hdd smart error
  • alihomee
    • Dec 2012
    • 1580
    • malaysia
    hdd smart error
    any body knows how to remove smart error on hdd
  • lezsimply
    The Wanderer
    • 655
    • Philippines
    Re: hdd smart error
    some bios have option to enable/disable this feature. and also you can try using hard disk sentinel which you can modify attributes.
    • Maj.GHOB
      • Feb 2014
      • 5
      Re: hdd smart error
      You can't really remove a SMART error from an HDD. SMART is supposed to give you a heads up about imminent HDD failure.
      Whenever a HDD gives you a SMART errors the first step is always to image the HDD or back it up manually if you are not familiar with imaging. Once that's done I normally either send it out for warranty replacement if applicable or use it for none critical data until it kicks the bucket.
      • LLLlllou
        • May 2011
        • 201
        Re: hdd smart error
        Yes:
        1) buy new hdd.
        2) clone old hdd to new.
        3) throw away old hdd.
        Ta-Da, smart error removed!
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          Re: hdd smart error
          smart can be erased but its very complicated... seagate disks can be doable with terminal like this
          https://sites.google.com/site/seagatefix/Home
          http://forum.hddguru.com/viewtopic.php?t=11040&start
          rest of them need special card calld pc3000
          http://www.acelaboratory.com/
          enter this
          CRTL+Z
          F3 2>U
          Spin Up Complete
          Elapsed Time 7.242 secs
          F3 2>
          F3 T>/1
          F3 1>N1
          this is a S.M.A.R.T. erase
          after that POWER off HDD, it means that you plug off power to hdd,
          power on hdd,
          reenter
          CTRL+Z on terminal
          F3 T>i4,1,22
          this is G-list erase
          Im Back... sort of...
          • spleenharvester
            • Mar 2010
            • 913
            Re: hdd smart error
            Surely won't the error just return? What error is it?
            Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
            • Sus256
              HISENSE 65E7KQ PRO - no boot
              by Sus256
              Hi all!
              HISENSE 65E7KQ PRO
              RSAG7.820.13512 - chassis
              MT9618BAATAB - cpu
              RSAG7.820.12059 - power
              HD650Y3U77 - panel
              KLM8G1GETF - emmc
              Replaced emmc.
              Terminal log
              UART
              AC_ON
              E-B
              FDE enabled
              06-01-2025, 02:11 AM
            • hakuuart
              Error E4 of HP Smart Tank 750 printer
              by hakuuart
              Hello everyone, I need some help or advice regarding the HP Smart Tank 750 device. I have already checked for paper jams and anything stuck inside, as well as all the flex cables, but I still encounter an E4 error. We have taken it to customer service for inspection, but they don't know how to fix it. Is it possible that the issue lies with the main board or the sensor? I would really appreciate any guidance from those who have experienced this problem. Thank you!...
              05-12-2025, 08:51 AM
            • Superbee_dad
              Sharp 80” long short flash backlight error - Help
              by Superbee_dad
              Hello Sharp TV experts
              Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
              > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
              > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
              01-24-2025, 11:51 PM
            • Maalobs
              Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
              by Maalobs
              I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
              The relevant service manual for the chassis is available here.
              The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
              When I short the SDM to ground I get the layer-2 error code 53.
              The inside of the TV has no damaged components and no swollen capacitors.
              In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
              04-02-2019, 01:15 PM
            • medinfo
              Mac T2 after update(There was an error activating your device)
              by medinfo
              Macbook Pro 2019 T2
              iCloud OFF
              MDM unlocked by changing Serial Number
              worked fine but after latest update see (There was an error activating your device. Please try again).
              Erased and boot in internet recovery, same error.
              changed to original serial number (iCloud OFF & MDM ON), same error.
              tested with others serial number, same error.
              tested (CMD+R), (Option+CMD+R), (Shift+Option+CMD+R), same error
              Revived and restored by Apple Configurator and same error.
              Any help ?
              12-31-2023, 02:04 PM
