LENOVO DG425/DG525/DG725 NM-B321 NO POWER
  • madjid911
    • Dec 2016
    • 390
    • France
    hello, I have a Lenovo that does not turn on at all, I flashed the bios but no result, the battery charges well I have 3v and 5v, the sio chip is well powered, taking all the voltages I noticed that the bios was not powered even after pressing the keyboard power button.
    I'm missing +1.8VS, but I have +3VALW_APU and +1.8VALW.
    Can you explain to me how to analyze the attached diagram to get +1.8VS please, thanks
    SCHEMA AND BRD : https://www.badcaps.net/forum/troubl...st#post1770089
  • mon2
    • Dec 2019
    • 14255
    For me, it is easier to start the review with the mosfet in question which for your case, it is Q39. Start with measuring the voltage to ground of each pin cluster.
    source (1-2-3)
    gate (4)
    drain (5-6-7-8)
    You have noted, that the voltage does not reach the pins 1-2-3. By reviewing the datasheet for this mosfet, we know it is a N-channel mosfet. For this mosfet to enable, the gate voltage (pin # 4) must be higher than the voltage being passed between source / drain pins. Measure the voltage to ground of pin # 4.
    Review the schematic to confirm the power path from V20B+ (right side of the partial schematic) -> to the gate pin # 4 of this Q39 mosfet. If the voltage is not higher than 1v8 at the gate pin, then someone is pulling this trigger voltage down or there is a break in the PCB traces and/or components in this same power path.
    Click image for larger version  Name:	N-channel.png Views:	0 Size:	65.0 KB ID:	3214668
    Click image for larger version  Name:	power_path.png Views:	0 Size:	59.7 KB ID:	3214669
    • madjid911
      • Dec 2016
      • 390
      • France
      source (1-2-3)
      gate (4)
      drain (5-6-7-8)
      Thanks for your help
      source (1-2-3) : 0V and 3,3 KOHMS
      gate (4) : 0V and 110KOHMS
      drain (5-6-7-8) : 1V8 and 9,6 KOHMS
      Mode diode : 377/1163
      Q45 and Q46 : Pin1 : 0V, pin 2 : 4V7 , pin 3 : 0V
      I don't have V20B+, so I looked at the R214 resistor : pin 1 : 0V (no short), pin 2 : 20V. I have a lot of macbook air a1466 donor motherboard, I found a resistor of 300K, in the diagram r214 is at 270K, can I replace it with a 300K? I didn't find 270K
      • mon2
        • Dec 2019
        • 14255
        Can you confirm that V20B+ is missing since +3VALW_APU is also based on the same power rail source. You have +3VALW_APU? Best to measure for the presence of V20B+ at the DCin mosfets -> check pins 5-6-7-8 (any of these are ok) on mosfet PQ202.
        • madjid911
          • Dec 2016
          • 390
          • France
          Yes +3VALW_APU 3V4, V20B+​ is present 20V5 but not on the mosfets, only on R214 pin 2, but pin 1 0v. so I thought it was the resistor that was dead, but when unsoldering it I lost it, I replaced it with a 300 Kohms but the result is the same I have 20V5 on pin 2 but 0v on pin 1
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Check Resistance to GND on R214,pin1.
            • madjid911
              • Dec 2016
              • 390
              • France
              Sorry, I meant Pin 1 : 20V5 and 161 OHMS. Pin 2 : 0V and 197OMH. (on the diagram they reversed R214 PIN 1 AND 2).
              I changed the resistance, I don't understand why I can't get 1V8VSGATE, I don't have any shorts on it
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                I doubt your measurements. Just confirm what is the voltage on pin 4 of Q39 ? If R214,pin1 has indeed 20V,then Q39 ,pin4 must be 20V also.However, without any voltage on pin2 of R214,i cant imagine voltage on pin1 of R214.
                So double check your readings again.
                • madjid911
                  • Dec 2016
                  • 390
                  • France
                  Q39 Pin 4 : 0V. Pin 5 : 1V8
                  R214 Pin 1 : 20V5V. Pin 2 : 0VV
                  pay attention on the schematic the r214 is reversed
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Ok, the issue here is with SUSP and SUSP# signal. Q45/Q46 both are N channel,so the gate(pin2) must be low so that R214 allows to pass 20V to Q39 pin4. Trace the SUSP signal and it'll lead you to SUSP#. So trouble shoot within this area.
                    • madjid911
                      • Dec 2016
                      • 390
                      • France
                      RE18 pin 1 (+3VL_EC) 3V5; pin 2 (SUSP#) 0V.
                      SUSP : 4V7
                      SUSP# : 0V
                      Is it the sio chip IT8586E that generates the SUSP# ? In this case it would be defective ?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Yes, SUSP# is generated by SIO but it goes to APU. More often then not,SUSP# is not generated 'coz of bad APU/SOC. You need to probe each and every area of SUSP/SUSP# before concluding bad APU.
                        Right now,you're getting just the opposite values on SUSP/SUSP# lines.Working scenario is SUSP-0V and SUSP#-high.
                        • madjid911
                          • Dec 2016
                          • 390
                          • France
                          strange I have 0V everywhere on SUSP# and 4V5 everywhere on SUSP, is it necessary to try a new sio? Or should I give up
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            You need to check all the points where SUSP/SUSP# goes. SIO is very unlikely the culprit. Its either any of the mosfets on SUSp/SUSP# lines or the SOC is dry/bad.What i suggested is based on experience and not measurements since you've not done any troubleshooting.
                            • Jamescameron696969
                              Lenovo Ideapad 320-14IKB LCFC DG425 DG525 NM-B321 Discrete to UMA
                              by Jamescameron696969
                              can someone help me the GPU ram is shorted i wanna convert this to UMA coz amd A6 has integrated graphics.
                              but i dont know how to covert this. i tried removing coils in gpu rail and gpu ram the short is gone but it doesn't display.
                              i attached the schematic ang boardview.
                              [Mod. Edit] Schematic -> https://www.badcaps.net/forum/troubl...89#post1770089
                              Boardview -> https://www.badcaps.net...
                              02-07-2024, 07:47 PM
                              Lenovo 3000 Series Schematic
                              Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                              3000 C100 laptop with Braille keyboard
                              Lenovo 3000 C
                              C100, C200 - 15-inch XGA screen
                              Lenovo 3000 N
                              N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                              N500 - 15.4 inch screen.
                              Lenovo 3000 V
                              V100, V200 - 12.1-inch WXGA models
                              Lenovo 3000 G
                              G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                              10-04-2024, 06:05 AM
                              Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                              09-06-2024, 06:40 AM
                              This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                              09-06-2024, 06:06 AM
                            • derradji89
                              Need help Lenovo MIX 320-10lCR domaine name SERCOL
                              by derradji89
                              Hi everyone 🤗
                              I have a Lenovo MIX 320-10lCR computer.**
                              1. **Operating System**: Windows 10 ** Education** 64-bit.
                              2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                              3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                              4. **BIOS Chip Reflashing**: Currently,...
                              04-19-2025, 03:04 PM
