UNOWHY - Y13G010S4EI 2 smd components identification.
  • kamel
    • May 2011
    • 129
    • TUNISIA
    Dear members,
    need help identifying 2 missing smd components on motherboard EM_IG116_366B_V2.0 to get laptop UNOWHY - Y13G010S4E - PRODUCTION : 2020 repaired. (see red marking on photo).
  • kamel
    • May 2011
    • 129
    • TUNISIA
    hello, still waiting for any help from members, schematic or boardview to get the 2 missing smd identified.
    • mon2
      • Dec 2019
      • 14631
      Remove all power. Meter in diode mode. Touch one probe to the missing part’s pcb pad. Hunt for the other pad by testing each pin on the flash. Make a list of the contacts.
      • kamel
        • May 2011
        • 129
        • TUNISIA
        Thanks for your help.
        Do you mean, one probe on each of the pads of the missing parts ( 2 parts so 4 pads in total) and the other probe on each pin of the bios?
        • mon2
          • Dec 2019
          • 14631
          The right 2 pads are common (see the trace between the pads). Place one meter pad on the right side pads (either one); place the other meter probe to ground. Do you hear a tone beep? If not, these parts are not to ground.
          Test with the meter probe to pin # 8 on the flash IC = Vcc. Do you hear a tone beep?
          Then proceed to test the left side of each missing part pad. Test for a short on each flash IC. Very likely these are pull-up or pull-down resistors that were lost.
          • kamel
            • May 2011
            • 129
            • TUNISIA
            hello, I already checked the pads of missing smd as well as the pins of flash; all of them are not grounded (except 4th pin of flash i.e GND).
            Also I desoldered the flash and didn't find any link between flash pads and missing smd pads. I got to know from one colleague that the missing smd to the left is a diode marked "T" and the one to the right is a black smd measuring 100k and 31k when probes inverted; it should be a kind of resistor. With those new clues, it's getting more and more clear. Do you suggest any idea for the replacement of the smd to the right ?
            • kamel
              • May 2011
              • 129
              • TUNISIA
              Still relevant ....
              Does no one have UNOWHY - Y13G010S4EI laptop at hand or a scrap motherboard EM_IG116_366B_V2.0 to help identify smd component marked 1 on photo. Schematic and boardview aren't likely to be available ?
              • Belhadi Wail
                • Oct 2024
                • Algeria
                • kamel
                  • May 2011
                  • 129
                  • TUNISIA
                  I just saw the photo today. Thanks. Unfortunately the layout is different and the missing component doesn't exist in the photo.
                  • martingheorghita
                    • Jul 2018
                    • 9
                    • România
                    Hope this help
