Asus X407UBR No Power
  • abuhamza
    • Dec 2017
    • 19
    • Indonesia
    I have a ASUS X407UBR will not power up.
    I have measured:
    +3VA = 3.3 V
    +3VA_EC = 0,8V
    Need guidance where to start troubleshooting next. thanks
    LINK to schematic/boardview https://www.badcaps.net/forum/troubl...-0#post1751795
  • mon2
    • 14631
    Remove all power. Meter in resistance mode.
    Measure the resistance to ground of +3VA_EC.
    • abuhamza
      • Dec 2017
      • 19
      • Indonesia
      It's 1.3 KOhm
      I measured :
      +3VAO = 3.3 Volt
      +5VAO = 2,8 Volt
      The weird thing is that, after plugging and then removing the charger, resistance of +5VAO went very low to 11 ohm, but gradually get higher after some time back to 1800 ohm
      • mon2
        • 14631
        Review if this +5VAO rail is linked to the usb ports and usb vbus load switches. Inspect for damage in this region. Often, by spec, there will be a bulk cap on each usb vbus rail (usb type A connector). Maybe a partially shorted cap on one of these usb ports.
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • ShadowAi
          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
          by ShadowAi
          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
          03-15-2024, 10:46 AM
        • meraklinetx
          Asus Z97-a power cycle, no boot no cpu voltage
          by meraklinetx
          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
          05-10-2023, 06:08 AM
