Macbook A2442 820-02098 boot and display issue
  • macabook
    • Sep 2024
    • 30
    • France
    #41
    have you found a solution for the probleme, I am facing same issue with A2442 that bootloop when display cable is connected, and work fine if disconnected. I can't figure out what is the problème there slight signs of liquide but no corrosion, i measured and compare with working board nothing that can be suspected. I tested the board on another known screen and it's axactely the same behaviour.
    1-When i connect the display and the backlight cable, the mac shut down suddenly during chime, and did not reboot (5V on meter),i can only turn it back on by disconnecting power
    2-when i connect the display only, it reboots several time and then show the exclamation mark and stay like that, when I mesure PPVOUT_LUXE it's 14V (go to 0 when it reboot)
    3-when i disconnect both, the mac works fine on external display
    Any help will be very appreciated
    • mon2
      • Dec 2019
      • 14219
      Remove all power Meter in resistance mode. Disconnect the LCD display connector.
      Measure the resistance to ground of PPVOUT_LUXE. What is the resistance in ohms? Connect the display connector to the logic board. What is the resistance now of the same backlight rail?
      We fixed an A2338 last week where the display was dark - display was not abused recently but was dropped 6 months ago. Short summary - one of the caps in the backlight output rail was shorted to ~52R ohms to ground. After a few plucks, unit was repaired. Saved the client from purchasing a new display assembly.
      • macabook
        • Sep 2024
        • 30
        • France
        #43
        Hi, thank for the reply, I just found out what was the issue, I used the second original display I have as last attempt, I connected the display cable only. First it started to boot loop like previously and then it entered a different menu (not exclamation mark)asking to choose startup disk, after choosing the disk it worked fine. I connected back camera and backlight and all is working fine.
        So I tried with the display that the board came with, not working again. The display is faulty. But what I don’t understand is why it behave the same way at first connection to the other display, because it led me to focus exclusively on the board but I found nothing.
        • macabook
          • Sep 2024
          • 30
          • France
          #44
          I digged a little bit more by measuring diode mode on the screen connectors pin, and there is a clear short to ground on the backlight connector on the pins PPBCON_AWAKESW_BKLTCONN_ISNS, that explain the sudden shut down when display and backlight cables are connected.
          I foud also why I was having bootloop even with a good dispaly, if i connect only the display cable without the backlight on the good display the bootlooping happens and this tricked me to think that the issue is on the board but was not.
          Maybe when backlight is not connected it miss current sensing or other conditions that is done during boot ?
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            🛠 Original Issue
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • dqtech
            macbook pro late 2012 A1425 boot issue
            by dqtech
            this is my first time having this issue...everytime turn on will have this kind of word before apple logo appear....and sometimes just stuck here and have to force shutdown and turn on again....anyone have solution for this?...
            12-22-2024, 01:54 AM
          • abajor
            Alienware Area-51 R2 Boot Loop issue.
            by abajor
            I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
            It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
            To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
            Right now I'm trying to dig through the PDF schematics and Board...
            03-08-2024, 10:08 PM
          • No Lan
            [Macbook pro A1708] [Boot loop] [Trackpad ?]
            by No Lan
            Hey everyone,
            Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
            Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
            Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
            05-24-2025, 03:09 PM
          • twonk9098
            Macbook Pro mid 2015 battery required to boot?
            by twonk9098
            I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
            The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
            This model has the newer trackpad which is not clickable when turned off.
            At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
            If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
            12-10-2024, 06:51 PM
