Macbook Pro M1 820-02020 - no display
  • mon2
    • Dec 2019
    • 14719
    Good progress. Now that most of it is working - you can try to perform the DFU. This should correct any firmware quirk.
    There is a hall effect sensor in the trackpad that is used to sense if the display lid is open or closed. Perhaps that is faulty and you should check the IPD_LID_OPEN_1V8 logic level at this stage of your repair.
    Monitor this voltage when the lid is open and compare to the value when it is closed.
    Is the camera listed in your hardware device listing? Or is not detected at all? There is a multiplexer chip @ UP102 that is used to ENABLE / DISABLE the camera and is selected by the end user for privacy reasons.
    Review the voltage to ground of FTCAM_DISABLE_1V8_IC_L. Post each measurement.
    • obelix24
      • Jun 2023
      • 300
      • Slovakia
      #42
      I've checked
      lid open IPD_LID_OPEN_1V8 - 1,8V
      lid closed IPD_LID_OPEN_1V8 - 0V
      Camera is not available also in system report when I select camera I got information that no camera device connected.
      I'm not sure if I have correct board view or what but where UP102 should be I have only two metal shield for CPU clamps.
      • obelix24
        • Jun 2023
        • 300
        • Slovakia
        #43
        also one thing. Touch ID is not working power button is working.I don't know if these two thing are connected.
        • obelix24
          • Jun 2023
          • 300
          • Slovakia
          #44
          mon2 any idea ?
          • mon2
            • Dec 2019
            • 14719
            Measure the voltage to ground of PP5V_CAM on each side of LP610.
            • obelix24
              • Jun 2023
              • 300
              • Slovakia
              #46
              Hi thank you for response.
              5,2V on each side of LP610
              • mon2
                • Dec 2019
                • 14719
                So the camera is being powered. Is this with the LCD connected? If not, do attach the LCD and confirm this voltage on LP610 remains @ ~5 volts.
                The camera is a MIPI CSI interface.
                Measure the voltage to ground of:
                MIPI_FTCAM_DATA_ISOL_N
                MIPI_FTCAM_DATA_ISOL_P
                MIPI_FTCAM_CLK_ISOL_N
                MIPI_FTCAM_CLK_ISOL_P
                MIPI_DATA_CONN_N
                MIPI_DATA_CONN_P
                MIPI_CLOCK_CONN_N
                MIPI_CLOCK_CONN_P
                • obelix24
                  • Jun 2023
                  • 300
                  • Slovakia
                  #48
                  yes the voltage is with LCD connected.
                  I will measure and post results.
                  • obelix24
                    • Jun 2023
                    • 300
                    • Slovakia
                    #49
                    mon2
                    MIPI_FTCAM_DATA_ISOL_N - 0V
                    MIPI_FTCAM_DATA_ISOL_P - 0V
                    MIPI_FTCAM_CLK_ISOL_N - 0V
                    MIPI_FTCAM_CLK_ISOL_P - 0V
                    MIPI_DATA_CONN_N - 0V
                    MIPI_DATA_CONN_P - 0V
                    MIPI_CLOCK_CONN_N - 0V
                    MIPI_CLOCK_CONN_P - 0V
                    Diode mode (red on ground, black on test) all 0.290V
                    • mon2
                      • Dec 2019
                      • 14719
                      Diode mode confirms there are no shorts on these high speed camera lines but the 0volts indicates these lines are not being driven. The mipi clock lines are to be driven by the logic board (host) side; the mipi data lines are the camera captured pixel output data. It is possible that the camera is disabled or not being detected. Before the camera can spew out the high speed streaming video capture, it must be configured by the slower smbus or low power mipi (LP) channels. Mipi lane 0 pair also functions as the low power, slower speed configuration channel for the target camera. Suggest to measure the voltage to ground of the smbus pins on this same connector as the camera mipi lines. Confirm that the scl and sda lines are not stuck low. If stuck, camera will not be found and the mipi lines will remain at 0 volts.
                      • obelix24
                        • Jun 2023
                        • 300
                        • Slovakia
                        #51
                        mon2 sorry but i don't get it now what smbus should i check ? to me it looks like camera module itself is probably broken ?? or maybe connection on LCD board may be faulty but i haven't found where the camera is connected on LCD.
                        • obelix24
                          • Jun 2023
                          • 300
                          • Slovakia
                          #52
                          Another update. I've fixed Touch ID by replacing UT610 from donor board There was missing PP3V0_TOUCHID after replacing Touch ID is working perfectly
                          So I have only 2 problems left.
