Help reading schematic voltages input/output
  • gjgib
    • Nov 2022
    • 70
    • Venezuela
    Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
    I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
    Click image for larger version  Name:	image.png Views:	0 Size:	151.9 KB ID:	3266119 Click image for larger version  Name:	image.png Views:	0 Size:	143.6 KB ID:	3266120
    I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
    I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing, but I don't know entirely which way they are going, if IN or OUT. Btw: +V9B has its 20v.
    B)Any methos to know where values going for sure? Besides logic...
    I bought a couple of these LV5116AGQW IC's time ago and I'm ready to replace but first I must be 100% sure.
    I was following lines and realized that +VCCIN is missing right here:
    Click image for larger version  Name:	image.png Views:	0 Size:	68.0 KB ID:	3266121
    At this point I'm kinda stuck because since I'm rookie there's a bunch of voltages I don't know their usual value.
    This IC, which I think is responsible of sending some of these voltages to the mosfets has these 2 values.
    Click image for larger version  Name:	image.png Views:	0 Size:	93.5 KB ID:	3266122
    If there's posts already with the info I'm requiring feel free to just leave the links here to avoid taking other's valuable time.
    Thanks for any help and sry for still being noob hah Xd
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    You can download the datasheet of IC,if available, to understand it better. +VCCIN will come much later , so not of concern yet.
    1.2V(ddr power supply)/2.5V both are associated with ram circuit. Unless you have 1.2V/2.5V/1.8V , cpu core power related supplies wont rise.
    So in short, focus on why you're missing 1.2/2.5/1.8V rails. Check the respective enables for these rails.
    IC will output these rails when
    01.All its inputs are present( means its powered)
    02.All its enables are present
    03.There is no short on output rails.
    Hope this helps you in focussing a bit more sharply.
    • gjgib
      • Nov 2022
      • 70
      • Venezuela
      I thought +VCCIN was supposed to come online early as after the +V9B... Jesus, I just have no idea. lol. Okay so I'm going again with PU9800 (LV5116AGQW) voltages and enables as you said.
      Thing was I also guided me from the power block and thought brackets meant to be in this order:
      Click image for larger version  Name:	image.png Views:	0 Size:	64.5 KB ID:	3266594
      So I thought it was first block 1, then block 2 and block 3 and, like that, supposedly +VCCIN was before 1.2V/2.5V/1.8V. Which is wrong then...
      Thanks so much for clarifying. Now I know better.
      edit1: About the voltages in and out. Any thoughts?
      • gjgib
        • Nov 2022
        • 70
        • Venezuela
        edit1: About the voltages in and out. Any thoughts?​
        PUMP
        • mon2
          • Dec 2019
          • 14771
          The high adapter voltage feeds into the lower voltage regulators but the EN (enable) decide when that regulator is to turn ON / OFF.
          • gjgib
            • Nov 2022
            • 70
            • Venezuela
            Thanks again mon2 but I meant about how I know when voltages are going in and out in a schematic. Like in the first 2 pictures I shared. The voltages that come from top of the IC are going in and the ones at the sides are going out? Or is that view wrong?
            edit1: there's also some colors (black, red) in some voltages letters/numbers. They mean something?
            • mon2
              • Dec 2019
              • 14771
              A good library part drawing of the charger component should offer labels that detail the vitals like the power rail.
              VCC ; used to power the component.
              VSS / GND ; ground for the component.
              Review the drawing and their pin numbers - the label has _IN suffix so that is an INPUT to this IC.
              Respectively, if there is an _OUT = output from the IC.
              If there is a '#' suffix, then this is considered to be an ACTIVE LOW signal. Meaning that if the signal is a logic LOW = ~0 volts, then the signal is TRUE or ACTIVE. If the signal is HIGH = ~3v3 (usually), then the signal is NOT ACTIVE. This is based on if the IC is powered @ VCC by 3v3. These days we are designing with parts that have 0v9 or 1v2 or 1v8 for the VCC - these rails are very common inside of the new macbooks / iphones, etc. Respectively, their input and output voltage swings must be kept within safe ranges else can damage the component.
              Some pins are 'tolerant' to higher than the VCC voltage that is used to power the IC and this is through internal clamping diodes. The internal diodes will shunt or keep the voltage to a pre-defined safe range.
              For example, if an IC is operating @ 1v8 for VCC but outside signal is 3v3 - the 2 parts cannot mate with each other safely unless there are level shifters / voltage translators (same thing; different words) to shift from one voltage to the other. The other method is to purchase the same part which is 'tolerant' to the higher voltage without risk of damage.
