Where to buy 0402 caps and resistors
  • John McGivern
    • Dec 2013
    • 195
    • uk
    Hi guys, could anyone suggest where to buy the above?
    Does anybody sell component kits for laptops.
    Many thanks in advance.
  • T30M31
    • Feb 2014
    • 58
    Re: Where to buy 0402 caps and resistors
    I have always purchased mine from Mouser or DigiKey. An internet search for "SMD 0402 resistor kit" will provide information on kits.
    I also salvage some from old hard drives and other electronics that will not be repaired.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Whilst maplins are no good for low esr Electrolytic capacitors they are ok for other things
      IF they have them. Usually a bit expensive but if you only want a few and have an outlet nearby. next up cpc.com (Currently post free on small internet orders.)if they have what you want. thenrs components and farnells then digikey /mouser
      • dellxps15
        • Feb 2014
        • 1591
        • italy
        mouser and digikey are i think the most famous and think they have original good quality component, but for EU people ship costs are a bit expensive. i see your from uk. on ebay many uk shop sell them, while noone have 0402, 0603 1206 here in italy.
        check first in ebay.uk a good uk seller then look if it's near you. most of them however offer free ship to uk country .
        good luck
        PS: just bought a pack of 0402 fuse from uk last week
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • TinkerTron
          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
          by TinkerTron
          Hey everyone,
          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
          Instead, here's what's been bugging me so far:
          The schematic...
          03-06-2025, 02:03 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
