Lenovo ideapad 5 windows 11 update disable charging circuit?
  • bogart219
    • May 2009
    • 200
    • usa
    #141
    I got to have something touching somewhere , where its not supposed to touch by getting that flashing OL reading on my meter where I should be reading 3 and 5 volts. I started looking for solder blobs again. I was checking the components that I put down and found that TPS chip I replaced , I was actually able to push it around with my tweezers1, wtf, It wasn't soldered down properly.a cap right next to it came off too! Let me get this straighten out (hopefully). Also hoping this was the cause of the flashing readings! I will let you know! Thanks!
    • bogart219
      • May 2009
      • 200
      • usa
      #142
      Originally posted by m1ch43lzm
      You're missing both +3VALW and +5VALW, those are very important, if those are missing the power on sequence stops there
      Measure +3VALW_EN on PC6230 (may be missing from the board, that's ok)
      and +5VALW_EN on PC6231 (may be missing from the board)
      Those should be high level, 3.3V, if they're 0v something went wrong
      I've marked the location where you can measure those signals, in green for +5VALW_EN and yellow for +3VALW_EN
      PC6230 = 3.28 VOLTS
      PC6231 = CAN'T FIND (MISSING) ?
      • m1ch43lzm
        • Mar 2019
        • 757
        • Peru
        #143
        PC6231 is also a missing component, but the solder pads are there, go back to post #131 on the previous page, the pictures are back , I marked it with a green line
        Ok, now the 3.3v are enabled, you should get now 3VALW
        • bogart219
          • May 2009
          • 200
          • usa
          #144
          Try setting your multimeter to volts, manual range appropriate for 3v, if it's auto range
          If manual range set to 20v range
          Just want to confirm if that chip is being told to enable the 3VALW and 5VALW outputs by the EC IT8227 (it's branded "Lenovo", a BGA chip which may have black glue on the corners, it it has the glue better not to try to remove it, as the pads on the PCB may become damaged)
          Inspect the area first for stray solder blobs
          Expected steady 3.3v on those enable signals
          Also check RE4501 and RE4505, should be 0 ohm resistors, or may be just traces, those feed 3VL to the EC
          Pictures were lost , hopefully the admin will fix the forum issues
          I remember part of your follow-up question before the post was gone, it was about where the 5v goes
          The 5v should go after the MOSFETs, on the fuses, even if the TPS65994 hadn't negotiated the 20v yet, it should pass those 5v to the BQ
          It's a bit complicated, because the sequence I think is like this:
          Charger only, or a completely empty battery
          1. The TPS65994 passes the 5v to the BQ, which will boost those 5v to 13v (if battery is not present), creating the main power rail
          2. The RT6585C (PU6219) generates the 3VL and 5VL by internal LDO regulators, from the main power rail
          3. The EC (embedded controller) IT8227 (UE1) powered by 3VL, then tells the RT6585C to enable the 3VALW and 5VALW outputs
          4. The EC also communicates with the TPS65994, feeding it the required firmware
          5. then the TPS65994 negotiates the 20v
          6. After getting the 20v, the BQ charger IC acts as a buck converter, generating the appropriate voltage for charging the battery/main power rail
          7. We're in S5 power state, the EC waits for the power button press to turn on the laptop
          Some laptops will also power on on their own if the RTC battery is not present or was unplugged before
          With a working battery step 1 changes to:
          1. The BQ connects the battery to the main power rail through a MOSFET
          Skip 5 and 6 if charger not plugged in
          Hopefully what I wrote is understandable, or maybe too technical?
          Further reading: https://www.badcaps.net/forum/troubl...arging-circuit
          Yours is Narrow VDC (NVDC) topology, buck-boost converter
          The issues your laptop has right now are separate, if now we're not getting those voltages (3VALW, 5VALW), either due to a short, or it's not being told to enable, that's what I want to check first
          Before you removed the MOSFETs it powered on from battery, so maybe a stray solder blob, or missing resistor that got dislodged somewhere
          Reflowed the TPS chip and reattached the cap, still getting flashing meter like before.
          With batt & charger plugged in. On the BG chip, ( PU5301) was getting 11.7, 3.2 and 1.4 volts on a number of pins. RE4501 & RE4505 , NOT ON THE BOARD.
          • bogart219
            • May 2009
            • 200
            • usa
            #145
            Pics still not working for me. Will try again in the morning, thanks.
