MacBook Pro 14" M1 Pro Battery related question.
This topic has been answered.
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Voltage is 0 volts on L5230 on both points
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
    • mon2
      • 14713
      Review the resistance across this DUAL mosfet @ Q5230.
      So test the resistance between:
      pin 1 of Q5230 = C5213 & L5230 (source / drain)
      etc.
      If you are comfortable with the idea, consider to flux and replace this dual mosfet. Assuming that U5200 is not defective, this inductor @ L5230 should show some voltage. This voltage then will pass onto Q5240 and finally to create PPBUS_AON.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        etc.
        Question though, if the U5200 is not working wouldn't the board not turn on at all? Unless these boards are a little different, I would assume that U5200 could be the issue but the mosfet Q5230 was recently replaced as I assumed this was the issue but it still persisted, now what's weird is the misfit Q5240 is getting less voltage on PPDCIN_AON_CHGR_R that area is 3 volts and dropping but Q5230 has a consistent 5volts and not dropping.
        sigpic
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 674
          etc.
          I am getting 24k ohms on pin 1
          sigpic
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            I went ahead and replaced U5200 out of curiosity with the exact ISL9240HIB3 chip and same issue is around so U5200 is not the issue at this time...
            sigpic
            • mon2
              • 14713
              That is a very low resistance for a mosfet. Suggest to flux & replace Q5230. As a comparison, check the same resistance of the replacement dual mosfet while it is out of circuit.
              Update:
              U5200 is probably ok but suspects are the 2 dual mosfets above linked to U5200.
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 674
                I remember replacing these but yet it still didn't solve the issue with a donor board, I will look for a donor that turns on and see if that solves the issue.
                sigpic
                • Stephen
                  Meow Meow MEOW!
                  • Apr 2020
                  • 674
                  replaced and issue is still persisting. I thought it was these as well but they were replaced from donor boards that work and it still doesn't fix this issue. I also replaced U5200 and that didn't solve the issue so I am still stuck on 0amps 5volts
                  sigpic
                  • Stephen
                    Meow Meow MEOW!
                    • Apr 2020
                    • 674
                    I believe L5230 is bad since it looks kind of weird and blown...
                    sigpic
                    • mon2
                      • 14713
                      You have replaced both, Q5230 and Q5240?
                      What is the voltage to ground of the following?
                      PP1V8_S2
                      CHGR_AUX_DET
                      PPVBAT_AON
                      You have a charged battery attached to the laptop?
                      Update - replace L5230 if it is a suspect. The part is required.
                      • Stephen
                        Meow Meow MEOW!
                        • Apr 2020
                        • 674
                        PP1V8_S2
                        CHGR_AUX_DET
                        PPVBAT_AON
                        Replaced L5230 nothing happened HOWEVER it was deformed and burnt and looked bad. I replaced it nothing fixed yet. I will read off other readings now...
                        PP1v8_S2 0 Volts
                        CHGR_AUX_DET 0 Volts
                        PPVBAT_AON 1.1volts and dropping
                        sigpic
                        • Stephen
                          Meow Meow MEOW!
                          • Apr 2020
                          • 674
                          no battery is not connected. It will turn on with battery connected.
                          sigpic
                          • Stephen
                            Meow Meow MEOW!
                            • Apr 2020
                            • 674
                            OMG the board just turned on......WTF its at 20volts...AND NOW its back at 5volts...
                            sigpic
                            • mon2
                              • 14713
                              PP1v8_S2 0 Volts
                              Both are incorrect values and need to be non-zero. Test the resistance to ground of PP1v8_S2.
                              Measure the voltage to ground of R5215 (both legs). Is this resistor missing or defective?
                              TCRS noted that some boards need a good battery to power on - this may be one of them.
                              • Stephen
                                Meow Meow MEOW!
                                • Apr 2020
                                • 674
                                Voltage Present on Pin 1 on R5215 No voltage present on Pin 2 which is CHGR AUX
                                Resistance to groundd on (PP1v8_S2) is 1.5k OHMS
                                sigpic
                                • Stephen
                                  Meow Meow MEOW!
