Acer A315-41G similar to AN515-42, AC OK Battery OK but not charging
This topic has been answered.
  • mon2
    • Dec 2019
    • 14216
    Flux the mosfet well and apply enough heat to make the component swim into place. Do not burn the part or the PCB in the process. After it is cool, be sure to check the resistance of the mosfet as usual (source - drain; source - gate; gate - drain).
    • titomno2
      • Aug 2020
      • 100
      • France
      #42
      so I did it, checking the values everything unplugged and cold:
      PQ305
      LX_CHG -> UG_CHG => 19.59kOhms
      LX_CHG -> +19VB_CHG => 1.6MOhms
      UG_CHG -> +19VB_CHG => 2.7MOhms
      PQ306
      LX_CHG -> GND => 2.8MOhms
      LG_CHG -> GND => 100kOhms
      LG_CHG -> LX_CHG => 2MOhms​
      Still 0.000V on LG_CHG... when I plug the battery and adapter.
      Still blinking amber right away... 🤔
      • mon2
        • Dec 2019
        • 14216
        Check the mosfets as follows. Remove all power. Meter in resistance mode.
        Measure the resistance across the mosfet pins:
        PQ305:
        source (1-2-3) & drain (5-6-7-8)
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Post each measurement. Repeat for PQ306.
        • titomno2
          • Aug 2020
          • 100
          • France
          #44
          PQ305
          source & drain = 3.38Mohms
          source & gate = 0.7 Ohms !!!
          gate & drain = 5MOhms
          PQ306
          source & drain = 2.58Mohms
          source & gate = 100kOhms
          gate & drain = 3MOhms
          • mon2
            • Dec 2019
            • 14216
            PQ305 is certainly a suspect. Flux it well and remove while protecting any surrounding parts that may fly across the room. Also protect any plastic components.
            Once the mosfet is off the board and cool to the touch, measure it again to see if the part is truly defective. It appears to be.
            PS: Even PQ306 @ 100k ohms is a suspect. For mosfets, that is considered to be a low resistance measurement.
            • titomno2
              • Aug 2020
              • 100
              • France
              #46
              Something is wrong with the board
              I have 24MOhm or OL for each measurement on the mosfet cleaned twice just to be sure..
              But on the board I have 19.44kOhms
              • mon2
                • Dec 2019
                • 14216
                Check mosfet @ PQ312 using the same method. Leave PQ305 off the board.
                • titomno2
                  • Aug 2020
                  • 100
                  • France
                  #48
                  PQ312 removed:
                  4MOhms between drain and source
                  OL between Gate and drain
                  OL between Gate and source
                  On the motherboard
                  Gate drain 4Mohms
                  Gate source 4.47Mohms
                  Drain source 5.27Mohms
                  So motherboard good and mosfet also
                  I have well cleaned with IPA both before measurement and short my probe each time to read the zero
                  • mon2
                    • Dec 2019
                    • 14216
                    What are the measurements now of the pcb pads (only) for pq305? Earlier you had very low measurements for that mosfet.
                    • titomno2
                      • Aug 2020
                      • 100
                      • France
                      #50
                      Source to gate = 0.000Ohms at first then 19.56kOhms once I have measured between drain and source ! and after a while I measure 4.7 Ohms
                      Source to drain = 0.9MOhms (increasing)
                      drain to gate = 1.5Mohms
                      It is a strange behavior
                      • titomno2
                        • Aug 2020
                        • 100
                        • France
                        #51
                        So If no new idea, I will solder back the component and maybe check for capacitor issue.
                        I have changed the ic chip, tested the mosfet separatly.
                        The remaining is may-be to swap the capacitor with another one.
                        • titomno2
                          • Aug 2020
                          • 100
                          • France
                          #52
                          My last word after some extra work on the motherboard.
                          Following parts have been changed and all solder joint checked with camera:
                          PQ306 => changed twice has both from doner board were faulty (short circuit bewteen drain and gate).
                          PU301 => changed because I have burn it twice (my hands are shaking these days)
                          PR319 => changed as I have measured it at 3.9kOhms instead of 0Ohms (discovered after replacing PQ306 and PU301 because no POST).
                          After all these modifications:
                          Motherboard works with battery charged (from another computer).
                          Motherboard works with adapter.
                          Motherboard works whend retrieving adapter (and battery plugged in).
                          Charging is still not working (If I remove the battery windows indicate that pc is fully charged instead of not present => this is a new symptom).
                          Note that PQ306 on both motherboards (the one I tried to fix and the one used as doner board is not the same as PQ305, as everyone type 1306 were dead I use the same for PQ305 and PQ306 as it is indicated on the schematics.
                          I remain open to any advice that may be provided by anyone.
                          • titomno2
                            • Aug 2020
                            • 100
                            • France
                            #53
                            So this is the last update and for a good reason. 😉
                            With the help of every one and especially mon2, I was able to solve issues one after the other.
                            So I made more deep research* and discovered even if the A315-41G motherboard is almost the same as the AN515-42, the battery used is not (it is a 2 cells AP16M5J).
                            Even if the BIOS is exactly the same version and the same for at least AN515-42 and A315-41G !!!
                            I have been fooled by my friend that have made the mistake to buy a wrong battery that works for AN515-42 AC14B8K 4 cells (but with exactly the same shape and same wiring !).
                            So I have buy a the correct one 2 cells on ebay and plugged in => works (great without adapter)
                            Once in windows level of battery indicated is 45% => Low but OK as the computer is powered properly.
                            Plugged in the ac adpater => heard a bip that I did not heard previously and amber lighted up right away and not blinking.
                            Check on the power supply => current draw is over 1.5 amps over the nominal consumption and thermal camera confirm the mosfets heating up (and not to much).
                            Now the level is 65% and increasing.
                            So for me this subject is closed and learn a lesson, never trust your friend (especially when he is not knowing what he his doing).
                            Have a nice evening and take care 😀
                            *deeper search also started as the keyboard mapping on A315-41G and AN515-42 is not the same also !
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • DenK
                              Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                              by DenK
                              Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                              1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                              12-06-2024, 01:29 AM
                            • survivalbloke
                              Acer Predator Helios 300 - will not power up if battery is CONNECTED
                              by survivalbloke
                              This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                              06-25-2025, 12:20 PM
                            • ahmarzo
                              Acer TMX314-51 laptop battery problem
                              by ahmarzo
                              I have acer laptop tmx314-51 with part no 6050A3020501.
                              The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                              But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                              I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                              The schematic is not available...
                              04-11-2025, 09:14 AM
                            • mkdj
                              ASUS X571 no power : battery issue?
                              by mkdj
                              Mark and model: ASUS X571
                              Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                              Tests already made:
                              - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                              - I have removed...
                              07-14-2025, 09:16 AM
