Problem in 5V Fan
  • magneh
    • Apr 2014
    • 616
    • Portugal
    Problem in 5V Fan
    Hello!
    I've got a laptop with fan problem. Doesnt turn.
    Here's the circuit.
    On U41 I've got :
    Pin1 - 1.44V
    Pin2 - 5.14 V
    Pin3- 0.03V
    Pin 4 - 0.01V
    On JFAN :
    pin1 - 0.02V
    pin2-GND
    pin3 - 3.25V
    U41 is the culprit?
    Didnt find any shorts.
    Thanks for your help!
    • 31259
    Re: Problem in 5V Fan
    take the fan out and test it.
    they often jam or need to be stripped & lubed.
    • magneh
      • Apr 2014
      • 616
      • Portugal
      The fan is OK
      And she works, I've applied 5V to her and works perfectly
      • pravin6p
        • Mar 2014
        • 75
        • india
        change the circuit. take 5 volt from the usb.
        its easy. thats what i do in this case.
        • atsio
          • Oct 2013
          • 819
          • Greece
          Originally posted by magneh
          Hello!
          Here's the circuit.
          On U41 I've got :
          Pin1 - 1.44V
          Pin2 - 5.14 V
          Pin3- 0.03V
          Pin 4 - 0.01V
          On JFAN :
          pin1 - 0.02V
          pin2-GND
          pin3 - 3.25V
          U41 is the culprit?
          You are not measuring something allright. You can't have 5v on pin 2 of U41 and 0.02v on pin1 of JFAN and no shorts.
            • 31259
            check the ceramic capacitors for shorts.
            • magneh
              • Apr 2014
              • 616
              • Portugal
              Hello!
              https://cdn.badcaps-static.com/pdfs/...a2fa5bebc3.pdf
              Humm... I think the pin2 of U41 is Vset, and then nothing to do with pin of JFAN
              JFAN pin1 = Pin 3 U41 ( Vout = 1.6x Vset pin 4)
              I think the problem is having 0V at pin 4 Vset
              If I had 3V there the 5V would appear on pin 3 of U41.
              I've mesured on D40 3.25V
              I've also noticed that I have what seems to be a burned component (see photo attached )
              It's PR128 I think ...
              The laptop had also problems in keeping CMOS settings , but the battery is OK (2.9V)
              Where could I find a similar component to change this one? on a broken laptop rig I suppose ?
              thanks again!
              • atsio
                • Oct 2013
                • 819
                • Greece
                Yes you are right. Quick answer without paying much attention to the schematic (too busy). What's the model of the board?
                  • 31259
                  that looks more like soldering residue from an iron.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5082
                    • New Zealand
                    I think so too. Note that Pin 1 (/FON) will turn fan on full if pulled low, I would try that, if it starts the fan, find out why you aren't getting CPU_FAN signal to Pin 4, if it doesn't, maybe U41 is dead.
                    -David VanHorn
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      The shematic (picture) points it clearly that they are shorted pads and I don't think it has to do anything with the EN signal of the fan because it is to boost the voltage of a voltage regulator and from what I understand from the picture it has to do with the 1.8v regulator.
                      What is the model of your board?
                      • magneh
                        • Apr 2014
                        • 616
                        • Portugal
                        Hello again!
                        Back
                        Here's the model : 6-71-M74S0-D05A
                        The manual I found is the clevo w760s w765s model reference.
                        Tomorrow I'm gonna work on it.
                        Please leave your thoughts guys!
                        Thanks!
                        • magneh
                          • Apr 2014
                          • 616
                          • Portugal
                          UPDATE
                          Ive pulled low Pin1 and the Fan started spinning immediately!
                          Mesured the resistance in R586 and I read 1170 ohms...
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5082
                            • New Zealand
                            That R586 is probably OK, and I guess so is U41. They aren't going to pull it down hard with a low value resistor and lose control over the fan. Most likely CPU_FON# signal is normally pulled high and goes low when they want the fan at 100%
                            Though I don't understand what the *0_04 means on the schematic for R586.
                            Can you post the full schematic file to find out where these signals go, especially CPU_FAN?
                            -David VanHorn
                            • magneh
                              • Apr 2014
                              • 616
                              • Portugal
                              Hello!
                              Of course I can! Here he is.
                              Please share your thoughts! and thanks for your help!
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                I can answer that. Check R308. See if you get different voltages at each end of R308. If you aren't getting anything on either side, follow the trace from R308 to pin 76 of U20 IT8512E.
                                If there's nothing on pin 76 either, then U20 is faulty and must be replaced. But i wouldn't bother with that for a fan... You can easily make a little replacement circuit to enable the fan to still be thermally controlled.
                                A working TV? How boring!
                                • magneh
                                  • Apr 2014
                                  • 616
                                  • Portugal
                                  Okay!
                                  Gonna check that tomorrow.
                                  Could this IC be also responsible for the problem in keeping the CMOS settings? the bat is OK but the laptop doesnt keep the setting when unplugged.
                                  If it's U20 the culprit, could you explain to me how to enable the fan garanteeing the thermal control?
                                  Thanks again!
                                    • 31259
                                    cmos problem is probably a bad diode
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5082
                                      • New Zealand
                                      I don't know how the fan controller works but I just thought of something, maybe the controller is getting bad feedback from the fan RPM sensor and it thinks the fan is spinning when it's not or something.
                                      -David VanHorn
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        Okay!
                                        Thanks again!
                                        Yes it could very well be U20. But also check the diodes and transistors connecting the RTC battery to U20 like stj suggested.
                                        Impossible, as this particular fan controller chip is a "dumb" model, it's just a linear regulator. RPM is not even monitored in most laptops for other than displaying it to some diagnostic software... The fan speed is based on the thermal sensors monitored by the EC which is U20 in this case.
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • kalilinux25
                                          Lenovo Thinkpad T410 no power
                                          by kalilinux25
                                          DEVICE: Laptop
                                          Model: lenovo thiinkpad t410
                                          Board Id: 09A33-3 48.4FZ09.031
                                          NZM1H-8
                                          ISSUE: NO POWER
                                          From the first mosfet 20v is not passing through, pin 4 has 19.5v and the first mosfet is a P-CHANNEL mosfet (SI7121DN) i think the pin 4 should be lower to active the 1st mosfet to allow the 20v to pass to second mosfet ive check all for shorting in the board , i did;nt find in rails, so ive check the schematic and im suspecting that, my Q61 is faulty due to its pin 1 is 0.47ohms? im not pretty sure, hope someone can help me figure out this issue.
                                          07-13-2025, 07:56 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
                                        • perzyk23
                                          Lenovo T580 - LCD Panel problem - error 0288
                                          by perzyk23
                                          Good morning,
                                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                          10-25-2024, 12:42 AM
