Macbook A2442 820-02098 boot and display issue
  • macabook
    • Sep 2024
    • 37
    • France
    #41
    have you found a solution for the probleme, I am facing same issue with A2442 that bootloop when display cable is connected, and work fine if disconnected. I can't figure out what is the problème there slight signs of liquide but no corrosion, i measured and compare with working board nothing that can be suspected. I tested the board on another known screen and it's axactely the same behaviour.
    1-When i connect the display and the backlight cable, the mac shut down suddenly during chime, and did not reboot (5V on meter),i can only turn it back on by disconnecting power
    2-when i connect the display only, it reboots several time and then show the exclamation mark and stay like that, when I mesure PPVOUT_LUXE it's 14V (go to 0 when it reboot)
    3-when i disconnect both, the mac works fine on external display
    Any help will be very appreciated
    • mon2
      • 16201
      Remove all power Meter in resistance mode. Disconnect the LCD display connector.
      Measure the resistance to ground of PPVOUT_LUXE. What is the resistance in ohms? Connect the display connector to the logic board. What is the resistance now of the same backlight rail?
      We fixed an A2338 last week where the display was dark - display was not abused recently but was dropped 6 months ago. Short summary - one of the caps in the backlight output rail was shorted to ~52R ohms to ground. After a few plucks, unit was repaired. Saved the client from purchasing a new display assembly.
      • macabook
        • Sep 2024
        • 37
        • France
        #43
        Hi, thank for the reply, I just found out what was the issue, I used the second original display I have as last attempt, I connected the display cable only. First it started to boot loop like previously and then it entered a different menu (not exclamation mark)asking to choose startup disk, after choosing the disk it worked fine. I connected back camera and backlight and all is working fine.
        So I tried with the display that the board came with, not working again. The display is faulty. But what I don’t understand is why it behave the same way at first connection to the other display, because it led me to focus exclusively on the board but I found nothing.
        • macabook
          • Sep 2024
          • 37
          • France
          #44
          I digged a little bit more by measuring diode mode on the screen connectors pin, and there is a clear short to ground on the backlight connector on the pins PPBCON_AWAKESW_BKLTCONN_ISNS, that explain the sudden shut down when display and backlight cables are connected.
          I foud also why I was having bootloop even with a good dispaly, if i connect only the display cable without the backlight on the good display the bootlooping happens and this tricked me to think that the issue is on the board but was not.
          Maybe when backlight is not connected it miss current sensing or other conditions that is done during boot ?
          • jaglion19
            • Oct 2017
            • 118
            • TURKEY
            #45
            a2485 16" macbbok pro m1 promax
            Hello everyone. First of all, I'm facing the same issue. The customer's screen arrived broken, with no display but a backlight. I ordered an LCD from AliExpress and installed it. The display was fine, but I cracked the screen while tightening the screws too tightly, so I ordered a new LCD. When I installed the screen, the device remained in the Apple loop with no light. I didn't observe any short circuits. The same thing happened with other broken screens. It works fine externally when the light and camera flex are attached, but the screen flex remains in the reset state. Furthermore, the light doesn't light up even when the flex is attached. I changed the UP800 to make sure, but there's still no change. The thing I noticed is that the PPVDD_DISP_AWAKESW line in ohm diode mode has an ohm of 052. If it's not higher, I have three options left: either the UP710 1V29 line is blocking voltage or not completing it. Or, if the u770 isn't one of these, the CPU display data line remains.
            • jaglion19
              • Oct 2017
              • 118
              • TURKEY
              #46
              voltage lines same as a2442
              Yes, I had the opportunity to make a quick observation today. It should be 112 instead of 52 ohms. I haven't been able to detect the fault yet. Two places have low ohms, one is PP3V8_AON, the voltage of this is normal 3.7V, but I measured the place where PPVDD_DISP_AWAKESW is on the working motherboard and it should be 112ohms. If one of the power integrated circuits is not faulty, there is a high probability that the line sending voltage to the display on the processor is faulty. However, I am not saying for sure, I will completely disassemble and replace the u770 and up710 and the surrounding components and try them. When I find a junk motherboard, a motherboard with iCloud installed, or a reference motherboard
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                🛠 Original Issue
                The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ezenia
                Gigabyte B450M S2H POST/boot issue
                by ezenia
                So I got a faulty Gigabyte B450M S2H motherboard off eBay. It was listed as having a potentially faulty CPU socket. When I got the board, I went straight to checking the CPU socket under a microscope with the plastic cover removed to verify if it was actually damaged. None of the pins looked broken or damaged.
                So I started troubleshooting the board to see what's actually wrong. The 1st issue I found was there was 0.7V at the power button header. I found the cause was the 6-legged ESD chip that was next to the header. So I removed the chip which brought 5V back to...
                04-19-2026, 03:20 PM
              • Stephen
                A2779 MacBook Pro 14" MOST WEIRD ISSUE I HAVE EVER SEEN
                by Stephen
                MacBook Pro 14" A2779 having a no power issue. power raise are ALL HEALTHY! I probed all of them ALL healthy.
                Getting 20volts 4amps battery charging, etc. Disconnected battery to see voltage and amps. Getting 20volts 0.135amps-0.139 with no battery connected. Disconnected trackpad to see what the fans would do, they go into full blast, odd behavior, plugged into an LCD external nothing displays, ok...this is freaking weird, going down this rabbit hole I keep trying everything. I even went out of my way and tested a working battery I had in stock at the store. LIKE Nope nothing same...
                04-21-2026, 11:32 AM
              • dqtech
                macbook pro late 2012 A1425 boot issue
                by dqtech
                this is my first time having this issue...everytime turn on will have this kind of word before apple logo appear....and sometimes just stuck here and have to force shutdown and turn on again....anyone have solution for this?...
                12-22-2024, 01:54 AM
              • jasonr2000
                Macbook Pro 16" 2019 No Display After Lid Sensor Issue
                by jasonr2000
                hi guys i have the above MacBook pro 2019 16"
                i did some dust cleaning recently and i somehow damaged the lid angle sensor. so i purchased the nerdtool1 lid angle sensor calibrating tool and a new sensor.
                installed it and followed the instructions to program the sensor.
                and now im still getting no display out of the MacBook pro.
                its booting up ok ive noticed the keyboard and touchbar is all lighting up.
                it was also showing a display before i replaced the damaged sensor and now i cant get any display out of it.
                02-18-2026, 01:54 PM
