Dell XPS 13 9370 unknown USB devices in device manager
  • Stachujones
    • Jul 2023
    • 19
    • Poland
    Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
    Device manager says "unknown device, failed to request device descriptor"
    Can somebody point me in right direction what to check?
    I updated bios to the newest version and thunderbolt controller firmware still no luck
  • mon2
    • Dec 2019
    • 14551
    To save time, always share details of the logic board markings so we can track down (if one exists) the schematics.
    See attached. Believe you have the 'LA-E67' motherboard?
    The fingerprint reader is interfaced through a USB 2.0 port which is protected by local TVS ESD devices. It is very possible that a transient has taken out these TVS diodes and is now causing communication faults.
    Remove all power. Meter in diode mode. Red meter probe, yes red to ground. Black meter probe to the point to test. Test each of the USB 2.0 lines used by this fingerprint scanner so test D+ and then D- lines.
    Post each measurement which are in volts. If the voltage measurement is too low or close to zero then the TVS diode has triggered and must be removed and/or replaced. Respectively, a shorted TVS ESD diode will raise the observed errors.
    Click image for larger version  Name:	fingerprint.png Views:	0 Size:	31.2 KB ID:	3608360
    • Stachujones
      • Jul 2023
      • 19
      • Poland
      In diode mode it has 0.495v
      If i identified correctly it should be this component?
      • mon2
        • Dec 2019
        • 14551
        Red to ground (not the point to test) when using DIODE mode. Repeat testing.
        • mon2
          • Dec 2019
          • 14551
          See attached. Post a pic of this region. It is possible that the vendor has not even stuffed this part (to save the pennies to build this board) in which case, the port was never protected against ESD transients. It is a common trick used by the cheap manufacturers.
          • Stachujones
            • Jul 2023
            • 19
            • Poland
            Yeah i done that, Red was on ground while i messured, on this photo Red was just to point at component 😉
            • Stachujones
              • Jul 2023
              • 19
              • Poland
              Here's the photo
              • Stachujones
                • Jul 2023
                • 19
                • Poland
                Made a better one
                • mon2
                  • Dec 2019
                  • 14551
                  Well noted. The diode mode readings are the same as posted for each of the 2 pins on D20 mated with D+ and D-? If yes, the USB lines are not shorted.
                  • Stachujones
                    • Jul 2023
                    • 19
                    • Poland
                    Yes there are the same, is there any things to check? Is bluetooth related to this?
                    • Stachujones
                      • Jul 2023
                      • 19
                      • Poland
                      I founded something strange all of the legs of this component are shorted to ground (dead short 0,0ohm)
                      • mon2
                        • Dec 2019
                        • 14551
                        Flux and carefully remove D20. Protect the nearby plastic parts like the fingerprint cable and connector - otherwise it will melt and warp. Use aluminum foil or similar to protect the plastic part(s) from the hot air nozzle. Point the hot air nozzle in such an angle to avoid melting the delicate parts.
                        If D20 is truly showing the low diode mode readings, then most likely this D20 is shorted and causing the fingerprint sensor from working.
                        • Stachujones
                          • Jul 2023
                          • 19
                          • Poland
                          i founded that with thingerprint reader unplugged there is no short on d20 so maybe just the thingerprint reader is bad, But still there is issue with bluetooth bios says "bluetooth none" i read on internet that bluetooth is in the same chip as wifi but wifi is working fine so what i should check?
                            DELL XPS 9370 Notebook 13 Specification for Upgrade or Repair
                            This specification for the DELL XPS 9370 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9370 boardview and 9370 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9370 Notebook...
                            09-06-2024, 08:01 AM
                            09-06-2024, 07:11 AM
