Aspire 5730Z
  • senchire
    • Dec 2012
    • 190
    • Bosnia
    Aspire 5730Z
    Hello folks, I've been doing repairs on this laptop. And decided to exchange upper plastics for new (touchpad,left buttons etc). After replacing that upper piece of housing my touchpad along with my mouse buttons stopped working.
    I've put bad the old one and it still isn't working .
    Its enabled trough FN+F7 and it isn't recognised trough device manager.
    So now this laptop works only trough USB mouse devices, also measured all voltages on the connectors and they have they 5V's.
    The connectors are cleaned and let voltages from the MB to the touchpad.
    I am now clueless what to do next.
    I also tested both touchpads on my other laptop (extensa 5620) and they work perfectly fine there.
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: Aspire 5730Z
    @senchire
    check Touchpad flex cable continuity with multimeter.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Re: Aspire 5730Z
      Windows XP? have you tried the install hardware route
      Obviously make sure it plugged in -bent/broken pins etc
      • senchire
        • Dec 2012
        • 190
        • Bosnia
        Re: Aspire 5730Z
        Thanks guys for fast response.
        @dspok yes flex cable was tested with multimeter works fine, also the flex was tested in my extensa and works normally as they are identical built.
        @selldoor Windows 7 and Hirens on these 2 I have tested it.
        Yes its plugged in, and tried 3 different flex cables which all work in my Extensa 5620 (its the same flex cable for touchpad).
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Re: Aspire 5730Z
          I've been doing repairs on this laptop ?????????
          repairs to what
          • senchire
            • Dec 2012
            • 190
            • Bosnia
            Re: Aspire 5730Z
            Exchanged HDD, reinstalled Windows. That would be it, of course along with replacing the upper case of the laptop.
            I had to test it again these freaking touch pads and they work perfectly fine on my Extensa, after swapped them back to Aspire and none works again tried trough Hirens and Windows 7, in Device manager they aren't detected indicating that something is faulty on the MB side.
            Bios offers nothing regarding the touch pad.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              Re: Aspire 5730Z
              maybe as well as windows you need drivers from acer to be installed?
              Some dells have to have specific dell drivers.
              Latest bios installed?
              perhaps the windows vista one from here
              http://www.helpjet.net/getfile/Acer-...e8a0f19de.html
              virus check before using !!
              • senchire
                • Dec 2012
                • 190
                • Bosnia
                Re: Aspire 5730Z
                Ok after putting new HDD I freshly installed windows 7 without any drivers, and it worked. Note that this happened before touchpad exchange.
                I used before this problem also Hirens over usb and it worked.
                But since i changed thetouchpad nothing works. I installed drivers but they are useless since my hardware isn't detected. I am running out of options to be honest.
                • senchire
                  • Dec 2012
                  • 190
                  • Bosnia
                  Re: Aspire 5730Z
                  Well sad news regarding this laptop. Now my keyboard works only when choosing which OS will i start, or at safe mode etc (also works when i wake up my laptop from sleep), getting into BIOS or any kind of System it stops working and what really interesting is the Southbridge is freaking hot.
                  • whaldsz
                    • Apr 2013
                    • 395
                    • Philippines
                    Re: Aspire 5730Z
                    Try to reflow your KBC chip first (U39 ENE3310). Or better replace it.
                    • senchire
                      • Dec 2012
                      • 190
                      • Bosnia
                      Re: Aspire 5730Z
                      I'll try it today, looking the schematics it indeed controls the voltage output to the slots. But it also "drives" my buttons (wifi on, volume up/down) and caps lights which work all the time perfectly.
                      Did testing on my motherboard so if my touch pad isn't connected on
                      TP_DATA and TP_CLICK I get 5V (according to schematics its fine)
                      If I connect my touch pad I get 0.96V on these 2.
                      Also the laptop starts as soon as I plug in my DC (if my batter is in and it won't). So in theory when he gets voltage he does this. Also the PWRBTTN is powered by the KBC chip (which get the power from the Intel ICH9M chip).
                      • senchire
                        • Dec 2012
                        • 190
                        • Bosnia
                        Re: Aspire 5730Z
                        Recently I said my keyboard isn't working well its not working when I plug in my Touch pad if its out it works all the time. If I plug in not.
                        • senchire
                          • Dec 2012
                          • 190
                          • Bosnia
                          Re: Aspire 5730Z
                          I think this will be the final update. So I was a bit curious and measured all voltages on mc KBC chip guess what they are fine. After as previously stated the touchpad blocked my keyboard (that was a bit fishy) but what totally fishy is I plugged an older touch pad (from previous acer) and it transmitted the right votages to the LEFT and RIGHT buttons (namely 1V) and it didn't blocked my keyboard (ofc its not supported by the board so not working).
                          All in all I'll order a new one (costs me 10$ touch pad but this time a "new" not used). And I'll report to you folks back.
                          • senchire
                            • Dec 2012
                            • 190
                            • Bosnia
                            Re: Aspire 5730Z
                            Here is an update, so a new touchpad (brand new one) solved the issue.
                            Fact is the old one works in another laptop. So if someone encounters this just change it (with a brand new on even if the old one works).
                            Lock it .
                              ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              09-12-2024, 03:36 PM
                              ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-12-2024, 03:30 PM
                              ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              ACER Aspire Aspire X1700 + X223WB Aspire E5300 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire X1700 + X223WB can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1700 + X223WB boardview and Aspire Aspire X1700 + X223WB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-12-2024, 03:28 PM
                              ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