            • m1ch43lzm
              • Mar 2019
              • 757
              • Peru
              #146
              11.7 is from the battery, that chip is doing its job for now
              Check again
              +3VALW at PJ6201
              +5VALW at PJ6206
              May need to scratch a bit those points with the probes, sometimes flux from manufacturing can form a non conductive layer over the solder blobs
              The enable for 3VALW is present, so we should have 3.3v there with just the battery connected
              Sorry for the pictures not showing, only noticed the thumbnails working now, but the full image doesn't work
              The admin is working on fixing the attachments, we have to wait
              • bogart219
                • May 2009
                • 200
                • usa
                #147
                Check again
                +3VALW at PJ6201
                +5VALW at PJ6206
                Hi. when I check the voltages to ground on PJ6201 and PJ6206 with just the battery, the meter just flashes back and forth between 1 and 3 volts approx. No steady reading.
                • m1ch43lzm
                  • Mar 2019
                  • 757
                  • Peru
                  #148
                  That could mean there's an issue with either 3VALW or 5VALW, can also be related to the flickering on the USB-C meter
                  Try removing the solder blob at PJ6206, add fresh solder then use solder wick to clear it
                  With only the battery, Repeat the measurements at PJ6201, and either side of PJ6206, check if the 3.3v and 5v are stable now (laptop won't power on for now)
                  • bogart219
                    • May 2009
                    • 200
                    • usa
                    #149
                    Still no power there on either one. On both One side flashes overload and the other side has .5 & .1 volts going down like a cap is discharging or something. What kind of pads are those?
                    I see the picture posting is still not working
                    • m1ch43lzm
                      • Mar 2019
                      • 757
                      • Peru
                      #150
                      Those pads at PJ6201 and PJ6206 are solder jumpers, the board designers sometimes leave those in the final board design, as they're used for isolating the power supplies from the rest of the circuit when they design the prototype board
                      Sometimes they don't bother replacing those with solid traces, but i noticed they do with the 0 ohm resistors.. in the schematics and board view there's a resistor, but in the real board it's just a trace in that spot
                      About clearing those jumpers, sometimes a tiny bit of solder is still making a connection, it's good to double check for continuity with the multimeter across both sides of the jumper
                      Also those solder bridges/jumpers are useful when troubleshooting a board
                      For the pictures not uploading, try contacting the admin Document Archive , as i noticed some users couldn't upload files
                      Originally posted by Document Archive
                      There was an issue with uploads. The server was launched from backup and upgraded os, php, and vbulletin. We just realised now the tmp upload directory and session directories changed. That is hopefully fixed. Still a few missing files.
                      • bogart219
                        • May 2009
                        • 200
                        • usa
                        #151
                        WITH JUST THE CHARGER PLUGGED IN: PJ6201 NO VOLTAGE TO GROUND. PJ6206 , LEFT SIDE 2.5 VOLTS RIGHT SIDE HALF A VOLT. J4 AND J5 NO VOLTAGE AND NOT FLASHING.
                        WITH JUST THE BATTERY PLUGGED IN : PJ6201 & PJ6206 BOTH RIGHT SIDE FLASHING, LEFT SIDE 0 VOLTS. J4 & J5 0 VOLTS AND NOT FLASHING.
                        If I check a capacitor and get a reading to ground on both sides, doesn't that mean the cap is shorted? Thank You
                        • m1ch43lzm
                          • Mar 2019
                          • 757
                          • Peru
                          #152
                          Something definitely wrong, could be the TPS65994 or the soldering on it
                          There's no way to get those 2.5v if PJ6206 is open unless the TPS is badly soldered, there's a solder bridge somewhere, or has an internal fault, the 5v from the charger shouldn't go anywhere except the TPS itself and the input of the BQ, it shouldn't "leak" to 5VALW
                          It means only that whatever is in parallel to the cap is shorted
                          May be the cap itself, another cap in parallel on the same voltage rail but on a different physical location, an IC, anything...
                          One side of a cap in a power rail is definitely GND
                          • bogart219
                            • May 2009
                            • 200
                            • usa
                            #153
                            I replaced that TPS chip but its very possible I shorted it out with my half ass soldering I Thought I had soldered but bump it a few days later and move it moved around. I will put the old one back in as there was probably nothing wrong with it( you or mon2 didn't tell me to replace it), I did that on my own.
