Macbook A2442 820-02098 boot and display issue
  • veedo
    • May 2016
    • 31
    • United Kingdom
    Hi All
    I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
    Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
    I found component UD290 ( SF0101-I2C) little bit green but after cleaning and soldering it back once again it not making any differences .
    Where to look after now?
    Thanks for any help
  • mon2
    • Dec 2019
    • 14079
    Perhaps you are disconnecting the flex on JP400 to make this unit function?
    JP400 is linked to the ALS (ambient light sensor) and the camera controller logic.
    Remove all power. Meter in DIODE mode (not resistance mode). Red meter probe, yes red, to ground. Black meter probe to the point to test.
    With the flex cable attached onto JP400, measure the DIODE mode readings for:
    I2C_CAM_1V8_SCL
    I2C_CAM_1V8_SDA
    I2C_CAM_1V8_SDA
    I2C_CAM_1V8_SCL
    Then disconnect the flex cable from JP400 and measure the above points of interest again.
    Post each measurement.
    • veedo
      • May 2016
      • 31
      • United Kingdom
      so without flex connected is:
      I2C_CAM_1V8_SCL 0.549
      I2C_CAM_1V8_SDA 0.549
      with flex is:
      I2C_CAM_1V8_SCL 0.454
      I2C_CAM_1V8_SDA​ 0.454
      but the issue shows up when JP600 is connected, sorry not mentioned before which flex make that.
      • mon2
        • Dec 2019
        • 14079
        Diode readings are fine.
        Carefully, review the voltage to ground measurements (not diode mode) for both sides of the level shifter @ UD290. This bidirectional FET level shifter is used to shift from the 1v2 to / from the 1v8 voltage domains.
        • veedo
          • May 2016
          • 31
          • United Kingdom
          I have 1v2 and I have 1v8 as well, with and without flexes connected.
          RD296 and RD297 have 1v8 on both ends, RD295 AND RD294 have 1v2 on both ends.
          • ronaldopdias
            • Jul 2015
            • 93
            • United Kingdon
            Hi. Good morning.
            I have got a Mac same model with same issue here.
            Did you manage to solve the issue with yours?
            • veedo
              • May 2016
              • 31
              • United Kingdom
              Hi, not I'm afraid, left it without repair
              • mon2
                • Dec 2019
                • 14079
                Share the voltage to ground of PPBUS_AON. What is the voltage and current draw showing on the USB Type C meter (if available for testing - if not, consider to source one on Amazon).
                • obelix24
                  • Jun 2023
                  • 291
                  • Slovakia
                  I have exactly the same Macbook Pro 14" A2442 (M1 Pro)
                  water damage arround UP800, UR700,UR730,UR760
                  I've cleaned all corrosion but there is no backlight.
                  I tried to reball UP800 but doesn't help still the same. Chime and apple logo without backlight and after some time macbook restarts (bootloop)
                  I read this and i disconnected JP600 and i was able to restore system and fully start and test macbook (everything is working, camera, keyboard, lid sensor, microphone, speakers, wifi, bt, battery, ....)
                  I probably need to replace UP800 but i don't understand what is causing the bootloop on JP600.
                  Any idea ?
                  • mon2
                    • Dec 2019
                    • 14079
                    Remove all power. Measure each contact used by JP600 in diode mode. Red meter probe, yes red to ground. Black meter probe to the pin to test.
                    Confirm the diode mode measurements against the schematic to see if the diode measurement is ok or not. Start with the I2C / SMBUS lines.
                    Post your table of measurements with their pin #s / labels as shown in the schematic to make the review easier.
                    • obelix24
                      • Jun 2023
                      • 291
                      • Slovakia
                      1 GND
                      2 GND
                      3 OL
                      4 0.157
                      5 OL
                      6 0.510
                      7 GND
                      8 0.510
                      9 OL
                      10 GND
                      11 OL
                      12 GND
                      13 GND
                      14 0.800
                      15 OL
                      16 GND
                      17 OL
                      18 GND
                      19 GND
                      20 GND
                      21 OL
                      22 0.310
                      23 OL
                      24 0.348
                      25 GND
                      26 0.310
                      27 OL
                      28 0.346
                      29 OL
                      30 GND
                      31 GND
                      32 0.658
                      33 GND
                      34 0.315
                      Whole top Line of pins (except GND are OL) so i guess there is problem. According to BRD file all this pins go to oposit side to Resistors and Capacitors and then directly to CPU.
