ASUS TUF566HM No Power PCH hot ! (FX506HM) DA0NJHMBAH0 REV H
  • pc_okay
    • May 2022
    • 244
    • FRANCE
    Hello friends,
    A nice TUF laptop not starting, when i press power button LED POWER up and stay up, no fan spinning nothing more, juste charge LED and Power LED.
    I reflash bios and replace SIO, no changes...
    I didn't notice first but PCH is heating a lot and nothing else. (complete description on boardivewer C.S FH82HM570 B1 FCBGA943//INT TGL HM570 SRKMA/99AC55)
    I check my voltage and...
    RSMRST# ok
    DNBWON# ok
    The first voltage missing is SLP_S4# 😥
    Maybe PCH is dead, I need some advice please.
    How can I confirm this? Do I need a bga machine to replace PCH or my QUICK 8610 hot air station will do the job?
    And last one where do you sources your PCH?
    Thanks guys ! 😀
  • aaronysmael01
    • Sep 2024
    • Philippines
    I have same problem with my Lenovo Ideapad. Only PCH is getting hot. Also, SLP_S4 Is the first voltage missing.
    • questore
      • Dec 2015
      • 574
      • csongrád
      You have a faulty PCH, or PCH have a crached solderball under it. You can try to inject 3.3v on the SLP_S4 and if laptop powers on then its just a cracked ball and you can bypass it with a wire, but if no then PCH have to be replaced.
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • ShadowAi
        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
        by ShadowAi
        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
        03-15-2024, 10:46 AM
      • meraklinetx
        Asus Z97-a power cycle, no boot no cpu voltage
        by meraklinetx
        Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
        05-10-2023, 06:08 AM
