g86-703-a2 pinout needed
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    I desoldered this chip because have short on 1.2v and 3v rails. Need to check this short to check if is chip ok or is fried. Did anybody know what pins to check?
  • loser18
    • Nov 2013
    • 274
    Re: g86-703-a2 pinout needed
    As far as I know...There's no way to check if the chip is bad...Heard if you check resistance across all caps on the chip & don't have resistance, it's fried(of course after desoldered & cleaned)...
    But not sure...
    • dellxps15
      • Feb 2014
      • 1591
      • italy
      on vga mxm you have 4 coil named L1 L2 L3 L4 ,first check if any of them is shorted.
      L4 is for: FBVDDQ SWITCHER POWER SUPPLY
      L1 L2 L3 are for NVVDD SWITCHER POWER SUPPLY
      on fpa there are many pin to check:
      i have a G86 schematic p419 (should be g86-630-a2)
      FB_VTT W19
      FB_VTT U19
      FB_VTT R19
      FB_VTT N19
      FB_VTT L19
      FB_VTT J18
      FB_VTT J17
      FB_VTT F16
      FB_VTT F15
      FB_VDDQ Y22
      FB_VDDQ U22
      FB_VDDQ P22
      FB_VDDQ L22
      FB_VDDQ J22
      FB_VDDQ T19
      FB_VDDQ M19
      FB_VDDQ J19
      FB_VDDQ F19
      also d15 get power.
      f13, h22 are ground
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3610
        • slovakia
        guys, im wrote that chip is desoldered. i need to check resistance on 1,2v and 3v on the chip. im not familiar with finding the right pins right on the chip so help will be needed. maybe enybody have some picture of pinout with some legend to be sure
        • dellxps15
          • Feb 2014
          • 1591
          • italy
          each bga start with a letter and number. fisrt ball is a1 , down there is b1, and so on. referring to your bga socket, i give you letter and number position of voltage and ground.
          (because bga is desoldered you have to look at that location inverted.
          like in the picture, but for bga they are inverted.http://4.bp.blogspot.com/_lAb8NkC80k...definition.jpg
          example: A1 is upper right, a30 is upper left. looking at removed bga.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3610
            • slovakia
            thats exactly what im looking for.
            Big thanks.
            • pickledegg
              Dell Inspiron 7501 / Vostro 7500 (2020) - eDP connector pinout/panel compatibility question
              by pickledegg
              Hello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
              I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...
              10-02-2024, 04:54 PM
            • maleksa
              Korg Kross2 Service Manual and LCD pinout
              by maleksa
              The LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
              However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
              Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
              From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...
              10-11-2024, 05:54 AM
            • chth96
              desoldered capacitor is self charging until 0.6 voltage.
              by chth96
              I have an 21 inch CRT TV which is not able to power on.
              I disassembled 21 inch CRT TV and measured voltage of main filter capacitor(Samhwa HC 400WV 220uF) in the circuit.
              It shows 270V on my DMM.
              So I discharged this main filter capactior completely and detached circuit board from cathode-ray tube.
              Then I desoldered this main filter capacitor from circuit board.
              But I noticed that this desoldered large capacitor(Samhwa HC 400WV 220uF) is slowly charged by itself until it reached 0.6V
              I measured its ESR value with MESR-100 and it shows 0.1 ohm,judging...
              03-28-2024, 08:56 AM
            • AquaMan Ua
              Panasonic toughbook CF-19 help connect the HDD directly. Need a SATA pinout.
              by AquaMan Ua
              Hello, dear community. NEED A DIAGRAM of the HDD/SSD connector contacts as an example (a screenshot from the diagram of another laptop on which I have already done this and a photo of the patient's board) Maybe someone can make a screenshot of the diagram with the pinout? Or does someone have a diagram of the motherboard schematic?
              I am asking, because not find the information myself anywhere. I have a PANASONIC CF19 MK2 laptop (Any revision will do, I do not think that the contacts in the connector are located differently) but finding a basket for it at reasonable prices is a problem....
              08-26-2025, 09:07 AM
            • Darren Hibbert
              Lenovo Y50-70 LA-B111P Boardview needed
              by Darren Hibbert
              08-09-2025, 06:01 PM
