A1465 820-3435-B, Fast Fan, CPU HOT 71°C
  • thuygsm
    Nguyen Van Thuy
    • Jan 2023
    • 17
    • vietnam
    Hello everyone. I am a new member and hope to get some help.
    I received from a customer a macbook A1465 820-3435-B that fell in lemon juice.
    After cleaning, I found that PP3v42 was lost and I replaced it with D7012. As a result, the machine ran stably.
    I plugged it in overnight and it just got hot, the fan spun fast and constantly. It was stuck at 0.582A, no display, no startup chime, no capslock led.
    PPBUS_G3H =8.16V
    PPBUS_S5_HS_COMPUTING_ISNS =8.17V
    PPBUS_S5_HS_OTHER_ISNS =8.15V =16.21V
    PP3V42_G3H =3.44V
    PPVRTC_G3H =3.3V
    PP5V_S5 =5.01V
    What should i do, THANNK YOU
  • mon2
    • 14659
    https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
    • thuygsm
      Nguyen Van Thuy
      • Jan 2023
      • 17
      • vietnam
      I found a small crack in the U5000, I replaced it, and the machine turned on, thanks for the help
      • mon2
        • 14659
        Nice!!
        • cook
          HP Power Supply 6632A: Fast Mode vs Normal Mode?
          by cook
          FAST MODE vs NORMAL MODE
          I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
          I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
          06-07-2020, 05:32 AM
        • SevenOFF
          Denon AVR-X4000 – Fast red blinking after 2nd relay
          by SevenOFF
          I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
          According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
          Here’s what I’ve done so far:
          • Fully opened and cleaned the unit (a lot of dust inside)
          • Removed and visually inspected the AMP board → nothing visibly damaged or burned
          • Testing is done with
          06-18-2025, 09:54 PM
          TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
          FF Series (Very Fast Acting), 0603 Size
          Features
          ● Very fast acting at 200% overload current levels
          ● Low DCR
          ● High inrush current withstanding capability
          ● Fiberglass enforced epoxy fuse body
          ● Copper termination with nickel and tin plating
          ● Halogen free, RoHS compliance and lead-free
          Applications
          ● Notebook computers and tablets
          ● Digital cameras
          ● Memory cards
          ● Toys
          ● Bluetooth earphones
          ● Portable electronic devices​...
          10-07-2024, 05:50 AM
        • paparazzo79
          fast charging vs normal charging cellphone,damaging battery?
          by paparazzo79
          Hi friends.
          I see there are many clever people here.
          I purchased used Note 10 plus phone,and it doesn't have good battery cuz it's been used probably more then a year.
          Since I'm not an expert into phones but my own thought is that fast charging with high current wears out battery more quickly and damages cells compared to regular charging.
          I don't need fast charging at all so I disabled that option in phone,since I don't care if my phone will charge 1h or 2.5 h (with regular charging).
          But want to ask does fast charging damage the battery cells as time passes...
          05-16-2021, 03:27 AM
        • Caimano
          hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
          by Caimano
          MB G7AD-2G DAG7ADMB8D0 REV D
          Processor i5 8265U
          AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
          Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
          Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
          02-06-2024, 10:14 AM
