macbook A2141
  • PITERPENY
    • Jul 2023
    • 472
    • Ukraine
    macbook A2141
    Can you please tell me from which MacBook models the display can be used to test the MacBook A2141 820-01700 board?
  • mon2
    • 14839
    Personally - I would search out for a working but locked board of the same model. Then test your display against that new board. My suspicion is that the display is not compatible. Returning one now back to XJS - causing power cycling everytime we connect the connectors.
    • mon2
      • 14839
      Curious - are you able to monitor the voltage & current draw WITH this display attached? With the unit from XJS, we were peaking to ~700mA and then power cycling. From iFixit forum, this cleary indicates the display had the incorrect or missing firmware for the T-con board. Now we are paying $30 + # of hours to ship this crap display back to China with an ETA of 2 months and then they will inspect the display and issue a refund only then. All because someone there did not test the display before shipping. BTW - we also ordered a unit from Seven Puppy because they claim that TRUETONE will work 'out of the box' and their display worked immediately. No idea about the Truetone support as we do not have the client's passwords for checking this feature.
      • PITERPENY
        • Jul 2023
        • 472
        • Ukraine
        Why am I asking because I also bought a new display but I don’t get any images, but all measurements show that there should be a picture but there isn’t! thank you very much for your answer! I thought that since almost all MacBooks have clones with an interchangeable display, I thought that this model also had something similar!
        • mon2
          • 14839
          Share your details from the USB meter. Are you at 20V with ample current to power the board WITH this display attached? Or is it power cycling like ours was. This is to rule out if the T-con board is a proper match for this logic board (or not).
          • PITERPENY
            • Jul 2023
            • 472
            • Ukraine
            The data from the USB tester corresponds to the normal operation of the MacBook and does not overload! everything works well but there are no pictures on the displays! For now I stick to your idea of ​​finding a working motherboard or display that I can see for myself that it works! but 16" costs a lot of money!
            • mon2
              • 14839
              Even locked ones? I think there is some dude in Hungary that is advertising on Ebay for assorted mac stuff. I was pinged by a very large wholesaler from Europe to fix macbooks - I may have his contact details still. I think they purchase stuff from Costco, etc. for their returns with password protection.
              • reformatt
                • Feb 2020
                • 1549
                I've never bought a 15" or 16" display from China as they are so expensive. The refurbishers here buy MDM/iCloud locked machines on eBay and steal the displays off them. The displays are genuine and works out cheaper than a display from China (if it works).
                I'd just check the EDP_INT_AUX lines in diode mode, as sometimes U9850 gets damaged.
                I also see the refurbishers are swapping IC's between displays when replacing LCD only on the newer models.
                • mon2
                  • 14839
                  Have to ask..are you confident of your soldering of this mux? Also following your thread on the Rossmann forum on the same topic. With even a locked but working board, you can compare diode mode measurements. Not sure if the boardview files offer these measurements but worth a search.
                  • PITERPENY
                    • Jul 2023
                    • 472
                    • Ukraine
                    It was with this problem that the MacBook arrived with a dead u9850 and it was replaced three times! All indicators in all modes correspond to measurements! then I bought a new display but there is no picture either, but what doesn't work? I wonder if there is a problem on the display or a problem somewhere on the motherboard!
                    if you are interested in how the repair is going:
                    Hello again, I'm back! Some liquid got onto the 8500 connector, causing a short circuit on the EDP_INT_AUX_N and PPVOUT_S0_LCDBKLT lines. MacBook works with external display! help me please ! U9850 has been replaced.
                    • reformatt
                      • Feb 2020
                      • 1549
                      Is the display detected in MAC OS? Connect the MAC to HDMI and check the display settings. Usually the voltages PP3V3_S0SW_LCD and PP5_S0SW_LCD should be initially enabled and toggle off if there is no communications from the display.
                      • PITERPENY
                        • Jul 2023
                        • 472
                        • Ukraine
                        thanks for the new perspective. The system does not see the displays that I have. The system immediately boots to the external monitor. In the displays section there is only an external monitor. what could be the problem
                        • PITERPENY
                          • Jul 2023
                          • 472
                          • Ukraine
                          PP3V3_S0SW_LCD=3,3v all the time
                          PP5_S0SW_LCD =5v all the time
