dell 15341 no power
  • doctormasry
    • 108
    • giza
    dell 15341 no power
    hi friends
    i va laptop dell 15341
    motherboard id : vegas/turis skl/kbl 15341-1
    the proplem no power
    no 3.3 v on bios or pin 1 press power
    i check pu4503
    pin 12 = 19v vin
    pin 3 = 3.3 v vreg3
    pin 13 = 5v vreg 5
    pin 7 = 0v pgood
    pin 20 = 0v en1
    pin 6 = 0v en2
    i check kbc24
    no volt on all vcc pin
    i changed pu4503 put same measure no new
    any idea
  • mon2
    • 14666
    What is the voltage to ground of RTC_AUX_S5 @ Vbat pin 122 on KBC24 (EC)? This pin should be ~3v since the source of this voltage is 3D3V_AUX_S5 <- 3D3V_PWR_2 = VREG3 (pin 3 on PU4503).
    Remove all power. Meter in resistance mode.
    Measure the resistance to ground of:
    3D3V_PWR ; @ PL4502
    5V_PWR ; @ PL4501
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      ACAV_IN present on pin 128 of SIO?
      • doctormasry
        • 108
        • giza
        thanks mcplslg123
        ACAV_IN = 3.3V
        • doctormasry
          • 108
          • giza
          3D3V_PWR ; @ PL4502
          5V_PWR ; @ PL4501
          thanks mon2
          VBATT PIN 122 = 0 VOLT AND ITS SHORT
          VREG3 (pin 3 on PU4503). = 3.3V
          PL4501 = SHORT
          PL4502 = 850 oh​
          • mon2
            • 14666
            Remove all power. Meter in resistance mode. What is the exact resistance to ground of PL4501? Being 5v, this issue may very well be linked to a defective USB loadswitch since the USB ports use 5v for VBUS.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • Mark01
              Dell Optiplex 7490 AIO - red power led after flash
              by Mark01
              Hi guys,
              This is my first post! 🚀
              I have no idea what I’m doing, but I’m learning by trial and error.
              I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
              07-04-2025, 12:54 PM
            • zlr8r
              Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
              by zlr8r
              hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
              Ill try and give as much info as I can.
              Dell Inspiron 17 (7786) Laptop
              Service Tag: 5J0NHT2
              Bios: 1.9.0
              When I received this , it would only flicker on the KB backlight for a second, then off and on.
              Then it started getting weirder!
              Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
              12-12-2023, 09:31 PM
            • LimesKey
              Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
              by LimesKey
              Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
              10-17-2025, 05:33 PM
