BQ24800 to can it be replaced with these parts BQ24780S
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Hello to all.
    may I have a question about these Semiconductor parts BQ24800RUYR? can it be replaced with these parts BQ24780SRUYR?
    I need some good advice and also some information about it. thank you and God Bless...
  • mon2
    • Dec 2019
    • 14695
    Found this:
    https://e2e.ti.com/support/power-man...20and%20800kHz.
    • lorins_core
      BlackSmith
      • Dec 2012
      • 552
      • Philippines
      Originally posted by mon2
      Master My Questions can be okay if I replace the BQ24800RUYR part. for this BQ24780SRUYR? Do they have no problem with the system board or bad effects?​
      • mon2
        • Dec 2019
        • 14695
        The ‘R’ has a few more features than the ‘S’ version. If the software makes use of the extra registers then no it will not work. However the parts are drop in replacements for each other so no harm to test it if the part is available to you.
        Continue to post your updates.
        • lorins_core
          BlackSmith
          • Dec 2012
          • 552
          • Philippines
          Here is happening hahahaha. - Negative 4
          • mon2
            • Dec 2019
            • 14695
            OMG - yet the TI forum (FAE) states the 2 devices are pin-for-pin compatible with each other.
            From the pinout - they look to be compatible as mentioned in the TI forum. Could there be another fault on the logic board?
            Click image for larger version  Name:	BQ24800_typical.png Views:	0 Size:	264.1 KB ID:	3269655
            Click image for larger versionName:	compatible.pngViews:	0Size:	37.3 KBID:	3269654
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              BQ24780S is suitable replacement for 24800. the IC has burnt for some other reason. You need to remove the charging IC and share resistance to GND on each and every pin of charging IC
              • lorins_core
                BlackSmith
                • Dec 2012
                • 552
                • Philippines
                not yet. i hold for now...
                • SirangKap
                  • Feb 2020
                  • 29
                  • Philippines
                  Originally posted by lorins_core
                  Hello to all.
                  If you have BQ24781 you can use it as replacement for BQ24800. I personally tested it yesterday with the latest Acer ExpertBook B1400CB.
                  • SHIBIL MA
                    • Sep 2021
                    • 30
                    BQ24780/BQ24781/BQ24800 same (it’s working ok)
                    • SHIBIL MA
                      • Sep 2021
                      • 30
                      Thanks brother
                      • judamex
                        Active Member
                        • Jan 2021
                        • 186
                        • Mexico
                        Could it work on an asus rog strix zephyrus motherboard? The bq24800 is very hot when I connect the charger and in V+ I only have 4v
                        • SirangKap
                          • Feb 2020
                          • 29
                          • Philippines
                          Then there is a problem in the B+ line and you have to isolate it to find the real problematic parts.
                          • judamex
                            Active Member
                            • Jan 2021
                            • 186
                            • Mexico
                            the real problem is on de KBC, SLC line are on Shortcircuit
                            • baltaszar
                              • Feb 2014
                              • 20
                              • mexico
                              sorry, do you have the full schematic from that page? i need to check who else its connected to regn.. i have an la-n591p wh ohas an ic shorted.. i desold it and battery charges.. but i need to know who is it.. thanks in advance
                              • Sisko
                                Onkyo-593 No power and now clicking sound
                                by Sisko
                                Hi all!!
                                Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                10-03-2025, 02:18 PM
                              • dragon3x
                                After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                by dragon3x
                                Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                power on.
                                Here are some examples :
                                (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                switching supply area).
                                (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                than 6.3 V.)
                                1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                I replaced capacitors with aluminum-polymer.
                                3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                03-21-2025, 02:46 PM
                              • reset1986
                                acer extensa 15 it works but doesn't charge main la-k093p
                                by reset1986
                                Hi everyone, I have this laptop which arrived turned off, the KBC ene IC was short, replaced with an already programmed one, the PC works but doesn't charge, I replaced the BQ24800 IC with BQ24780S now it sees the battery but the orange light flashes and the percentage doesn't increase of the battery which stops at 55%
                                all mosfets are good, there are no shorts, resistances in their values, what can I measure? I attach the diagram and board
                                thanks...
                                11-08-2024, 09:02 PM
                              • Iherduleikgemz
                                Asus FX505DY - Battery not charging - BQ24780S
                                by Iherduleikgemz
                                Hello everyone
                                I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                                I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                                01-13-2025, 03:54 PM
                              • 2elw
                                SVOD4 PCB pictures + parts
                                by 2elw
                                Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                                STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                                GW1N-UV9UG169C6/I5 FPGA - Its a...
                                07-04-2025, 12:23 PM
