HP 455 G7 no display on battery
  • ghedada.06
    • Feb 2023
    • 19
    • Algeria
    Hi, i have HP 455 G7 came in for no display
    laptop model: HP 455 G7
    motherboard model: da0x9mmb8f0 REV: F
    this laptop turns on fine on charger, but when attempting to power it on battery (with charger unplugged) it shows no display with fan turning max speed. I did some measurements and i noticed that cpu voltages are missing on battery, after digging deeper in measuring i noticed that 1.8v is missing on pin #9 (APU_PG)
    ​i don’t know how can i trace this issue further, any help will be appreciated and thank you in advance
  • fix122
    • Apr 2025
    • china
    There is an inductor PL9301 providing 1.8V next to the memory slot
    • ghedada.06
      • Feb 2023
      • 19
      • Algeria
      It has 1.8v, i can measure 1.8v on APU_RST# also which is also connected to +1.8v_DEEP_SUS
      • ghedada.06
        • Feb 2023
        • 19
        • Algeria
        You can see it here
          NVDC charger configuration...
          11-05-2024, 03:28 PM
          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
          Narrow VDC applications where the system power source is
          either the battery pack or the regulated output of the charger.
          This makes the max voltage to the system equal to the max
          battery voltage instead of the max adapter voltage. Operating
          at lower system voltage can improve...
          11-05-2024, 04:43 PM
        • flat-earther
          how to prevent a connected charger from draining battery when not charging?
          by flat-earther
          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
          So the battery is backfeeding the charger and being drained.
          How can I prevent...
          08-07-2025, 01:04 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
          Bauer tool battery pack charging with a HERCULES charger modification
          The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
          Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
          05-06-2023, 12:17 PM
