acer extensa 15 it works but doesn't charge main la-k093p
  • reset1986
    • Dec 2014
    • 308
    • italia
    Hi everyone, I have this laptop which arrived turned off, the KBC ene IC was short, replaced with an already programmed one, the PC works but doesn't charge, I replaced the BQ24800 IC with BQ24780S now it sees the battery but the orange light flashes and the percentage doesn't increase of the battery which stops at 55%
    all mosfets are good, there are no shorts, resistances in their values, what can I measure? I attach the diagram and board
    thanks
  • mon2
    • 14215
    Test the voltage to ground of the smbus lines of the battery pack (if present) = scl / sda pins.
    Test with a known good battery.
      • 20932
      Post a link to the schematic
      Reminder: rules and organization of this section
      https://www.badcaps.net/forum/troubl...f-this-section
      • reset1986
        • Dec 2014
        • 308
        • italia
        new battery, 55% charge, same behavior with original battery, it turned on even with battery only but not charged scl/sda not present
        BATT_B/I to ground to release battery voltage,
        current 11.1V
        BATT_TS 0.16V
        EC_SMB_CK1-1 3.3v
        EC_SMB_DA1-1 3.3v
        measurements with battery and charger inserted
        other measures +6V_CHG_REGN 6.2V
        ACDET 2.6v
        ACDRV_CHGR 25v
        • reset1986
          • Dec 2014
          • 308
          • italia
          Schematic https://www.badcaps.net/filedata/fetch?id=3472614
          Board https://www.badcaps.net/filedata/fetch?id=3482963
          • mon2
            • 14215
            Are you using the OEM charger / battery adapter for this unit? What is the power rating?
            Remove all power. Meter in resistance mode. Measure the resistance between pins 19 & 20 on the charger IC (SRN/SRP).
            Confirm the resistance across PRB22 and also of PRB24. These resistors define the peak current used for the charging of the battery. Do the measured values match the schematic values?
            Post the measurements.
            • reset1986
              • Dec 2014
              • 308
              • italia
              I'm using a bench power supply set to 19.5, put ADAPDET pins towards earth with bridge, put positive and negative cables soldered
              next values soon
              • reset1986
                • Dec 2014
                • 308
                • italia
                measured out of table prb22 316k and prb24 78k, they are ok, resistance between pin 19 and pin 20 20 Ohm, they are ok, I performed a measurement on all pins with power and battery connected, battery voltage 11.1V,power voltage 19.5
                1 ACN_CHGR 19.5 V
                2 ACP_CHGR 19.5 V
                3 CMSRC_CHGR 19.5 V
                4 ACDRV_CHGR 25 V
                5 ACPRN_CHGR 3.3 V
                6 ACDET 2.6 V
                7 IADP 0V
                8 IDCHG 0 V
                9 -
                10 PROCHOT 0V
                11 EC_SMB_DA1 3.3 V
                12 EC_SMB_CK1 3.3 V
                13 gnd
                14 -
                15 BATT_TEMP 0.15 V
                16 CHG_TB_STAT 0.16 V
                17 BATSRC_CHGR 11.1 V
                18 BATDRV_CHGR 11.1 V
                19 SRN_CHGR 11.1 V
                20 SRP_CHGR 11.1 V
                21 ILIM_CHGR 0.66 V
                22 gnd
                23 LG_CHGR 0
                24 +6V_CHG_REGN 6.1 V
                25 BST_CHGR 10.85 V
                26 UG_CHGR 11.09 V
                27 LX_CHGR 11.1 V
                28 VCC 18.76V
                any advice is appreciated, thanks
                • mon2
                  • 14215
                  Something wrong with pin # 7 = IADP on the charger IC. It is at 0v = adapter current. Review this area.
                  • reset1986
                    • Dec 2014
                    • 308
                    • italia
                    ok, iadp signal inspections, I wonder but can the bq24800 ic be replaced with bq 24780s?
                    is the ADP_I adp_i generated by the bq24 ic or by ene KB9052Q?
                    • mon2
                      • 14215
                      https://www.badcaps.net/forum/troubl...parts-bq24780s
                      • reset1986
                        • Dec 2014
                        • 308
                        • italia
                        from the discussion they are compatible, only pin 13 of the bq24800 is connected to ground, while the bq 24780s pin 13 CMPIN, I don't know if it could be a problem
                        • mon2
                          • 14215
                          Personally I would use the original part the OEM used. There is a reason for different part numbers of each device.
                          Confirm that the IADP pin is not floating and it should mate with the resistor showing in the schematic.
                          • reset1986
                            • Dec 2014
                            • 308
                            • italia
                            iapd not floating, I measure 0.09mv, resistance ok pr 206 2.3k pr208 10k, VCIN1_ADP_PROCHOT is not generated​
                            • reset1986
                              • Dec 2014
                              • 308
                              • italia
                              there is new information, I assembled the whole system and turned it on with battery, the system works but the problem is that the battery stops at 55%, the orange charging LED flashes and does not stay steady, the system works well even with only battery and the percentage drops battery normally
                              I noticed that if I turn off and hold down the power button for 10 seconds to reset, when I release the button the LED becomes steady and I notice the current absorption is 0.30 A for 10 seconds, then the LED flashes and the absorption drops to 0.2A., what could I check?​
                              • badcapjerboard
                                • Apr 2023
                                • 68
                                Did you ever make progress on this? I'm interested because I have a very similar problem on a thinkbook. Works, but won't charge. 3.3v on sda and sdl, but 0 on PWR_CHG_IBAT
                                It detects battery info, but incorrectly ie. 0% capacity after charging to 80% in different machine.
                                  ACER Extensa Extensa E264 Extensa E2200 Specification for Upgrade or Repair
                                  This specification for the ACER Extensa Extensa E264 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Extensa Extensa E264 boardview and Extensa Extensa E264 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-12-2024, 03:36 PM
                                  ACER Extensa M2710 Extensa M2 i3-6100 Specification for Upgrade or Repair
                                  This specification for the ACER Extensa M2710 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Extensa M2710 boardview and Extensa M2710 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
                                  09-12-2024, 03:30 PM
                                  ACER Extensa M2710 Extensa M2 i5-6400 Specification for Upgrade or Repair
                                  ACER Extensa EM2710 Extensa M2 i3-6100 Specification for Upgrade or Repair
                                  This specification for the ACER Extensa EM2710 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Extensa EM2710 boardview and Extensa EM2710 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
