Hi, maybe someone is able to help.
My macbook pro 16" 2019 is not installing Mac-OS correctly. I erased the disk and gone into recovery and installed Catalina. It ended with an error. Same with internet recovery with Catalina and Tahoe.I can't install another Mac-OS install via USB stick because the T2 blocks it. I erased the disk and don't have an admin user, so disabling is impossible. Setting the correct time via terminal didn’t help. First aid shows no error at all. Sometimes while installing catalina it restarts and loads the update screen with the apple logo and remaining time...
Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
MacBook Pro 16" (2019) A2141: power consumption? Dead GPU? MacOS not installing
by misc
by som_b1hello. I have 2141 on which I can't restore macOS. When loading, no buttons are active, it immediately wants to restore the Internet. But then I see an error 2100f. It doesn't boot from an external USB.
I can't flash it through dfu because I don't know the version of macOS that was on it. Help
By the way, for some reason it heats up inadequately and the coolers are at maximum -
by veedoI have Macbook A1534 which had Windows 10 installed on it, now customer want to have macos back because windows is slow.
From disk utility I deleted all partitions ( there was boot camp and macintosh ), created GUID Partition Map / APFS and I'm trying to install High Sierra from USB and its failing in half way, if I use Internet Recovery I have error apple.com/support -5101F, its shows me the option to go under support and mentions that battery have to be replaced.
Because the battery I can't install the MacOs or it something else? any suggestions please?... -
by SimplebeansI have just got in a MacBook Pro A2338 which was initially displaying the Apple logo followed by an explanation mark in a circle as described here:- https://support.apple.com/en-gb/102164.
After some error messages attempting to revive and restore the machine via DFU mode i have finally got the machine revived however now the issue seems to be when attempting to install macOS Sequoia via a bootable USB installer or via macOS recovery the machine just keeps freezing and restarting before the installation is complete, usually the installation has just started or is mid way trough before...08-10-2025, 11:04 AM -
by prw07Mac crashes and restarts with kernel panic. No water damage on board. Board is clean. Memtest86 showing no errors. The installation Ventura or Sonoma is successful, but after 5-10 minutes of operation, the accident occurs again. Did a DFU restore and revive, twice with success and successfully reinstalled Sonoma. After 5 minutes of work Mac crashes with Kernel Panic. Apple Diagnostic (AHT) does not find errors.
How to localize the problem ? - Loading...
