A1706 short PP3V3_S5
  • madjid911
    • Dec 2016
    • 390
    • France
    Hi friends,
    I have a macbook pro A1706 820-00923-A that won't start no signs of life, no liquid, checking the voltages I found PP3V3_S5 was shorted, I removed all the processor coils, but when I 'injects a voltage it is the processor which reacts, can you confirm to me that this is definitely coming from there please?
    I have 20V on the usb-c connector, and 13v stable on​ ppbus_g3h.
    I saw that a track had burned out on PPVIN_2V7NAND_LB after resistor R9350
    I injected voltage on L7660 pin 1 in short but only the processor reacts
    Thanks for your help
  • mon2
    • Dec 2019
    • 14086
    With no power, meter in resistance mode, measure the resistance from this coil where you are injecting and to the CPU rails. Could be the PCH component of the CPU. 38C = ~100 F and does not sound crazy hot for a CPU (with no heatsink).
    What is the resistance to ground of the CPU / PCH rails ?
    • madjid911
      • Dec 2016
      • 390
      • France
      C8154 pin 2 (PPVCCPRIMCORE_SUS_PCH) to L7410 pin 2 (CPU) : 3,9 ohms
      C8154 pin 2 to GND : 2,9 ohms
      L7410 pin 2 (CPU) to gnd : 3 oms
      L7660 pin 2 (PP3V3_S5) to gnd : 1,2 oms
      • mon2
        • Dec 2019
        • 14086
        Flux and lift up one leg of L7660. Then with no power, measure the resistance to ground on each side of the PCB pads for L7660.
        What is the resistance to ground measurements for each PCB pad? This is to confirm if the short is on the producer (U7650) side or the consumer / downstream side of this power rail.
        • madjid911
          • Dec 2016
          • 390
          • France
          L7660 pin is short 0,2 OHMS, pin 2 is 5,43KOHMS
          PP3V3_S5 is produced by who please? by the processor? In this case it would be the processor which is short
          • mon2
            • Dec 2019
            • 14086
            U7650.
            By isolating this rail by removing inductor L7660, you have confirmed that the downstream or consumer side of this power rail is shorted. The upstream or aka producer side is ok. This power rail is likely shutting off naturally after sensing a higher than normal current draw due to the hard short to ground. The current sense pins for this rail exist @ P3V3S5_CSP2 and P3V3S5_CSN2.
            Noting that the CPU / PCH is heating up with a voltage injection (should be 1 volt with 3A - 5A typically) then it is very possible that the CPU is defective. The PCH component does use the same PP3V3_S5 power rail.
            Do also inspect the heat signature on the other side of this logic board for perhaps a capacitor that is hard shorted and causing this night glow on your thermal camera.
            For your injection, consider to use 1 volt but keep increasing the current to confirm the shorted component. A capacitor (ceramic or tantalum) will crumble and split open under the pressure. Very possible the CPU / PCH will do the same.
            • madjid911
              • Dec 2016
              • 390
              • France
              U7650.
              I checked behind I didn't see any condenser heating, So the processor is really dead.
              The client absolutely wants to recover his data, a swap seems complicated to me with the exchange of nand, the change of processor seems easier to me with the reballing machine, what do you think if I change the processor and clean the region me for the bios? I have any chance of finding all the data?
              • reformatt
                • Feb 2020
                • 1404
                A1706 has a lifeboat connector to isolate the SSD from the CPU. The intended method for data recovery is to plug in the Apple Data Migration Toolkit to that connector so that it will mount the SSD on another MAC.
                It's no longer made (and Apple don't publicly acknowledge it's existence). Any that are around are really expensive and only usable on the MBP's from 2016/2017. Not worth trying to track one down for one data recovery, but most data recovery places will at least have access to one. Only problem is last time I queried a local mob for it, they quoted AUD $700 for recovery.
                The NAND's are underfilled so you'd have to transplant to a donor board. Doable but these A1706 boards the copper they use is ultrathin and pads lift super easy. If you can do a CPU then go for it, but be sure to quote appropriately. Typically customers desire for the data is inversely proportional to the cost. The higher the cost, the less important it is!
                • mon2
                  • Dec 2019
                  • 14086
                  New Apple Customer Data Migration Tool Kit 076-00236 for MacBook Pro 2016-2017 | eBay
                  • madjid911
                    • Dec 2016
                    • 390
                    • France
                    This seems like a waste of time, thank you for your help and advice.
                    • iMuhtaseb
                      A1706 - 5v due short 3.3v LDO
                      by iMuhtaseb
                      Board was OK but after keyboard replacement; we found short on 3.3 LDO on UB300 (CD3215).. I removed it and of course I tore off some pads because its undefiled.. pads are repaired successfully.. diode and continuity tests done Pads were USB_UPC_TA_F_P and TP_UPC_TA_SWD_DATA and UPC_TA_SPI_MISO..
                      After replacing UB300 the watts consumption lowered since short is gone but still is stuck @ 5v (0.06amps)
                      I noticed few balls around UB400 so I assumed it needed reball; reballed and replaced it; still 5v.. on both sides
                      While on the other wing U3200 and U3100...
                      11-18-2024, 07:01 AM
                    • rilley
                      MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                      by rilley
                      I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                      I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                      My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                      And the resistor L4004 is literally burned.
                      From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                      07-10-2024, 01:57 AM
                    • DynaxSC
                      Extreme High Current & Low Voltage Short Killer ??
                      by DynaxSC
                      Hi Folks
                      I'm looking for a extreme high current short killer solution for a reasonable cost.
                      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                      After taking off the socket, the shorts dissappear again.
                      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                      10-15-2024, 10:13 AM
                    • Stephen
                      MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                      by Stephen
                      I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                      02-06-2025, 12:03 PM
                    • Victor Moreira Silva
                      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                      by Victor Moreira Silva
                      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                      Well, my decice specs are the following:
                      Model: Acer Nitro 5 AN517-54-55T5
                      CPU: Intel Core i5-11400H
                      GPU: NVIDIA GeForce GTX 1650
                      Motherboard: GH51G LA-L181P Rev:1c
                      The symptom:
                      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                      05-26-2025, 10:49 AM
