No VCC to bios chip - Huawei Matebook d15 DAH98AMBAD0 REV:D HF Model H98A H898A
  • Raygen
    • Sep 2024
    • 10
    • Italy
    Hello, I received to repair this Huawei laptop (model in the title).
    The laptop will charge the battery fine throught the USB C port, but it wont turn on. The charging led will blink fast and repeatedly when trying to turn it on.
    I've attached photos of the board. (the wires are for briging the power button, I did not inject voltage)
    Upon visual inspection, a couple of ICs were blown. Along the 5V line leading to one of the USB A ports. They wasnt fully shorted but just a couple of ohms to ground.
    I replaced the blown IC on the board (the one circled in red, close up photo attached), and just disconnected the I/O board were the other blown IC was.
    This did not fixed the issue though.
    Main power lines are all up. 3.3, 5, and 12 volts present.
    Trying to search for any other short or blown ICs I've noticed a couple of things:
    • Without the battery connected, the charging led will just stay stuck on. It won't blink fast and repeatedly like when battery is connected, if I try to turn it on. And yeah, the input power on the USB C will just fluctuate when trying to turn it on, but then fall back to nothing. It wont boot loop by itself. When battery is connected instead, input power for charging is steady and regular.
    • One of the CPU coils (the one circled in purple) reads 1.2 ohms to ground, while all the others read 2.3 ohms to ground. I've no idea if it's normal or if the chipset could be fried.
    • The Winbond flash bios chip has no VCC, even when trying to turn it on, it gets 3.3V for a split second but then goes away. I've followed the VCC pin to a small SOT-23 form factor smd (photo attached), which I gueees is a tranistor or mosfet? I could not find the datasheet through its markings. It has 3 pins: one pin goes to the vcc bios, one has 3.3V from the power line, and the third pin I guess is the control pin of the transistor. I've checked this third pin, and yup, it goes high for a fraction of a second when trying to turn on the laptop, and then goes back low.
    • CPU doesn't feel warm. I do not have a thermal camera yet.
    Welp, I'm out of ideas, apart from the suspicion that the CPU might be toasted.
    Where does the third pin of that transistor / mosfet lead to? directly to the CPU? I could not find it.
    I've found schematics for this board from this thread. But I don't thing they're the right schematics.
    For example: The pin out of the bios / flash chip does not correspond to the one in the schematics.
  • Raygen
    • Sep 2024
    • 10
    • Italy
    Bump
    • mon2
      • Dec 2019
      • 14544
      What is the voltage to ground of the pad pointed to by the arrow?
      Click image for larger version  Name:	voltage_check.png Views:	0 Size:	1.68 MB ID:	3470606
      Click image for larger version  Name:	flash.png Views:	0 Size:	70.5 KB ID:	3470607
      • Raygen
        • Sep 2024
        • 10
        • Italy
        The pad on top of the one in line with the VCC trace?
        It's a ground pin, so always at 0V.
        Both pads (yellow arrow and vcc) have a factory clean solder blob. There was no knocked off component.
        • Sabina
          • May 2022
          • 67
          • philippines
          By any chance do you still have the board for this ,. i have a hard time finding what component is this,. near the edp ., beside the big Fuse
          • Raygen
            • Sep 2024
            • 10
            • Italy
            Sure, here's the photo.
            Looks like a mosfet. Like a LP301ALT1G
            • Sabina
              • May 2022
              • 67
              • philippines
              Thank you so much brother Big Help
                Huawei MateBook Matebook D 15 Notebook D 15 AMD Specification for Upgrade or Repair
                This specification for the Huawei MateBook Matebook D 15 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Matebook D 15 boardview and Matebook D 15 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-07-2024, 06:21 AM
                Huawei MateBook Matebook 16 Notebook 16 Specification for Upgrade or Repair
                This specification for the Huawei MateBook Matebook 16 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Matebook 16 boardview and Matebook 16 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-07-2024, 06:11 AM
                Huawei MateBook Matebook D15 Notebook Specification for Upgrade or Repair
                This specification for the Huawei MateBook Matebook D15 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Matebook D15 boardview and Matebook D15 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-07-2024, 05:50 AM
                Huawei MateBook MateBook D 15 Notebook D 15 Specification for Upgrade or Repair
                This specification for the Huawei MateBook MateBook D 15 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MateBook D 15 boardview and MateBook D 15 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-07-2024, 05:20 AM
                Huawei MateBook MateBook 16 Notebook 16 Specification for Upgrade or Repair
                This specification for the Huawei MateBook MateBook 16 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MateBook 16 boardview and MateBook 16 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
