Compaq CQ62-210US no dispplay
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    I acquired a dead compaq cq62 motherboard yesterday. When I attach power adapter no led light in dc jack which indicates no power. I have check board and there seems no heating components and all is looking good. decided to program bios with the file downloaded on HP website.
    After bios flash dc jack now has led light indication that it receives power. When I press power button it turns on but there is no display on external monitor. tested different memory and still no display. I cannot test it with lcd panel because I don't have any spare here and owner didn't have it too. I don't have keyboard too.
    Does this indicate that bios reprogram is a fail? I also notice that if I press power button again it turns off, Its like commencing correct power off command. I usually see laptop with vga issue which does not turn off when power button is pressed. any ideas? Thanks.
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: Compaq CQ62-210US no dispplay
    try a mild reflow on gpu
    • alihomee
      • Dec 2012
      • 1574
      • malaysia
      you need to try the conform bios file because normally website bios did not work
      • lezsimply
        The Wanderer
        • 645
        • Philippines
        I'll try it fddizon but before that I wan't to look for good bios first. One thing, the file I got from hp website was an exe file. When I extracted those file I found 3 versions of .fd with different sizes. 1mb, 2mb and 4mb, I used 1mb because the bios dump I saved from the bios chip itself is 1mb. I've got 2 other more from other sites.
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          when flashing hp/compaq always read and dump bios from eprom it can help later rebuilding DMI and it can help determine exact version of motherboard/bios combination
          it would be best for you if someone should dump working bios with rw-everything or directly from eprom and test with that
          Im Back... sort of...
          • lezsimply
            The Wanderer
            • 645
            • Philippines
            does anyone have dump for this intel version?
            • lezsimply
              The Wanderer
              • 645
              • Philippines
              Got it! Its already up and running. I have attached bios file and hope it can help others. Thanks everybody!
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • iulik17d
                Intel Arc A380 videocard power limit remove - BIOS needed
                by iulik17d
                Hello everyone!
                The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
                The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
                01-10-2025, 02:33 PM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
                by Vesko356
                08-11-2023, 03:27 AM
              • Nopslide
                HP Omen 15-dh0052nf power-on & bios password
                by Nopslide
                Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                04-01-2024, 04:27 PM