                      • obelix24
                        • Jun 2023
                        • 291
                        • Slovakia
                        ok so the OL should be ok after some research ... is it possible that issue is that UP800 is faulty ?
                        • mon2
                          • Dec 2019
                          • 14079
                          What is the voltage to ground of:
                          BL_PWR_EN (RP873)
                          I2C_LUXE_DEBUG_SCL
                          I2C_LUXE_DEBUG_SDA
                          SPMI_DISP_BKLT_CLK
                          SPMI_DISP_BKLT_DATA
                          • obelix24
                            • Jun 2023
                            • 291
                            • Slovakia
                            In Diode mode :
                            BL_PWR_EN (RP873) - 0.416
                            I2C_LUXE_DEBUG_SCL (RP841) - 0.417
                            I2C_LUXE_DEBUG_SDA (RP842) - 0.421
                            SPMI_DISP_BKLT_CLK (CP813 - cap is not here so i measured on pad) - 0.341
                            SPMI_DISP_BKLT_DATA (CP814 - cap is not here so i measured on pad
                            ) - 0.333
                            • mon2
                              • Dec 2019
                              • 14079
                              Voltage to ground - not diode mode.
                              • obelix24
                                • Jun 2023
                                • 291
                                • Slovakia
                                OK i've connected one USB-C port and connected power it was taking 20V
                                BL_PWR_EN (RP873) - 1,2V but drops to 0V
                                I2C_LUXE_DEBUG_SCL - 1,2V but drops to 0V
                                I2C_LUXE_DEBUG_SDA - 1,2V but drops to 0V
                                SPMI_DISP_BKLT_CLK - 0V
                                SPMI_DISP_BKLT_DATA - 0V
                                • obelix24
                                  • Jun 2023
                                  • 291
                                  • Slovakia
                                  any idea why the voltage is dropping from 1,2 to 0 ?
                                  • obelix24
                                    • Jun 2023
                                    • 291
                                    • Slovakia
                                    i've replaced UP800 and it's the same ...
                                    no backlight (i can hear the chime + apple logo is there but no backlight) after some time macbook restarts.
                                    without JP600 connected it's working fine (on external screen)
                                    any idea what can cause this strange issue ?
                                    • obelix24
                                      • Jun 2023
                                      • 291
                                      • Slovakia
                                      when I test only motherboard and power connected over USB-C charger on RP833 (LUXE_UG2_R) voltage is not stable but it's falling from approx 3V to 0,5V. Next resistor RP830 (LUXE_LG2_R) I'm getting 0V
                                      is this normal behaviour ??
                                      Also I'm not sure if RP840 should be on board or no. (I don't have other board to compare but from photos on google it looks like it's not there ...
                                      • obelix24
                                        • Jun 2023
                                        • 291
                                        • Slovakia
                                        OK so I probably found the problem. After checking with thermal camera and screen connected I noticed hot spot on U5000.
                                        I've removed it (U5000) and 3 to of 4 pads for PP3V8_AON were missing and the one left was corroded
                                        U5000 is useless as it's missing one pad
                                        Is it possible to use U5000 from (MacBook Pro A2338 M1 - board number 820-02020) ?
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • dqtech
                                          macbook pro late 2012 A1425 boot issue
                                          by dqtech
                                          this is my first time having this issue...everytime turn on will have this kind of word before apple logo appear....and sometimes just stuck here and have to force shutdown and turn on again....anyone have solution for this?...
                                          12-22-2024, 01:54 AM
                                        • abajor
                                          Alienware Area-51 R2 Boot Loop issue.
                                          by abajor
                                          I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
                                          It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
                                          To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
                                          Right now I'm trying to dig through the PDF schematics and Board...
                                          03-08-2024, 10:08 PM
                                        • No Lan
                                          [Macbook pro A1708] [Boot loop] [Trackpad ?]
                                          by No Lan
                                          Hey everyone,
                                          Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                                          Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                                          Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                                          05-24-2025, 03:09 PM
                                        • twonk9098
                                          Macbook Pro mid 2015 battery required to boot?
                                          by twonk9098
                                          I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                                          The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                                          This model has the newer trackpad which is not clickable when turned off.
                                          At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                                          If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                                          12-10-2024, 06:51 PM
