aspire5742zg .ask for shutdown and it just restart.
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    well this machien is kind akward , on windows cheked everything on power management a also acpi drivers , all are ok . even after new windows install .
    when i press the on off button (insyde windows) or press the shutdown on the start menu , it sas shutding down , but the machine never shutdown , it simply restart !
    so cheked both bios KBC and system , flashed both , same problem , ok so replaced KB (i got a lot in stock) well the same , cheked the mains power controlers , system charger and step controler all seems fine as well .. so im kind curious what is making this happen !
    an sugestion will be welcome.
    cheers
  • dj_ricoh
    • 2073
    • uk
    Re: aspire5742zg .ask for shutdown and it just restart.
    the guy who shows me stuff in this department told me one thing that i follow it.
    Never mess with a notebook that is working over 90%.
    if you wanna use it and does NOT: dim the screen-leave it,does not charge the bat?-leave it, any small stuff that does not influence the performance of the notebook just leave it man; you will only find more trouble.
    think like this: what happens if tomorrow does NOT power anymore?
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      well its a good point of view , but this is why we are technicians , we stud for something and we work for something , at least i speak for myself , i try everything to find out the solution , of course going in small steps to avoid damage something , but this is something weird , im here reading this schematic and cheking for the shutdown and suspend process to see were they pass , and what controle them , and were they pass thru , so its a hard job , but i love to dig around the schematic and understanding each time more what are the causes for stupid anormalities , just like this one .
      i would not touch it , but my client is warned about this issue , and he want us to find a solution , so im here for it !
      • vvacl
        • Jun 2012
        • 22
        • VietNam
        Try by removing the lan controller
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          good taught , i was thinking about this wake up lan process , good i refreshed and noticed you thinked the same . for such coincidence it will work :P
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            well a diferent action occured , now it shutdown even the leds , but turned on 2 second later
            its a move . soemthing else making the computer to turn on
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              nop it have done this only once , making exact the same!
              • atsio
                • Oct 2013
                • 819
                • Greece
                Check the power button
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  Also check RTC circuit
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    You may be getting a BSOD on logout, so Windows reboots instead of shutting down.
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                      • 31094
                      so if you remove the battery,
                      and power it up by plugging in the charger does it turn on?
                      if it does, unplug the panel with the power button and leds and try again.
                      these aspires can be a pain!
                      • loser18
                        • Nov 2013
                        • 274
                        Wow...never seen this before (except soft issue)...looks like the mobo sets itslefs from S5 to another state...i doubt it will be a power button or pwr board as if it's continouesly sending signal to SIO/KBC it would hibernate or sleeps after logon...rtc is a good idea, but depends on architecture...could you post schematics???
                        • atsio
                          • Oct 2013
                          • 819
                          • Greece
                          When I say, power button, I mean (and I think is obvious) the circuitry of the power button. Also remove hdd and check if laptop restarts when you press the power button.
                          I suppose, this is the schematic https://cdn.badcaps-static.com/pdfs/...451ed125d1.pdf
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1488
                            • portugal
                            im very carefull reading schematic and like i mentioned , all does test were carried forward , and nothing was showing anormalitys , cheked components for all circuit from to turning on , to all states envolved , making serious test , made me arrive to the BD intel chipset . since the power management section of the chip , is responsable for action as turning on and off the machine , replaced intel BD and its working
                            so i guess will be a good tip for the next one with similar problems
                            for my experience , i had a lot of issues in computeres with this chip . even not having image on a internal display and just on external , and was a fault with the VID part of the BD . so this chip's are really SH$% .
                            SOLVED , well at least on hirens it shuting dowm properly , let see in windows now . later i will give final feedback ..
                            thk guys
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              officialy SOLVED
                              • Caimano
                                Asus PU551LA cannot restart after shutdown
                                by Caimano
                                Motherboard PU551LA Ver 2 with Intel i5 4210U
                                I bought the motherboard as faulty to replace a similar one not repairable because it was completely shorted.
                                3V EC was shorted to ground because of EC chip. IT8585E FXA replaced with IT8585E FXS. Motherboard now works and I am able to recharge the battery, install Windows and update BIOS from Ver 207 to 210 with EZ Flash, but it has the following problem: Every time I power off the laptop with power switch or with Windows shutdown the laptop apparently turns off, but the power LED remains on and it's not possible to restart the laptop....
                                05-13-2023, 03:38 PM
                              • SuperJames
                                Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                by SuperJames
                                This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                Specs
                                i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                Backstory
                                I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                10-23-2023, 04:09 PM
                              • kingskie
                                macbook pro A1989 restart when sleep and A1707 restart when shutdown
                                by kingskie
                                Hello all,
                                I got macbook pro A1989 that has sleep wake failure..always restart when put in sleep mode or close the lid..if i shut down and close the lid there would be no problem at all.. already reinstall the mac os but still has the same problem even restore with DFU mode.
                                and for macbook pro A1707, this one always restart when i try to shut down..always restart when put in sleep mode.
                                can anyone help me? @piernov, @mon2 ?
                                thanks before
                                09-18-2021, 08:11 PM
                              • shouri
                                Dell latitude e5490 auto restart
                                by shouri
                                Hi guys, can someone help me?
                                I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                                Board model is dm70 la-f401p rev:1.0 2017-09-20.
                                At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                                After a few days test, is seems ok.
                                Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                                12-10-2024, 09:27 PM
                              • kacangpolo
                                Asus X415EA Auto start when shutdown ( Laptop cannot shutdown with baterai only )
                                by kacangpolo
                                I have problem with my laptop, with code board X415EA 2.0,
                                laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
                                I did :
                                1. Flash Bios
                                2. RTC_RST 3.3V
                                3. LID_SW 3.3V
                                4. WLAN_WAKE# 3.3V
                                08-26-2025, 04:42 AM