                          1. Camera is still not working not even recognised by OS
                          2. Touch Bar is working but lights up after I close lid and reopen it, or after some time.
                          Any ideas ?
                          • mon2
                            • Dec 2019
                            • 14719
                            Measure the voltage to ground of pins 24 and 26 on this camera connector. These are the I2C lines for SCL and SDA.
                            • obelix24
                              • Jun 2023
                              • 300
                              • Slovakia
                              #54
                              On LCD connector you mean ? I've measured on TP's
                              I2C_BKLT_SCL - (PIN 26) - 5,2V
                              I2C_BKLT_SDA - (PIN 24) - 5,2V
                              • obelix24
                                • Jun 2023
                                • 300
                                • Slovakia
                                #55
                                or you mean camera connector in the LCD ?
                                • obelix24
                                  • Jun 2023
                                  • 300
                                  • Slovakia
                                  #56
                                  I was checking macbook more and i noticed that Automatic Adjust brightness is No in system report ...
                                  I've checked on boardview ALS but i'ts quite hard as there are almost no IC's on the board ... it looks like is controled on LCD boards ... I've tried to replace UD140 but still the same and camera is not working ...
                                  On Rossmann group forum i found same issue as i'm having (trouch bar working but light up after some time, camera not working) and problem was LCD cable. But i have tried 2 different LCD cables and same issue ...
                                  I will try to order new LCD cable to have 3 to be 100% sure it's ok
                                  • mon2
                                    • Dec 2019
                                    • 14719
                                    The ALS sensor is I2C / SMBUS based. Locate it and check the voltage to ground of this ALS sensor SCL & SDA lines.
                                    • obelix24
                                      • Jun 2023
                                      • 300
                                      • Slovakia
                                      #58
                                      I have problem with this MacBook. I've replaced keyboard as the original one was working but lot of the keys were sticky. I've ordered new keyboard and replaced it with no issue. But when I inserted motherboard it take only 5V and 0,2A I took the board with care to prevent any damage so I don't understand what happened.
                                      I've checked and PPBUS_AON is only 0,5V when power is connected (taking 5V 0,2A (I tried to inject voltage 1V 3A but looks there is no short it's taking only 0,03A)
                                      PP1V25_S2 in diode mode is only 0,283V but also doesn't looks like any short on this rail ...
                                      any idea ?
                                      CD3217 should be both ok as I've measured 5V on both FF200 and FF201
                                      strange is that on F5200 I've measured in diode mode 0.073V on both sides. I've tried to inject voltage here but it's taking nothing 0A
                                      only thing that gets in my mind that when I was replacing keyboard it was without backlight and the old one looks little bit sticky also so I've used another one from a2189 or a1708 (I'm not 100% sure but it looks same as original one ...
                                      • mon2
                                        • Dec 2019
                                        • 14719
                                        Remove all of the parts you are suspecting that are the not 100% like the original such as the keyboard backlight. Even the keyboard should be removed. Use the tweezers to perform the ON/OFF button activity to test again.
                                        • obelix24
                                          • Jun 2023
                                          • 300
                                          • Slovakia
                                          #60
                                          i've tried with motherboard removed just connecting power and it's immediatelly taking 5V and 0,2A
                                          I tried also in case without anything connected and same result.
                                          I've tried also DFU but it's not working
                                          i found similar issue that i have hare :
                                          https://www.youtube.com/watch?v=x3yL...nnel=MasterLiu
                                          but i'm concerned as he is injecting 9V in PPBUS_AON, but when i inject only 1V in PPBUS_AON is taking nothing
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • som_b1
                                            Macbook screen does not display an image
                                            by som_b1
                                            Hello. I encountered such a problem - the MacBook screen lights up but does not display an image. Almost like a flexjgate in reverse). Maybe someone has encountered such a breakdown. The problem is in the cables or maybe in the t-con?
                                            11-05-2025, 12:20 PM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
                                          • Ado02
                                            MacBook Pro A2159 - No Display / Works on External Screen
                                            by Ado02
                                            I am working on a MacBook that came in for a screen replacement. The MacBook powers on and works on the external screen. However, the screen stays black. The replacement screen made no difference. On further investigation, I found small amounts of corrosion.
                                            Please see the attached image.
                                            I ordered a refurbished logicboard, but the problem didn't go away with the old or replacement screen.
                                            Can anyone suggest where to go from here?...
                                            01-12-2023, 03:35 AM
                                          • ledbylight
                                            M1 A2337 Macbook - No Display, likely due to logic board
                                            by ledbylight
                                            Hi all!
                                            This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                                            I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                                            11-04-2024, 06:36 PM
