Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Macbook Pro A1707 - Dead - Battery 'popped'
    Posted Photos 6 Photos
  • leonemax81
    Macbook a1707 820-00281 Battery no Power
    by leonemax81
    Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
    08-23-2024, 09:24 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • PITERPENY
    Macbook A1707 820-00928 battery replacement
    by PITERPENY
    brought in a working MacBook for battery replacement (swelled up). After replacing the battery it stopped turning on. tried connecting the old battery without changes. consumption with the battery connected and without the battery is the same 5v\0.200a on all 4 ports. replacing 9239 did not help
    04-20-2025, 03:22 PM
  • silver60618
    Macbook Pro A1990 - Battery not detected after connector torn off
    by silver60618
    Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
    Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
    11-12-2025, 06:36 PM
  • BMCappelletti
    Macbook Air M1 2020 A2337 - running on reserve battery (without battery)
    by BMCappelletti
    Hi everyone.
    Quick backgrounhd story: Macbook came to me stuck on 5V. According to repair.wiki I could have an issue on L7800. Indeed it was not passing signal through. And I did have an issue on PP5V_BSTLQ_VOUT_SPMU line. I found a cracked cap (C7800) and replaced both failing components.
    Now it negotiates 20V and the computer starts, but I receive the message "you are now running on reserve battery power", as shown on the attached picture. It happens with or without a battery connected. So I am discarding a battery issue, for now (it may be bad, but I will only know for...
    12-11-2025, 06:03 AM
