820-00875-A and PP3V3_S5 line
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Hi
    I need help on an Apple 820-00875-A board, it doesn't turn on and I noticed that the voltage fluctuates from 0V to 3.3V on the PP3V3_S5 line. If I inject 3.3v (with the board powering and the coil isolated from the generator) the consumption is 8 mA.
  • mon2
    • Dec 2019
    • 13996
    Carefully review the voltage to ground of P3V3S5_EN @ pin 21 on U7650. What is the measurement?
    With the low current on the downstream / consumer side of the power rail, there is no short on that section.
    Remove all power. Meter in resistance mode. What is the resistance to ground @ L7690 (best to check each of the PCB pads for this component)?
    Next, meter in resistance scale. With no power to the board, measure the resistance between pins 17 & 18 on U7650. You are checking the resistance of the current loop path (CSP2 & CSN2). Post each measurement.
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      Hi
      the resistance detected by both sides of the L7690 is (with the tester in manual mode) 1.5 M, not stable (it tends to drop); while in auto mode it is not detectable. The resistance between pins 17 and 18 of u7650 is 1.5712 Kohm in auto mode
      • mon2
        • Dec 2019
        • 13996
        The high resistance to ground on L7690 pads confirms there is no short on these rails.
        The current sense loop resistance looks to be ok since R7693 and R7692 are in parallel. Both being 3k16 => should be 1580 ohms between pins 17 & 18. As a double check, confirm the resistance between pin 18 on the IC and the PCB pad # 2 of L7690. This should be ~3k16 ohms. No power during these resistance checks.
        Interested in a few other resistance checks for this regulator.
        No power -> meter in resistance mode.
        1) One meter probe on L7690, pin #1 pcb pad (PP3V3_S5). Other meter probe @ pin 16 of U7650 (VFB2). What is the resistance ?
        2) One meter probe on L7690, pin #1 pcb pad (PP3V3_S5). Other meter probe @ pin 3 of U7650 (RF). What is the resistance ?​
        Next, confirm the voltage to ground of the enable pin of this regulator @ pin # 21 (P3V3S5_EN).
        It is possible that U7650 (TPS51980A) is defective. Louis mentions this fault often in his YT videos.
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          Thanks for your help, from what I understand u7650 goes on off, the only stable voltage is pin 21 P3V3S5_EN while all the other signals fluctuate. PP5V_S4 is not present. With pad 1 of L7690 disconnected the P3V3S5_EN voltage is present so there is probably a feedback signal which fluctuates and has repercussions on the chip itself since if the chip were to go into protection it would become hot,, I don't know how correct an idea is. I see a pgood signal but it refers to PP5V_S4
          R7693 -> 3.156K
          R7692 -> 3.147K
          U7650 PIN 18
          L7690 PAD 02 PAD1 DISCONNECTED
          RES 3.156K
          U7650 PIN 18
          L7690 PAD 02 PAD1 CONNECTED
          RES 1.571K
          U7650 PIN 17
          U7650 PIN 18
          RES 1.571K
          L7690 PAD 01
          U7650 PIN 16
          RES 13K
          L7690 PAD 01
          U7650 PIN 03
          RES 180K
          L7690 PAD 01
          GND
          RES 1.6M​
          • mon2
            • Dec 2019
            • 13996
            Since the enable pin is stable, suggest to replace this TPS51980A​ @ U7650. Have some here but to get to you would have to fly in, have some good pizza and fly back. Perhaps you have a local source for these or a donor board?
            • jasko_jacker
              • Oct 2014
              • 1137
              • italy
              Yes, I could try to replace the chip but since it is an old laptop I don't think the shop will accept the cost of repair. However I found this post which might be useful. https://boards.rossmanngroup.com/thr...-problem.3252/
              • mon2
                • Dec 2019
                • 13996
                What is the voltage to ground on ppbus_g3h ?
                is it stable?
                • jasko_jacker
                  • Oct 2014
                  • 1137
                  • italy
                  Yes, misured on F8400 13V stable PPBUS_G3H
                  • jasko_jacker
                    • Oct 2014
                    • 1137
                    • italy
                    Solved, but I still don't know why. I checked all the recommended voltages including SMC_PM_G2_EN or PM_SLP_S4_L and they were all correct. In this case I would normally have thought there was a problem involving one of the two voltages that the U7650 creates, such as a damaged component that uses them.
                    However, I desoldered the U4000 memory because I wanted to use it in another board and I noticed that now the P3V3S5_VSW and P5VS4_VSW voltages were stable, I re-soldered the U4000 and the board started working again. probably (since nothing repairs itself) if it was a software problem something was reset, if it was a hardware problem (a BGA chip that had some balls with problems) the repair will certainly take a short time. I'm not very expert in Apple systems and I'm now starting to dedicate myself to repairing this brand​
                    • lezsimply
                      Low resistance reading on 3v line, Asus Prime H310M-A R2.0 desktop motherboard
                      by lezsimply
                      Hello Everyone and Good Day,
                      I've got an issue with this desktop motherboard. It does not power on, Asus Prime H310M-A R2.0. I tested 33ohms reading on 3v line on the ATX connector. It beeps on continuity mode. I tried injecting voltage from 0.9v at 1.5amps and no current being drawn. I raised the voltage to 3v @ 4amps and now I only get 22mA on current. I checked with thermal camera and there is no part heating up. I'm afraid of going further the safe voltage. What could possibly causing the line to be shorted. 5vsb has no short. I get 0.9v on positive pin of power switch. There's...
                      11-22-2024, 03:14 AM
                    • cind12
                      GTX 1080 TI Gigabyte Aorus low resistance on vmem
                      by cind12
                      Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                      Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                      The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                      Resistance on 12V 4K ohms (Power present when on)
                      Resistance on 12V PEX 4K ohms...
                      12-08-2023, 09:09 AM
                    • Nagy Daniel
                      Lowest possible resistance on laptop motherboard rail - Guide Table request
                      by Nagy Daniel
                      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                      So, I generated a table with AI so I can...
                      03-04-2025, 08:24 AM
                    • cubytus
                      Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                      by cubytus
                      Hi to all,
                      I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                      I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                      Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                      01-10-2024, 01:26 AM
                    • TrueSword88
                      Kogan - KALED65XU9220STB - Blue Vertical Line
                      by TrueSword88
                      Hi all.
                      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                      The line just happens to coincide with the end of COF and start of the next COF (attached).
                      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                      Hoping to fix...
                      05-05-2023, 04:28 PM
