Quality Replacement AC adapters. Are there any left?
  • JJR
    • Mar 2013
    • 171
    Re: Quality Replacement AC adapters. Are there any left?
    Originally posted by goodpsusearch
    I have bought LCD screens & laptop keyboards (but not adapters) from this seller with no problems.
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      http://www.ebay.com/itm/251142258304...84.m1497.l2649
      • bammbammfran
        • Apr 2014
        • 476
        re: http://www.ebay.com/itm/251142258304...84.m1497.l2649
        IF the seller says that the item is exactly what is pictured then this one should be good to go.
        If I had to chose I would go with this one
        On your other link, I do not know for sure
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Did you take the old adapter apart? It most likely still works, it seems the HP connectors/wire that goes to the computer shorts out, and the SMPS won't turn on because of that. I've encountered tons of them that have done this, granted, they are the 65W ones though. If you replace the wire and/or connector, you might be able to get some more life out of that old adapter.
          Muh-soggy-knee
          • bammbammfran
            • Apr 2014
            • 476
            The problem on these is usually in the plug that goes into the laptop or just outside of the rubber shield that is supposed to absorb flexing
            Either a wire cracks in half or the solder pops loose right off of the connectors barrel
            • mockingbird
              • Dec 2008
              • 5484
              #26
              No, those adapters you listed are not necessarily real. Let me elaborate:
              They have large quantities of these adapters. Did they themselves buy them from China? If so, they're probably counterfeits. Very good counterfeits.
              The closest thing to a surefire way of obtaining a genuine adapter is to look for a pi]used[/i] adapter. That way you know that it came together with a laptop, and perhaps the laptop was discarded, but the adapter is still good. Be careful with used adapters when the seller describes it thusly "I bought this as a replacement, but didn't end up needing it." In this case, you can't be sure whetehr he cought a counterfeit replacement himself.
              Yea, as was mentioned, if you have a good adapter, but the tip is frayed, you can purchase new wires and then hook them up.
              • linuxguru
                • Apr 2005
                • 1564
                #27
                It's also worth replacing the secondary electrolytics in a counterfeit adapter with durable Japanese electrolytics. Most of these are flybacks with durable 600V MOSFET switches, and they can run for years with good electrolytics. I use Rubycon ZLH or ZLG, but there are lots of choices available.
                • dj_ricoh
                  • 2073
                  • uk
                  #28
                  that`s fake!
                  even the plastic shows that its crappy
                  that`s not a original HP sticker
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    #29
                    The charger arrived and seems original. I tested it and the laptop works but the adapter gets hot during charging or high cpu usage.
                    • mockingbird
                      • Dec 2008
                      • 5484
                      #30
                      That's because what you got is probably fake...
                      You didn't get the gist of what I was attempting to convey to you - which is that "New" adapters, regardless of where they come from, are usually Chinese fakes. A giveaway is a seller who has a large quantity of them (Like the seller you purchased from), the exception being sellers who sell lots of them in a single listing (And then they are usually used). Again, it's irelevant that you bought it from Europe. He's probably just a European seller re-selling fake Chinese products.
                      Crack it open and post pics. Let it be an expensive lesson to you.
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        #31
                        The owner of the laptop said that the original adapter that came with the laptop got hot too.
                        I have a better idea, but you have to wait a couple of days.
                        • spleenharvester
                          • Mar 2010
                          • 902
                          Out of curiosity why don't people try used genuine adapters? No crappy chinese fakes that way, a lot cheaper, and I've never had a problem with any I've bought. (Except for a Dell which makes a quite sort of crackling noise in operation, but the rest have been fine)
                          Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            #33
                            How you make sure that the dc jack is not worn-out?
                            • ezenia
                              PS4 controller left stick potentiometer replacement issue
                              by ezenia
                              Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                              So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                              I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                              09-30-2023, 02:19 PM
                            • Topcat
                              Nihon Kohden (Tyco Electric) ET2400LM 24" Restoration
                              by Topcat
                              This was rescued from a recycle gaylord from a hospital along with some other things....
                              I don't have to explain the significance of restoring this; 16:10 Aspect Ratio, 1920x1200; very high end Samsung LTM240CT04 panel. Add in it's blonde (will pair nice with a retro rig) and also ELO touchscreen. It is very well made, very heavy. Even used these are hard to find and expensive....but it had some problems...
                              Problem one, the external PSU was missing. I found one in my stash that had the correct voltage (12V) with the goofy 4-pin plug it used. It however was light on the...
                              08-02-2023, 10:07 PM
                            • dalek1967
                              Chinese made 12v 6 amp lead acid battery charger info
                              by dalek1967
                              I posted another thread like this for a TV power supply. This is for information purposes for anyone who has a bad one and wants to repair instead of replace. There is no model number on these but internally they appear to be the same, fan being the only difference I can find. If a component is damaged and can't be identified, this may help. One I have has the brand name XinJieBao on the front above the display. The other isn't marked.
                              My impressions. I can't say for sure on the chips and such but the HV capacitor is a very low quality one if I think. I tried to google it and also...
                              05-10-2023, 12:42 AM
                            • karatzdi
                              Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                              by karatzdi
                              I know some might say... just buy another one. Sell it as parts..!
                              So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                              Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                              Spent some time downloading the Service...
                              06-11-2024, 08:38 AM
                            • DXseekerMO
                              Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                              by DXseekerMO
                              Hello everyone!
                              Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                              I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                              Yes
                              0%
                              1
                              All backlight strips are the same quality
                              0%
                              1
                              No
                              0%
                              0
                              12-16-2021, 03:58 PM