                            • m1ch43lzm
                              • Mar 2019
                              • 757
                              • Peru
                              #154
                              Try removing the TPS65994, don't solder it back, check for shorts between the pads (except those which are connected together on the schematics)
                              Only battery for now, as it won't work with the charger for obvious reasons, just want to check if the 3VALW and 5VALW are working before installing the TPS65994
                              If those rails become stable, reconnect the solder blobs PJ6201 and PJ6206, measure again if the voltages are stable 3.3v and 5v
                              If that works, laptop should be able to power on from battery, I want to get back to the point where laptop worked from battery but not charge
                              • bogart219
                                • May 2009
                                • 200
                                • usa
                                #155
                                Hello. Removed TPS chip. from schematic checked all pads (that had to do with voltage), to ground and found NONE shorted. With battery plugged in only, measuring to ground, J4 and J5 still 0 volts.
                                PJ6201 & PJ6206 LEFT SIDE STILL FLASHING RIGHT SIDE 0 VOLTS.
                                Still a problem with downloading attachments I believe.
                                • m1ch43lzm
                                  • Mar 2019
                                  • 757
                                  • Peru
                                  #156
                                  Measure resistances between S-D, S-G, D-G on PQ6204, PQ6201
                                  On PQ6202 (it's a dual MOSFET, source from MOSFET1 is connected to drain of MOSFET2, referred as S1D2), measure resistance between D1-S1D2, S1D2-G1, D1-G1, and between S2-S1D2, S2-G2, S1D2-G2
                                  Measure voltages at PL6202 (5v), at the red dot, and PL6201 (3,3v) at the orange dot from the picture above
                                  The red and orange lines are where the MOSFETs connect to the respective inductors
                                  Also measure the resistances (in K ohms) across PR6209, PR6211, PR6210, PR6215, should be close to the value listed on the schematics
                                  PR6209: 13K
                                  PR6211: 20K
                                  PR6210: 30K
                                  PR6215: 19.6K
                                  Again check the enable voltages
Name:	5valw 3valw en.png
                                  Uploads work for me with the "Upload attachments" button, if it fails for you reply there: https://www.badcaps.net/forum/genera...e2#post3664713
                                  Admin is following that thread
                                  • bogart219
                                    • May 2009
                                    • 200
                                    • usa
                                    #157
                                    Will do. Clarification: When you want me to measure resistance, this is with no power connected to the board right?
                                    When you want me to measure voltages, is this with just the charger plugged in, with the charger and the battery plugged in or just the battery?
                                    I want the info I give you to be as accurate as I can
                                    • m1ch43lzm
                                      • Mar 2019
                                      • 757
                                      • Peru
                                      #158
                                      ⚠️ Warning, don't remove the MOSFETs or the IC yet, if you remove the low side MOSFET PQ6201 or the IC and apply power afterwards you will likely damage everything, as doing it will feed battery voltage to the 3v/5v lines
                                      On a buck converter circuit, all components should be present before attempting to power on
                                      I forgot to mention this, sorry
                                      • bogart219
                                        • May 2009
                                        • 200
                                        • usa
                                        #159
                                        Here are the resistance values you requested. The voltage values to follow After your directions from post Odd power issue related to bad caps? above.
                                        PQ6204 - S-D .7 MEG S-G 6 OHMS D-G .5MEG PQ6201 - S-D OL S-G 4MEG D-G OL
                                        D1-SID2 - 2.2 MEG S1D2 - G1 3.2 MEG S2-SID2 8MEG S2-G2 1.6MEG S1D2 -G2 3MEG
                                        PR6209,6211,6210 &6215, ALL WITH IN SPECS!
                                        • m1ch43lzm
                                          • Mar 2019
                                          • 757
                                          • Peru
                                          #160
                                          That's bad if the resistance measurement is correct
                                          Click image for larger version  Name:	gate source.jpg Views:	0 Size:	200.0 KB ID:	3665844
                                          PQ6204 is the high side MOSFET, if it's shorted S-G hopefully the RT6585 detected the fault, that's why the 3.3V and 5V supplies don't work
                                          You can remove PQ6204 and measure it outside the board to confirm, set the hot air to 450-460 C
                                          With the MOSFET removed measure again S-G pads on the board, resistance should be higher
                                          If the MOSFET is shorted S-G outside the board, it's definitely faulty
                                          Always measure resistance without power applied, don't connect the battery/charger until the MOSFET is replaced with an appropriate one
                                          Charger won't work anyway as the TPS65994 is missing from the board
                                            Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:20 AM
                                            Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