              Recommended reading:
              Getting_Started_in_Electronics_-_3ed_-_[Forrest_M.Mims].pdf (zpag.net)
              • gjgib
                • Nov 2022
                • 70
                • Venezuela
                Very insightful, mon2. Thanks a lot. I'll go through that guide. Very much needed.
                I'll also proceed to measure and list all the voltages on this IC and post it here in case I miss whats going on since I can't find anywhere the datasheet for this specific 40 pins IC (LV5116AGQW). The one that comes in is a 20 pins IC named LM5116WG.
                • mon2
                  • Dec 2019
                  • 14771
                  The datasheet is another world in itself. The mainstream companies are often in the USA (or at least were since the late 60s) - they invented the silicon and overseas companies copied the IP. We called it 'outsourcing' but I call it creating a Frankenstein. The servent killed the master scenario. There are some really good documentaries on the birth of Silicon Valley - worth a watch and inspiring. Years ago, met with Steve Wozniak (Apple), Tramiel family (Commodore / Atari) and founders of many other tech companies. Very humble folks and Steve Wozniak had body guards at the time. He was showing off the industry's first universal remote control at the time.
                  The datasheets can vary with the vendor who builds the product and many of them are in the witness protection program. We will not have access to each and every datasheet and yours may be one of them. Found the 20 pin version from Texas Instruments but keep hunting. Also if stuck, post on EEVBLOG for help - someone there may have what you are after.
                  • gjgib
                    • Nov 2022
                    • 70
                    • Venezuela
                    Wow, meeting those must've been inspiring. Thanks mon2 I'll look into it. Still to jump deeper into the electronic roots and any documentary is very welcome.
                    Btw, I managed to, carefully, measure every pin in the 40 pin LV5116AGQW. Any thoughts with these results?
                    Click image for larger version  Name:	LV5116AGQW 40 pin values.png Views:	0 Size:	187.2 KB ID:	3268083
                    VSYS - 20,2
                    VCC - 5,1v
                    PVCC - 5,1v
                    VDDQ_HG - 0v ----------------V1P8A_IN - 3,3v
                    VDDQ_BOOT - 4,6v ----------V1P8A_PH1 - 0,268v
                    VDDQ_PH - 0v -----------------V1P8A_PH2 - 0,268v
                    VDDQ_SWSNS - 0v -----------V1P8A_SNS - 0,268v
                    VDDQ_LG - 0v -------------------V1P8A_CTRL - 5,1v
                    VDDQ_SNS - 0v
                    VDDQ_CS - 0v
                    VPP_IN - 3,3v
                    VPP - 0v
                    VTT_IN - 0v
                    VTT - 0v
                    VTT_SNS - 0v -----------------------SCL - 3,3v
                    -------------------------------------------SDA - 3,3v
                    AUX_PWM - 0v ---------------------PROCHOT# - 0,39v
                    AUX_SWSNS - 0v ------------------PG_ARAIL - 0v
                    AUX_SNS - 0v -----------------------PG_DDR - 0v
                    AUX_VID0 - 3,3v --------------------DDR_ID - 0v
                    AUX_VID1 - 3,3v
                    AUX_CS - 0,25v ---------------------PMIC_EN - 3,3v
                    AUX_SET - 1,2v ---------------------DIGITAL_CTRL - 5,1v?
                    AUX_RGND - 0v --------------------SLP_SUS# - 3,3v
                    --------------------------------------------SLP_S4# - 3,3v
                    --------------------------------------------DDR_VTT_CTRL - 3,3v
                    (--- just to save space)
                    • gjgib
                      • Nov 2022
                      • 70
                      • Venezuela
                      Pump. Did I ask for wrong stuff?
                      • mon2
                        • Dec 2019
                        • 14771
                        Remove all power. Meter in resistance mode.
                        Measure the resistance (not diode mode) of pin # 25 to ground. You can measure at the inductor / coil on the same pin. This is to check if this line is shorting to ground through some component that is defective or leaky. The concern here is that this rail should be supplying a +1v8 voltage rail but is not.
                        • gjgib
                          • Nov 2022
                          • 70
                          • Venezuela
                          Thanks for reply mon2. There's 3.4 +pin25 -GRD. And 3.8KΩ -pin25 +GRD. (+- probes).
                          Is that value enough to consider there's a leak in the +1v8?
                          • mon2
                            • Dec 2019
                            • 14771
                            For resistance mode tests, there is no polarity requirement with the meter probes.
                            For diode mode tests, the red meter probe must be to ground and black to the point to test.
                            At ~3k4 = 3,400 ohms to ground, this measured rail is not shorted.
                            • gjgib
                              • Nov 2022
                              • 70
                              • Venezuela
                              mon2 Thanks for insight. Is there a value treeshold for a line to be considered 'shorted to ground'? I know it depends on some other things, but I meant this the basic way.
