot find motherboard schematic it makes it even more difficult. I've checked all lcd pins and I've got 19V, 3.5V, 1.3V, 1V and 0.3V. Can anyone help please?
                              P.S. I've tried 3 different LCD screens.
                              Thank you
