HP G62 shutdown
  • MDY
    • Jan 2014
    • 75
    • Spain
    HP G62 shutdown
    I have HP G62 which shutdown at 7,8 seconds and simetimes after 10-15 minutes. After changing thermal pad and cpu thermal paste it work 3 days perfectly and then shutdown.
    Now it keeping shutdown after 10 seconds and sometimes it keep few minutes. It is not a temperature problem. Any udea what to check?
    Note: Cpu es INTEL and I replaced CPU, RAM, AC adapter.
  • tomodachi
    • Apr 2012
    • 604
    • Turkey
    Re: HP G62 shutdown
    is it dropped before ? any crack on mohterboard may be happened and cause shutdowns
    • ry x hunter
      • Jun 2013
      • 184
      • philippines
      Re: HP G62 shutdown
      if your gpu is ati radeon try to reflow it..
      • miros84
        • Jan 2014
        • Spain
        Re: HP G62 shutdown
        I dont know if it was droped before. Have to ask customer.
        GPU es ati and I did reflow to test.
        Now I will try several days.
        • sew333
          Pc shutdown, monitor flickered with no signal after 10 seconds
          by sew333
          My pc:
          10850K stock 4800mhz stock Kraken X73 good temps
          2x16 GB DDR4 GSKILL 3000mhz XMP
          Seasonic Tx-850 Ultra Titanium
          Gigabyte Rtx 3090 Gaming OC
          Aorus Z490 Pro Gaming
          1 TB SSD
          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
          Power...
          02-22-2022, 10:27 AM
        • DrFalken
          Dell Inspiron 5593 shutdown after 5 seconds
          by DrFalken
          Hello everyone!
          Motherboard model: FDI55 LA-J081P
          Today a customer delivered this laptop completely dead, with the original power supply shorting when plugged into the connector.
          I found and replaced a shorted MOSFET (PQZ3).
          Now the laptop turns on (fan runs fine but no video signal) and after 5 seconds it turns off.
          BIOS has already been updated (both 64MB and 128MB IC)
          +3VALW and +5VALW are still present.
          +VCCIN = 1.8V stable (measured on PLZ1 at power up)
          Abnormal readings:
          PLZ1 to GND = 0 Ohm
          PLZ2 to GND = 0 Ohm
          04-09-2025, 10:45 AM
        • rex98
          Msi b250m bazooka shutdown after few seconds
          by rex98
          Does anyone here encountered the same problem i have on this motherboard? It shutdown after few seconds PCH is hot. The bios is fine. All voltage signals are normal it just shutsdown when it turned on a few seconds like 30sec the logo shows up ang bios settings shows the pch heats up then shutsdown itself. Can someone help me. I need schematics and boardview of this motherboard....
          04-09-2023, 09:27 PM
        • Pygo86
          Liyama G-Master GB3466WQSU-B1 - Backlight on - Shutdown after a few Seconds
          by Pygo86
          Hey Folks,
          i'm not far into Monitor troubleshooting. It's my first time. Normaly i try to repair Laptops.
          The Monitor is powering up. And the Backlight turns on. After a few Seconds the Backlight shuts off and the Power LED turns form Blue to Red.
          I can power it up again, but it's always the same Result.
          No Matter which Connection is used.
          I can't see anything obvius after disassembling. No Heatspots with the Thermalcam visible.
          The Powerboard is looking great. There is 12V and 5V everywhere on the Logicboard.
          So, i decided to swap that Logicboard....
          03-04-2024, 11:38 AM
        • Veyron7887
          Laptop overheating after replacement thermal paste
          by Veyron7887
          Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
          11-24-2024, 05:08 AM
