Lenovo Legion 5 15IAH7 - location of BIOS chip
  • Mirenia
    • Jan 2024
    • 53
    I've got a Lenovo Legion 5 15IAH7 with no post/no boot issue.
    The mainboard is a NM-E241 Rev 1.0
    Now I am searching for the BIOS chip so I can reflash it.
    But I have some difficulties to identify the correct chip. The schemantics somehow are not really helpful for me (I am a beginner with Laptop schemantics)
    I found 3 Winson chips and one GigaDevice chip as you can see on the screenshots.
    My guess its the W25Q128JVSIN (UB3) because it is the biggest from all.
    I attached the pages of the schemantics from the chips, too.
    (And if you found out, which one is the real BIOS chip, could you maybe explain to me how you know?)
    Thanks a lot in advantage
  • Mirenia
    • Jan 2024
    • 53
    After another research, it seems to be 2 BIOS chips for this Laptop model.
    One contains a 16MB BIOS and the other one a 8MB file.
    I think the chip for 16MB is Winson W25Q128JVSIN (UB3) and the chip for 8MB is the GigaDevice 25R64ESIG neraby.
    Did I get it right?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      16MB chip is the main bios.8MB is for ME region.
      Try flashing only the 16MB chip.
      • Mirenia
        • Jan 2024
        • 53
        I tried flashing both.
        Unfortunately the issue persists. Maybe it's not a BIOS issue, but a faulty component on the board...
        • subzerillo
          • Jan 2019
          • 5
          • Panama
          Hi.
          Which programmer did you use to program the bios chip?
          Could you recommend the software.
          I'm having problem programming my 16mb chip (same winbound chip as yours).
            • 21002
            Originally posted by subzerillo
            Hi.
            What model is your own programmer and software version
            • subzerillo
              • Jan 2019
              • 5
              • Panama
              I have a ch341a black edition.
              I desoldered de bios chip y used an adpater with the ch341a.
              i could read the information from the chip, but im having problem writing on it.
              The software always get unresponsive just after start writing firmware on the chip.
              Used these softwares:
              NeoProgrammer 2.2.0.10
              AsProgrammer 2.1.2
              CH341A Programmer 1.31
              • Mirenia
                • Jan 2024
                • 53
                Hi.
                Hi subzerillo,
                I am using a EZP2019+ programmer with the EZP2019+ Software.
                It works in most cases without problems.
                You can add chips to the software database or modify some parameters.
                But: This programmer only works with the EZP software. So no alternative tools like NEOProgrammer or AsProgrammer.
                • subzerillo
                  • Jan 2019
                  • 5
                  • Panama
                  I will buy the ezp2023 version. I saw that ezp2025 has problems with the software.
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
                  • DynaxSC
                    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                    by DynaxSC
                    Hi
                    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                    08-04-2025, 12:20 PM
                    by SMDFlea
                    Bad...
                    09-02-2021, 04:40 PM
                  • geotox
                    Lenovo Legion Y540-17IRH 81Q4 dead IT8226E-192 chip
                    by geotox
                    Hi, after a short circuit during power cord plug-in the IT8226E-192 chip on my Lenovo Legion Y540-17IRH 81Q4 died. I'm trying to order a replacement for it. There are some similar chips available online, but they are not 1-to-1 identical to my chip. For example, I see there's a 1921BXA chip available for sale, while mine is 1932BXA. Do you guys know if there's any compatibility table available which I can use to see what chips are compatible? Should I just order a similar chip and try it? Will I need to program the chip before installing, or will the laptop do it for me?
                    Thanks...
                    08-02-2023, 09:57 AM
                  • BMCappelletti
                    Asus Chromebox CN62 - wrong chip put on BIOS reader
                    by BMCappelletti
                    Long story short:
                    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                    - gave the computer to his son a couple years later
                    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                    (seems like the story was not that short)
                    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                    01-08-2025, 07:27 PM
