Water damaged MacBook Air A1932 AmrestoreErrorDomin Error-9 trying to restore with configurator
  • dbuergi
    • Jul 2024
    • 123
    • Deutschland
    this Macbook was stuck at 5v and didn't start because of some water damage. I was able to clean everything and the board started. So i put everything back together and the Macbook seems to boot with 20v, 1,4A and 29W. So i decided a DFU recovery. At 50% of the system repair i get the error massage from the title. Display stays black and no Apple logo. Both repair and recovery don't work.
    Is there anything i can do?
  • dbuergi
    • Jul 2024
    • 123
    • Deutschland
    One thing i found is a problem with the audio board. I have to give the connector a better cleaning tomorrow.
    So i diaconnected it and the MacBook started into recovery when i started Apple Configurator on my other mac.
    But again installation failed around 40%.
    Strangely the A1932 looses connection at this point and voltage changes as shown in the pic. After this the error message shows up.
    So do i have to look for shorts again or any failing chip?
    • dbuergi
      • Jul 2024
      • 123
      • Deutschland
      So i cleaned the board again under the microscope and reworked some solder joints which looked corroded. One big problem was the connector for the audioboard which was heavyly corroded and took some more time. The Macbook entered recovery mode and i was able to start a repair. It's starting now and my last and final problems is the cursor which is moving on its own.
      Just a general question do i have to enter more specific details to get help? I'm not a pro so often it is reading, watching videos and sometimes asking stupid questions to learn something.
      • mon2
        • Dec 2019
        • 14229
        Disconnect the trackpad to see if the cursor movement stops. Removing the trackpad will cause the required embedded sensor communication to be lost. This in turn will cause a high fan spin and will throttle the cpu speed but check if the cursor movement halts.
        • dbuergi
          • Jul 2024
          • 123
          • Deutschland
          I tried it and the Macbook worked normal for some minutes. Then it went back to slow self moving cursor and also the keyboard is not reacting to anything. Can this be a fault on the board or do i have to take a closer look at the trackpad?
          Cables and connectors look fine.
          • dbuergi
            • Jul 2024
            • 123
            • Deutschland
            Okay, too late to edit my former post. I had one small spot a the trackpad which i cleaned and now it's working fine but the keyboard is still without any reaction. The strange thing about this is that i used it to put the Mac into DFU mode yesterday and into restore today.
            Only thing i did was cleaning the connector and checking the cable for any damages.
            • mon2
              • Dec 2019
              • 14229
              Review the cabling on the trackpad and the keyboard. For the keyboard flex, be sure it is inserted deep enough into the mating connector. Often the horizontal silk screened bar can be used a guide for the alignment. Perhaps you can post a clear pic of the connector for the keyboard and keyboard flex.
              • dbuergi
                • Jul 2024
                • 123
                • Deutschland
                Sure, here are the pics.
                • mon2
                  • Dec 2019
                  • 14229
                  To me - appears that perhaps the one connector flex can be pushed in a bit more? Be gentle but can you attempt it?
                  You will have to use 2 fingers to gently lift up the locking blade / bar and then push further into the connector. If there is resistance, stop.
                  Also, concerned about the dark spot on the flex - is that flux or something else?
                  • dbuergi
                    • Jul 2024
                    • 123
                    • Deutschland
                    The spot was only some dirt and the i`m not able to push it any deeper. Tried it for several times now and the next step would be force but i don't think that it would help.
                    But problems with the trackpad seem to be solved after taking out the board connector and cleaning again.
                    One more thing i saw is the non working lid sensor which is causing problems so maybe i will replace the speaker and get a new keyboard / trackpad cable since they are not expensive.
                    • dbuergi
                      • Jul 2024
                      • 123
                      • Deutschland
                      I changed the cable and speaker with lid sensor and the MacBook came back to live and i was able to get into Internet recovery before it started to go crazy again. After rebooting voltage went to 20v i got a fan spin and A and W dropped to 0. I waited some time, tried again and it started to the flasing folder Icon. But this should be normal since i didnt reinstall the system.
                      So now i think i have to find a temporary? short on the board or a chip which is acting strange. Maybe any ideas where to start or is measuring any option here?
                      • dbuergi
                        • Jul 2024
                        • 123
                        • Deutschland
                        Water damage is a b.... I took my pick and inspected the whole board again and found three parts with corosion under the solder joints but all only had it on one side.
                        MacBook is running now but i got two more problems. The lid sensor is not working and since i installed a new speaker and audio board it must be something at the logicboard and the MacBook seems slow.
                        • bouch
                          unlock macbook air A1932 2019
                          by bouch
                          hi
                          i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                          i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                          i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                          have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                          I need help or information?
                          Does anyone have the minat2 activator 1.4 software?
                          Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                          Thank yo...
                          03-12-2025, 10:14 AM
                        • TOMÁŠ
                          MacBook Air A1932
                          by TOMÁŠ
                          Hi, I've never worked with a MacBook before, so I need some advice.
                          I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
                          05-20-2025, 11:19 AM
                        • Arshad alam4659
                          macbook air a1932 sign out of find my
                          by Arshad alam4659
                          Today I receive a MacBook Air A1932, its apple ID has been deleted but when I am resetting it is showing a message(sign out of find my ) customer's have no apple id he bought this MacBook from someone else can someone help me remove this message...
                          04-09-2025, 12:37 AM
                        • astroboypaul
                          Macbook A1932 Some Keys Not Working
                          by astroboypaul
                          Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
                          Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
                          06-10-2024, 05:32 AM
                        • Clarify4082
                          Macbook Air 2018 A1932 Bootloop
                          by Clarify4082
                          I have a A1932 Macbook Air with Bootloop.
                          I already replaced the battery with a new one and reset NVRAM and SNC.
                          When I start the Macbook the Screen is coming on (no Logo) and switches of after a few seconds. If I start without the trackpad and keyboard it stays on longer.
                          If I use diagnostic (Option+D), recovery (Option+R) I always get the Apple logo and it go into online-Recovery. Even if I boot the installer from a USB-stick it ends up in online-recovery. Sometimes it crashed short after entering the wifi password, sometimes it loads the recovery...
                          01-07-2025, 09:41 AM
