hp elitebook 2530p strange problem
  • ziko07
    • Jun 2021
    • 93
    • Somewhere
    Hi, I have this laptop , battery charge ok, also when powered ON and insert charger battery charge ok, but problem is IF charger is inserted and no matter if removed after that when switch off laptop or going hibernate when lid closed, in that case cannot start again when pressing power button, unless I reinsert battery.
    When operate on battery only no problem at all.
    Also, if remove battery and use charger only no way to start laptop ( I have second same model and it works on charger only fine).
    There is sensor touch button (see image) when pressed on good laptop ,laptop going ON and there is screen like missing some BIOS application, when press enter windows booting ok.
    On bad laptop after charger inserted( even removed after that) power button not works to start laptop, but accidentally I press that sensor touch button and glows on, and after second goes off, on second press glows again and then if I press any button laptop starts ( same as I described above) . But if charger is connected no way to start laptop from power button or this sensor touch button.
    Any tips?
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
    HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
    This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
    09-07-2024, 05:50 AM
    HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
    This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
    09-07-2024, 05:20 AM
