Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 not work with the battery
  • MTT97
    replied
    Originally posted by abobek zum
    I think I found the rootcause. Its a PU2001 (RT6585CGQW - 3Vand5V driver) + speciific PwrSeq on this board. This chip is damaged in specific way. There is leak of voltage to the ugate + shorted Ugate and source of Hiside mosfet (PQ2001) on 3VALW rail. So at the end you have follow situation:
    - When MB is powered by battery only there is a leak on 3VALWS and I have there 1.2V.
    - With the charger this leak is 3.4V which is really close what you should get on this rail.
    According to PwrSeq. with battery only for S5 stage, 3V and 5V ALW is OFF. S5 stage with charger, 3V and 5V ALW is ON and here I think is the reason why MB did not detect this specific short when powered with charger cause EC immediately send EN signal for PU2001 for 3V and 5 ALWS + the leak is very close to the nominal voltage on this rail and it is not detect or the current sens in the charger circuit is less sensitive than the battery one. PGOOD is pulled up to 3ALW.
    I will confirm that when Richtek arrives and I will be back from vacation.
    RT6585BGQW is the first thing in my suspect list to replace, followed by BQ24780SRUYR. When i received the laptop and plugged in the charger, i noticed that the RT6585BGQW was getting immediately hot, way too hot to even touch. It didn't take me long to find out that the +3VLP was shorted to ground. I then removed EC > short was gone > replaced EC > still no short > laptop now comes on but wont work if battery is plugged in.
  • abobek zum
    replied
  • MTT97
    replied
    So, for 230W, the measurement is correct; for 180W, it is not. However, I think there is no point in focusing on the charger anymore. Try doing what Mon2 suggested, and perhaps you will notice some anomaly.
    In my case, which could also be helpful for you, I was focusing on the SMBUS between the EC, the battery, and the BQ. I posted all the data that I got (for comparison purposes). I analyzed that data with AI, and it seems to be OK. So, the issue lies somewhere around the BQ chip (HW issue) or in the EC software—where, even if it gets the feedback from the battery, it is not accepting it for some reason (that could be another lead for a potential issue in your case, due to the fact that you replaced the EC chip).
    MTT97 , did you program the new EC chip, or did you write it with FF and look for autoprogramming from the main BIOS? I am not familiar with that MB, so I don't know if this EC supports autoprogramming.
    As for me, I have already tried two different BIOSes, and I programmed the IT8227E for each case individually. The behavior is the same. Based on that, I will focus on the HW, so now I am going to replace the capacitors and resistors around the BQ chip one by one, including the MOSFETs, even if the measurements are OK for them.
    Last resort will be looking for EC dump which works with exactly that type of the battery .....
    The IT8226E-192 i got off Ali was already ''pre-programmed'' for my board, so when i soldered it on the board, it did indeed boot but could also been empty and was auto programmed. Yet i bought a cheap programmer off Ali, erased the chip and the laptop was able to auto program the chip by itself but still didn't solve the issue. My final attempt i erased the chip again and had someone to extract the EC file from the bios and then written it manually into the EC chip but same issue as before again. I spent a lot of time and money on this board which doesn't even have great specs tbh (i5 9300h + 1660ti), i'm waiting for a new multimeter, other equiptment before i continue this repair just a bit more before moving on.
  • abobek zum
    replied
    Premium supporters get full download access and other benefits.
  • MTT97
    replied
    I meant to measure resistance of ID pin on your charger, not on your MB. To eleminate charger.
    Two original Lenovo chargers has already been tried, 180W & a brand new 230W charger. Same result.
    Edit: 180w & 230w both measured 4.6k
  • abobek zum
    replied
    Originally posted by MTT97
    The battery doesn't have enough charge to test it if the laptop works on battery only and i have no bench power supply at the moment to charge it manually. The laptop wont charge the battery either, it's just blinking orange light.
    As for ADAPTER_ID, the resistance to ground measured 950ohm which was low, i then removed the PD203 diode as mentioned before and now ADAPTER_ID is measuring 6k ohm to ground.
  • MTT97
    replied
    Small update. Battery is not the solution for my case. I tested with 3 different batteries.
    MTT97, is your laptop starts only on battery ? Your desciption when you plugin charger and battery is the same as main.
    About the warrning, you should measure the resistance on adapter pin and ground on your charger. How many Watts you should have there ?
    Here are few values.
    170 W ~ 1,9 kΩ
    230 W ~ 4,6 kΩ
    300 W ~ 8,6 kΩ
    P.S you have diffrent laptop/ MB so you should probably start your own thread.
  • mon2
    replied
    but i still cannot get the laptop to boot with battery and charger plugged in.
    MTT97 - this usually implies that you have leaky mosfet in the power path.
    Remove all power -> meter in resistance mode -> review the measurements across the 2nd DCin mosfet @ PQ102:
    source / drain
    source / gate
    gate / drain
    Post each measurement. Each should be hundreds of k ohms or higher else is likely defective and should be replaced. If found to be ok, review the other mosfets linked to the charger IC. Suggest to review PQ103 next (aka battery mosfet).
    As per the charger article by piernov (see above for this sticky), often the 2nd DCin mosfet becomes defective and raises such issues. If available, flux and replace PQ102 for quick testing. These are common N-channel mosfets and may be available on assorted motherboards.