                              Btw: Should I dig more into a possible fault on the IC inputs or do you think, considering the values, that is enough evidence for the IC to be considered as faulty? I know and understand that 100% of the responsability of this is on me but the rewards can be shared
                              • mon2
                                • Dec 2019
                                • 14771
                                In resistance mode - in my opinion, if the measurement if say 500 ohms or lower, it is of concern. Some engineers like to place a 100-120 ohms to ground resistor intentionally on the power rail and this part then acts like a bleed resistor. When the power is OFF, the resistor will impose a relative heavier load to cause the current to bleed off and discharge the capacitors to zero volts. In summary, when there is a load present, the voltage will dissipate from the capacitors that are holding the same. The capacitors will discharge and this makes it safer for the next power on cycle to start from zero.
                                Study the other package for this part to review how this part operates. If available, check if there is an enable pin for this power rail. Check if that enable signal is present. It does sound like this power rail is defective and the IC should be replaced. Before proceeding, check the rest of the output power rails on this component. If their voltage is not present, perform the same type of testing -> is the output shorted? If shorted, the short condition must be resolved before applying a replacement part.
                                When you have time - this is a must watch. I think we should have a sticky here for such worthy documentaries. I know there is another excellent one on the birth of the semiconductor industry - on how Fairchild Semiconductor and others were started. I will try to find that one as well. Fairchild is now owned by Texas Instruments.
                                Triumph of the Nerds (1 of 3) 4K Upscaled (youtube.com)
                                * must watch documentary
                                • gjgib
                                  • Nov 2022
                                  • 70
                                  • Venezuela
                                  Thanks for the documentary mon2 . Already seems like a valuable life lesson. How the dudes following their passion kinda self privated from other life pleasures changed the world.
                                  I detected low impedance in the +VCCIN rail (68,6Ω). +VCCIN_AUX (174Ω). And +VDDQ_OUT (+1.2V)-(418Ω​) Started doing some tests. Would you consider this amount okay for core rails nowadays or somethings off?
                                  • mon2
                                    • Dec 2019
                                    • 14771
                                    +VCCIN rail (68,6Ω)
                                    Yes, this is considered to be a low resistance.
                                    Remove all power. Meter in resistance mode. Review the resistance across the mosfet pins for this power rail (+VCCIN).
                                    Check:
                                    source (1-2-3) & drain (5-6-7-8)
                                    source (1-2-3) & gate (4)
                                    gate (4) & drain (5-6-7-8)
                                    Perform the above checks for the high side (PQ3501) and then the low side (PQ3502) mosfets for this rail. Post all measurements. On a normal mosfet, the resistance should be high.​
                                    • piernov
                                      • Jan 2016
                                      • 4439
                                      • France
                                      68 ohms is fine for Ice Lake/Tiger Lake CPU main power rail.
                                      • gjgib
                                        • Nov 2022
                                        • 70
                                        • Venezuela
                                        mon2 Found something fishy. Might be the issue(?
                                        PQ3501 Impedance / S-D 0.6MΩ / S-G 2.8MΩ / G-D 12MΩ
                                        PQ3502
                                        Impedance / S-D 88Ω / S-G 2.4MΩ / G-D 5.4MΩ
                                        Alsoo... In Diode Mode:
                                        PQ3501 (SD 0.5V) (DS 2.4V) (GS 1.07V) (SG 0.14V) (GD 1.35V) (DG 2.5V)​
                                        PQ3502 (SD 0.18V) (DS 0.05V) (GS 1.17V) (SG 0.45V) (GD 1.25V) (DG 0.5V)
                                        Second one seems like missbehaving right? Should I remove it for testing outside board?
                                        piernov Thanks for the insight, I've created a .txt file to save all about rails resistance values based on generations. I feel like its useful to avoid confusions like this in the future.
                                        • EasyGoing1
                                          Reading input and output of bridge rectifier on the same scope?
                                          by EasyGoing1
                                          I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                                          When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                                          06-26-2022, 12:52 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • redbaron1007
                                          Yamaha HTR-3065 No power/No Standby
                                          by redbaron1007
                                          I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
                                          S9 13.7V
                                          Pwr Ry 0V
                                          AC Det 9.1V
                                          Mgnd 0V GND
                                          The two pins on the transformer for the operation...
                                          09-12-2024, 03:04 PM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
                                        • eigma
                                          Samsung UN40H5003 boot loop every ~8 seconds
                                          by eigma
                                          Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                          Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                          SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                          Main board: BN94-07592P / BN97-08922R...
                                          11-20-2024, 10:31 PM
