Find IC Number in HP 15-eu0017nf
  • jeewantha
    • Nov 2016
    • 88
    • Sri Lanka
    I want to find numbers of 3v & 5v ICs in this laptop
    Model No - HP 15-eu0017nf
    Board image & IC images are attached.
  • Sephir0th
    • Oct 2020
    • 1289
    For parts identification we need at the very least to know what is written on them, the "code".
    FairRepair on YouTube
    • sikocan
      Lenovo X1 Carbon 9th Gen Black Screen
      by sikocan
      I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
      SN: PF3G1REP
      MODEL: 20KW-00J1AU
      PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
      Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
      06-24-2025, 09:01 PM
    • piernov
      Beginner's guidelines
      by piernov
      You have a laptop that does not power on, powers on but shows no image, crashes, etc… You want to fix it but you don't know where to start.
      There are 2 situations:
      1. You just want your laptop fixed
      2. You want to learn about fixing laptops
      Sorry, but if you're in situation number 1, we recommend you to use the services of a trustworthy professional repair shop.
      Unfortunately, if you're not serious about learning, you will waste your time and money, and you will make us waste our time as well.
      If you are in situation number 2, then please continue and...
      09-20-2020, 09:46 AM
    • Gentian
      Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
      by Gentian
      I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
      09-27-2025, 11:03 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • tofuSCHNITZEL
      Fujitsu Lifebook E547 vPro
      by tofuSCHNITZEL
      I have a Fujitsu Lifebook E547 vPro that does not boot anymore after Windows Update tried to install a new Bios version. Screen stays black no post - only the numblock light blinks.
      What I've tried:
      I have used my CH341A to read the bios chip (25Q128FVSQ) (Dump attached) - I think the dump is "good" because I could find the Serial number in the data and also the Winkeyfinder found a windows key.
      for the lack of any other Idea I took the bios from this post (https://www.badcaps.net/forum/troubl.../troubleshooti...
      10-15-2025, 04:26 PM
