2 x MacBook Air A2337 820-02016 both working but no usb, no charging, shorts CD3217. 5.10v 0.2A draw.
  • Emile Elfferich
    • Nov 2024
    • 4
    • België
    Used same charging cable. First A stopped recognizing my iPhone, then it stopped charging.
    Please advise.
Name:	Scherm­afbeelding 2025-04-26 om 18.58.15.png
  • mon2
    • Dec 2019
    • 14575
    For the PD controllers @ UF400 & UF500, confirm the voltage to ground of:
    PP3V3_UPC0_LDO
    PP3V3_UPC1_LDO
    • Emile Elfferich
      • Nov 2024
      • 4
      • België
      Thanks for your quick reply.
      Enclosed confirmation voltages to ground.
      + same with other (yellow) multimeter.
Name:	Scherm­afbeelding 2025-04-27 om 15.13.34.png
      • mon2
        • Dec 2019
        • 14575
        On your Unit A - remove all power; measure the resistance to ground of PPBUS_AONSW_IPD. This is the power rail (after the load switch / e-Fuse @ UC850) that powers the trackpad. If this resistance is low, then disconnect the trackpad and test the resistance again. It is possible that UC850 is defective from some transient linked to the trackpad and this is forcing the upstream power rail PPBUS_AON to sink.
        • Emile Elfferich
          • Nov 2024
          • 4
          • België
          PPBUS_AONSW_IPD = 4.62Ω at LT400 (1). Could not find spot on DC850 to put pin.
          All 3 logic-boards are out out of the case, only USB ports connected.
          • Adogabriel100
            where to get trusted CD3217. Problem with A2337 Macbook Air
            by Adogabriel100
            Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
            The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
            09-06-2024, 12:06 PM
          • TechSplendid
            MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
            by TechSplendid
            Hi All,
            I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
            Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
            04-09-2025, 02:13 AM
          • duwane
            MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
            by duwane
            Hi All.
            I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
            Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
            After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
            Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
            10-17-2023, 07:48 PM
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            🛠 Original Issue
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • soeren
            A2337 - Camara doesn't work
            by soeren
            I have replaced the display on my A2337 and I believe that during the change the battery connector was re-connected to the logic board and therefore I now have a non-working camera in my A2337 laptop.
            After the problem occurred, the camera was no longer detected and True Tone didn't work. I replaced the eDP flex cable (display connector) and now the camera is detected and True Tone works again.
            The problem is that when I open Facetime, for example, the green camera LED does not light up and the camera image remains black. In the end I get an error message. Does anyone...
            08-23-2024, 09:02 AM