                                  • Apr 2020
                                  • 674
                                  ok update I am getting 20volts and charing and not getting 0 amps anymore on the board with it connected to the battery! WOOHOO! Thanks MON2 you saved me and this customers computer. I will buy you a drink one day.
                                  sigpic
                                  • Stephen
                                    Meow Meow MEOW!
                                    • Apr 2020
                                    • 674
                                    Great one thing after another on this board...
                                    so now guess what is at 190 degrees?! U8100 20volts is finally showing up at the board but now that area is super hot. Like its one thing after another lol
                                    Also the CPU is getting hot as well, all shorts were removed and now that chip wants to act up. I am so done with this board lol
                                    sigpic
                                    • mon2
                                      • 14713
                                      Test the resistance of R5215.
                                      CPU will be hot when it is working. The CPU (regardless of make / brand) are current sucking pigs. Kind of like the salt eating pigs on (original) Star Trek except they would turn into mega babes (Nancy?) after eating the salt. The mega babes may have high blood pressure but were hot enough to be pursued by Captain Kirk (only).
                                      Well here, the Apple or whatever crapware CPU is onboard, will heat up if without a heatsink. Is the board lifeless now?
                                      • Stephen
                                        Meow Meow MEOW!
                                        • Apr 2020
                                        • 674
                                        I am getting 20volts and 1 amp on the charger, now no image, CPU is getting hot and all the Power IC chips are hot. I am like wait this was not like this before :/ I am taking a break from this computer.
                                        sigpic
                                        • Stephen
                                          Meow Meow MEOW!
                                          • Apr 2020
                                          • 674
                                          Board is not turning on, lifeless now. Crapware as always :/
                                          MagSafe 3 cable is blinking orange every half second when connected to another computer to try to see if it is in recovery or DFU. Nothing
                                          sigpic
                                          • techfreak9356
                                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                            by techfreak9356
                                            09-14-2023, 11:10 PM
                                          • ruletero
                                            Acer a515-43 low battery charge voltage
                                            by ruletero
                                            Hi
                                            Acer A515-43
                                            LA-H801P
                                            Fail: Does not charge battery, has low voltaje on connector.
                                            Laptop didn't want to turn on, only charge led blinked.
                                            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                            10-24-2022, 02:31 PM
                                          • ACS-Repair
                                            MacBook Air 2014 battery will not charge
                                            by ACS-Repair
                                            Hello All,
                                            I have a unusual problem with a MacBook Air 2014 820-3437 that it will not charge the battery. I have 2 batteries that charge just fine in another 820-3437 so i assume that the batteries themselves are OK. One was new in 2020.
                                            This board started off as a PP3v3_S5 short that was resolved (shorted capacitor) and came to life fine. While testing the computer I noticed that the battery was not charging so I checked the following components:
                                            Current sensing:
                                            R7121 10 ohm
                                            R7122 10 ohm
                                            R7151 2.2 ohm
                                            R7152 0 ohm
                                            06-15-2023, 11:15 AM
                                          • Juan Carlos Medina Franca
                                            Macbook air m1 does not charge the battery
                                            by Juan Carlos Medina Franca
                                            Hello, I have a MacBook Air M1 that got water on it and now the computer does not charge the battery. The USB C port does work since I can connect the computer to HDMI for example. The battery also works well since if I connect a motherboard from another MacBook Air M1, the battery charges.
                                            Anyone know what can it be?​
                                            06-18-2024, 11:28 AM
                                          • awe126
                                            Macbook Pro 16" A2485, 820-02100, battery service recommended, fan full speed, doens't charge
                                            by awe126
                                            Hello all,
                                            I bought a Macbook Pro 16" M1 Pro, A2485, 820-02100, which working flawlessly but not charging. I thought battery needs to be replaced but then started reading and it seems that problem will be in motherboard.
                                            Battery sign has cross sign and MacOS can't read battery stats. Fans are full speed but can be set down via Fancontrol software.
                                            I did start digging into in and found out below:
                                            Diode mode:
                                            SMBUS_BATT_SCL: 0.529
                                            SMBUS_BATT_SDA: 0
                                            SMBUS_BATT_SCL: 1.795V
                                            SMBUS_BATT_SDA: 0.948V
                                            Can anyone help...
                                            03-27-2025, 12:23 PM
