it so weird my Acer 4530 (AMD Processor)
+ More Options
Posts
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    Good Day to all
    I have Problem to may Acer Aspire 4530. the Keyboard keys problem)
    (problem) Keys QAZWSX alt ctrl capslock TAB 1 2 (and The Side Button etch WIFi and Bluetooth e button)
    i replace the Keyboard many times. new (Brandnew) 100% working and i try to change a Secondhand but 100% used to other same unit i barrow to test no luck.
    i wondered sometimes working if i shutdown (turn off) then i On. return the problem.
    i reformat. i used new hdd and memory i cleaning the MotherBoard and I resolder the keyboard slot... how come?
    it so weird... anyone can fix this?
  • selldoor
    Slow Learner
    • 7870
    Re: it so weird my Acer 4530 (AMD Processor)
    Try clearing the cmos? updating the bios- Does sound like it is a keyboard socket problem - assume you have cleaned and looked for bent /broken pins. I see you have reformatted
    but just check what keyboard the system thinks it has- think a keypress should still give something but worth a quick look
    • lefos
      • Nov 2013
      • 321
      • Greece
      Hello, this is usually caused by the EC ic (made from winbond or ene).
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        EC is the second place to look, first place is after connector, caps near connector. there are toons of caps or sometimes group of caps near/under keyboard connector. Compare with schematic if you have. then search for a cold soldered ec leg connected to those caps. Ec gets the keystroke signals by that pins. if everything is ok then replace EC.
        • lorins_core
          BlackSmith
          • Dec 2012
          • 551
          • Philippines
          i got it.... Thanks You To All Of You Guys. it is a not IC Nor Hardware problem... It is a Problem on Easy-launch buttons. the one module... if i remove on connection all keys has been working Proper...
          To all Other Forum-mates. that is a Solution Tips... thanks To all
          Problem Solve... it is Weird but have Solution....
