Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
  • lowpost99@gmail.com
    • Sep 2024
    • 8
    I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but discovered it sits in a frame with and has a 5-wire connector BLK-BLK-R-R-B, and although it was securely plugged into the MB, I see what looks like possible burn marks from the two BLK wires near the top of the connector in the photo. D
    Does this look like the type of fry that would cause the symptoms that I'm seeing? What other testing can I do to validate the cable and the battery itself? I don't want to just throw parts at this if I can avoid it. I can use a multimeter...just point me to the test points and the acceptable values. T​he MB inside says it's a ADM70 LA-C631P, REV 1.0(A00) 2015-10-23
  • mon2
    • Dec 2019
    • 14575
    Stop. You MUST use a Dell branded and recommended power rated adapter for this laptop. Check the original specs for the laptop for the power rating. This is mandatory so that you have a working PSID pin which is a 1-wire ID IC inside of the power adapter to identify the proper specs of the adapter. Every Dell requires this security 1-wire ID feature. Only then will the charging work normally. Cannot comment on the Jacob's ladder / skidmarks you are facing till the adapter is a Dell brand. Perhaps available through Amazon. You can always return it if you decide not to keep it.
      • Sep 2024
      • 8
      Thanks for the info! Will report back ASAP on any changes!
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
        DELL Latitude E5470 Notebook 5000 Specification for Upgrade or Repair
        This specification for the DELL Latitude E5470 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E5470 boardview and E5470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
        09-07-2024, 12:40 AM