  • abobek zum
    replied
    170 W ~ 1,9 kΩ
    230 W ~ 4,6 kΩ
    300 W ~ 8,6 kΩ
  • MTT97
    replied
    I have pretty much the same issue as OP. Laptop is legion y540 15irh, boardmodel NM-C221. The EC was bad causing the +3VLP on PU601 to short to ground. Replaced EC, short gone, laptop comes back to life. But i'm now seeing a warning message on each boot that You are using a lower-wattage adapter and when battery is connected with the charger, it wont boot at all. The charger led blinking orange and power button blinking white. I removed the PD203 diode for the Adapter_ID and the low wattage adapter warning is now gone but i still cannot get the laptop to boot with battery and charger plugged in. There are voltage fluctuation when the battery and charger plugged in at the same time, i've done a lof of measurement, including some here:
    Battery + charger:
    780s_VCC = stable 20v / internal resistance when everything unplugged 500ohm
    BQ24780S_VDD = stable 5.7v / internal resistance when everything unplugged 430ohm
    PC216 780S_LX = unstable 4.3-1.6v
    PC216 780S_BS_R = unstable 8-3v
    PR211 780S_BS = unstable 9-3v
    Battery only:
    780s_VCC = stable 11v
    BQ24780S_VDD = stable 5.9v
    PC216 both pins = stable 11v
    PR211 both pins = stable 11v
    Charger only:
    PC216 780S_LX = 0.2v stable
    PC216 780S_BS_R = 5.6v stable
    PR211 780S_BS =5.6v stable
    Everything else seems to be stable
  • mon2
    replied
    RTC battery MUST be connected and must be ~3V else needs to be replaced. This is the first required step of the power on cycle on most motherboard designs.
    The mosfet readings are correct. From the details so far, to me, the battery is the root cause and should be replaced with a known fresh one. If done already, test with another brand. There are many bad batteries on the market. The specs of the batteries can be faked with simple I2C tools from TI, etc. There are at least 2 companies selling devices to 'unseal' batteries, etc. To me, it is illogical to pimp up a dead battery. If the BMS locked out the battery pack, it did so for safety reasons. Forcing the BMS to come back to life again with hack tools is dangerous.
  • abobek zum
    replied
    Battery only:
    REGN is floating from 0.2V - 07V. If your press the PWRBTN, the MB is coming ON for split second and turining off. During this time REGN goes to 6.1V (same voltage as with charger only)
    Battery plug in + charger:
    PQ103 D: 20,54V, S:16,41V G:16,40V
    PQ102 D: 20,44V, S: 20,44V G: 26,33V
    PU101 Pin28: 19,19V
    Here the boot is cycling - MB is coming ON and OFF. When I diconnected the SDA and SCL from battery (remove the PR205, PR206). I can boot this MB in this configuration, unplugin the charger and MB remains ON but if turned off it will not start with battery only. You need repeat the sequence with the charger. RTC battery is awlays not connect during this tryouts
  • mon2
    replied
    These are ok measurements.
    Still with only the battery, review the REGN pin on the charger IC.
    Next, attach the adapter and measure these points again:
    PQ103 D: 16.34V, S:16,34V G:22,42V
    PQ102 D: 16,34V, S: 0V G: 0V
    PU101 Pin28: 16,16V
  • abobek zum
    replied
    Hi Mon2,
    Here are the measurement"
    PU101 Pin28: 16,16V
  • mon2
    replied
    Attach the pre-charged battery only; disconnect the power adapter.
    Meter in DC volts (30v or higher) scale.
    Measure the voltage to ground of the following points of interest:
    PQ103 (battery mosfet) ; source - drain - gate pins are of interest
    PQ102 (DCin mosfet) ; source - drain - gate pins are of interest
    PU101 pin 28
  • abobek zum
    replied
    Originally posted by mon2
    abobek zum - each case is different. Post the full details of your issues.
    Thank you for your prompt answer.
    In fact I have exactly same issue with the specific behavior included as OP so rather to create new topic I just want to ask about the status from this one. Tested on 2 different batteries ( one replacement and second one looks line original but have very few Charge/discharges count so probably is also not the original from that laptop - check by SVOD) - same effect. On other forum I found that solution was to use the Original battery.
  • mon2
    replied
  • abobek zum
    replied
    HI,
    would like to bump this topic even if its quite old. Was that issue solved ?
  • dhs6512
    replied
    Measured all signals on the charger BQ24780S, comment please. Thank you.
  • dhs6512
    replied
    Charged battery (in this unnormal cycle mode) to about 15v and now voltages at PD101: 1pin 780S_VCC_R 14,74v, 2pin VIN 0,002v, 3pin BATT+ 14,93V
  • Boardview and Schematic Bot
    by Boardview and Schematic Bot
    NVDC charger configuration...
    11-05-2024, 03:28 PM
    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
    Narrow VDC applications where the system power source is
    either the battery pack or the regulated output of the charger.
    This makes the max voltage to the system equal to the max
    battery voltage instead of the max adapter voltage. Operating
    at lower system voltage can improve...
    11-05-2024, 04:43 PM
  • flat-earther
    how to prevent a connected charger from draining battery when not charging?
    by flat-earther
    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
    So the battery is backfeeding the charger and being drained.
    How can I prevent...
    08-07-2025, 01:04 PM
  • ferah831208
    Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
    by ferah831208
    Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
    03-18-2025, 01:18 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
