A1708 820-00840 No boot - trackpad clicks - 20V 0.55amp
  • dellxps15
    • Feb 2014
    • 1590
    • italy
    Originally posted by FedorUkr
    Please tell me what resistance should be on the PPVCCGT_S0G line relative to ground?
    it is 2.5 omh.
    PPVCCGT_S0G volts come on only when logged into os.
    • FedorUkr
      Fedor
      • May 2025
      • 8
      • Ukraine
      Originally posted by mon2
      What is the voltage to ground of PPBUS_G3H? Is it stable?
      To me, ALL_SYS_PWRGD - 3.21V, this is a low pull-up voltage and should be ~3v3. Perhaps an issue with the PCH which consumes this voltage rail.
      Be sure to use a beefy USB-C power supply. Suggest 100W rated power supply + 100W rated power cable for testing.
      Try this bios:
      https://we.tl/t-erKf1uZb9U
      This bios didn't help either, I think the problem is not in the bios
      • mon2
        • Dec 2019
        • 14275
        Test with an external monitor. Do you see any graphice on the external display?
        • FedorUkr
          Fedor
          • May 2025
          • 8
          • Ukraine
          no, the board does not initialize
          • FedorUkr
            Fedor
            • May 2025
            • 8
            • Ukraine
            Originally posted by dellxps15
            i got some 820-00840 fixed by reflowing the cpu ic u7100 .
            replacing U7100 didn't help, no changes
            • No Lan
              [Macbook pro A1708] [Boot loop] [Trackpad ?]
              by No Lan
              Hey everyone,
              Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
              Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
              Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
              05-24-2025, 03:09 PM
            • cyber47
              Macbook Pro A1706 (820-00923) no boot if display or Trackpad connected
              by cyber47
              i have used the search function but i doesnt found my problem.
              I am reparing a MacBook Pro A1706 with the Boardnumber 820-00923-A.
              If i have the display and/or the trackpad installed the Macbook does not boot, i have 20V and 0.03 Amps at the charger (without the battery connected), i can post a video of the Amperemeter if this helps.
              The board has PPBUS_G3H and it seems it is in the S5 state (i have the voltage on the S5 rails but not on the S4 rails).
              If i connect the charger without die display and the trackpad installed...
              12-20-2022, 02:57 PM
            • privato89
              Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
              by privato89
              I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
              Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
              Let's begin:
              Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
              03-26-2024, 06:37 AM
            • hinisa
              Xiaomi router freezes at boot after re-capping
              by hinisa
              I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
              When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
              After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
              Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
              07-08-2023, 05:58 AM
            • Luke Anders
              Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
              by Luke Anders
              A few details about the laptop itself:
              Name: Lenovo Legion 5
              Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
              BIOS Version: GKCN60WW
              EC Version: GKEC65WW
              Serial Number: PF39AQ7Z
              Board Model: NM-D562 Rev 3.0
              RAM: 16GB Installed, DDR4 (brand new)
              NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
              I bought this laptop recently from eBay as a faulty device....
              10-12-2024, 05:13 AM
